rr8325 Samba Member
Posted: Wed Jun 14, 2017 5:24 pm Post subject: Painting rear deck vent area |
Took a 5/16 dowel, cut a slot in the end. Inserted a chunk of scotch brite pad small enough to fit through the slots. Spun with my cheap cordless... Got to a lot of places I couldn't with just a paint stick.
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Thu Jun 15, 2017 9:25 am Post subject: Re: Painting rear deck vent area |
Nice. Now to just figure out how to get paint down in there. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Jun 15, 2017 10:14 am Post subject: Re: Painting rear deck vent area |
skinny airbrush? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
rr8325 Samba Member
Posted: Thu Jun 15, 2017 2:04 pm Post subject: Re: Painting rear deck vent area |
I'm going to try the airbrush or touch up gun trick. Thought about masking the outside to paint the inside, then try to block the vents from the back and then paint the outside. Sounds, ah easy huh?... |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2664 Location: Long Island, NY
Posted: Thu Jun 15, 2017 2:12 pm Post subject: Re: Painting rear deck vent area |
A duster?
Some of these can get into some pretty tight places, and they're flexible. |
Joseph DR Samba Member
Posted: Wed Jun 28, 2017 2:05 pm Post subject: Re: Painting rear deck vent area |
rr8325 wrote: |
Did you glue the pad onto the dowel? If not did it fly off or stay put?
Thanks for the idea. _________________ 1964 Beetle |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Wed Jun 28, 2017 6:59 pm Post subject: Re: Painting rear deck vent area |
NICE idea!
I sandblasted it.
To paint it again, I took a spray can and changed out the nozzle for a nozzle with a straw(from some brake-clean), then stuck the sprayer nozzle on the end of the straw.
A bit hard to aim, but it worked. |
buguy Samba Member
Posted: Fri Jun 30, 2017 6:56 am Post subject: Re: Painting rear deck vent area |
I blasted mine too. But I then just sprayed it with the gun on full round, then wiped off the outside part with some thinner. Same thing with the clear coat. Then came back and painted the car like normal. |
rr8325 Samba Member
Posted: Sat Jul 01, 2017 1:34 pm Post subject: Re: Painting rear deck vent area |
Cut a split in the dowel, I have since changed to a 1/4 inch steel rod. The wood one wanted to break on the grain. Used a hack saw to cut a slot in the rod, then spread it out a little with a screw driver. The roughness of the saw cut holds the pad in. The PO had sandblasted the area and primed but the area was very rough from over spray. Have not sprayed yet, sanding the rest of body. |
Posted: Wed Jul 05, 2017 9:48 am Post subject: Re: Painting rear deck vent area |
OK, going to try it out with a metal rod. Thanks for the tip.
