February 1963 with sunroof, actually just boxes of parts LOL
Page: Previous  1, 2, 3, ... 14, 15, 16  Next
djway3474
djway3474 is offline
PostPosted: Wed Jul 05, 2017 10:14 am    Post subject: Re: February 1963 S with sunroof, actually just boxes of parts LOL Reply with quote
Rome, thanks for the radio information.
Bobnotch, AA makes a conversion flywheel with the pilot bearing in it. Clearancing for the larger flywheel is not a problem. The hardest part with the hanger seems to be what to attach to on the early cars. The shroud does look like a bit of work.
Thanks to all for the great info.
Erik G
Erik G is offline
PostPosted: Wed Jul 05, 2017 10:24 am    Post subject: Re: February 1963 S with sunroof, actually just boxes of parts LOL Reply with quote
the ISP West Tach is very nice, no one makes a clock conversion decal
look up supaninja here and on shop talk forums. He did Type 4 and megasquirt in his early notch. I've ridden in it, and it's nice
for the radio, the hard thing to find is the soft surround. I had to buy a whole parts radio just because it had the surround I needed
for your interior, it's hard to beat stock for 63 and earlier cars
Here's what a correct 63 looks like
djway3474
PostPosted: Wed Jul 05, 2017 12:22 pm    Post subject: Re: February 1963 S with sunroof, actually just boxes of parts LOL Reply with quote
That's a good looking interior.
Clatter
Clatter is offline
PostPosted: Wed Jul 05, 2017 9:08 pm    Post subject: Re: February 1963 S with sunroof, actually just boxes of parts LOL Reply with quote
If you dig through my thread, I welded a set of late rear mount brackets on.
With a more valuable early car like yours, it might be better to stick to bolt-on mods.
You can pick up the bar from the bumper mounts...
Bus Motor Build
What’s That Noise?!?
djway3474
PostPosted: Wed Jul 05, 2017 10:56 pm    Post subject: Re: February 1963 S with sunroof, actually just boxes of parts LOL Reply with quote
Thats a good idea. Anything I do I try not to alter the car much other than bolt on and bolt off. Thanks Very Happy
Bobnotch
Bobnotch is offline
PostPosted: Thu Jul 06, 2017 12:18 pm    Post subject: Re: February 1963 S with sunroof, actually just boxes of parts LOL Reply with quote
That's what Dan Zink did on his 65 Notch with T-4 power. I think he's got some pics of it on his home page, but sorry I don't have a link for it (I'm on the wrong computer).
OP, I was just pointing out some of things you need to be aware of. My son is using a 210mm flywheel on his car with a former 914 1.7L in it. We swapped the car over to IRS this spring (was in the plans for this winter though), as we really didn't want to try and buy a swing axle clutch for a 210mm flywheel for 1 summer of use. Now if he had used a 200mm conversion flywheel, it would have been different, as he already had a pressure plate for the SA trans. The conversion to IRS only set us back 3 days, but in the end, it's done so we won't have to mess with it in the winter.
As for adding rear mounts to a swing axle bodied car, I'd only do it IF I were doing an IRS conversion. It's a lot more work to do on a Notch than say a Fastback or a Square, since the air box is on the inside, versus the out side of a Fastback/Square. I know, as I converted my 65 Notch using later style engine hanger mounts. You have to cut part/most of the bottom of the duct out, and raise it to gain clearance to install the hanger brackets, then flip the brackets upside down, and side for side to get them to fit.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
KTPhil Premium Member
KTPhil is online now
PostPosted: Thu Jul 06, 2017 1:21 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
djway3474 wrote:
I would like to put a sun roof back in the car. How specific year wise do I need to be when looking for the entire sunroof assembly? I have seen entire later square backs for a decent price but they are later on and I really don't have the room to cut one up so I am hoping to find a donor roof section. Judging by the parts I now have I am not thinking a stock restoration but instead a nice highway cruiser. Any help with positive suggestions and what can be done would be greatly appreciated.
djway3474 wrote:
Is there a post of the ISP install of a sunroof?
ISPwest put a sunroof in my car. They peeled the whole roof off at the drip rails. A lot of work but the end result is indistinguishable from a factory job.
https://www.thesamba.com/vw/forum/viewtopic.php?p=7003741
ALLWAGONS
ALLWAGONS is offline
PostPosted: Thu Jul 06, 2017 2:43 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
Hey Man, post some pics of your car! JK, but let us see this so called '63. Whenever an early one pop up everyone chimes in with info, and most times it get sold before anything happens.
Martin
allwagons
NON INFLUENCER APPROVED
notchboy
notchboy is offline
PostPosted: Thu Jul 06, 2017 7:59 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
You will have two choices for radios if you want that OG early look. Blaupunkt and other - Motorola, Sapphire and the like. VW mad a good generic bracket for the Sapphire but what was touched on was the Blaupunkt system. There is a lot to it.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8032902#8032902
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
djway3474
PostPosted: Thu Jul 06, 2017 8:36 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
I have a 3 button Blaupunkt with a T3 faceplate in my Ghia. I have a Sapphire with coffin buttons but no faceplate and no soft cover I did not use because it was not period correct. So now I only need the more difficult parts.
What is the soft cover made from?
djway3474
PostPosted: Thu Jul 06, 2017 9:10 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
Here she is sitting on the bed frame I found her on. appears to be a later front beam to me.
notchboy
notchboy is offline
PostPosted: Thu Jul 06, 2017 10:19 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
Pebble grain like the dash and foam.
1964 1500 S
notchboy
notchboy is offline
PostPosted: Fri Jul 07, 2017 3:16 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
And here is the even harder to find surround.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8000774#8000774
1964 1500 S
djway3474
PostPosted: Fri Jul 07, 2017 3:24 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
Well, there were 4 parts for my low light Ghia that no one made so I made them and sold the extras. Sounds like it might be time to do that again.
notchboy
notchboy is offline
PostPosted: Fri Jul 07, 2017 3:26 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
Do you need a dash? Thats a part that is in serious need.
1964 1500 S
djway3474
PostPosted: Fri Jul 07, 2017 5:28 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
I need to know more about the soft radio cover. Is there any metal embedded in the material? If there is metal I would need an example of the raw metal and a nice example of the cover.
I have a new repop dash, are they still available?
I know people that have made air cooled dash parts and always have interest in taking on new projects.
If there is sufficient demand I will look into these projects
Rome
Rome is offline
PostPosted: Fri Jul 07, 2017 7:24 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
You could probably make your own radio surround bracket using a large piece of aluminum, like 1/16" thick. It would be a simple type with a flat bottom, flat and straight-back sides. Make a pattern using a paper grocery bag or wrapping paper. Lay your radio on the paper to determine the minimum width and length. The face's top would conform to the bottom curved surface of the dash. The face would have a 1/2" or 3/4" wide flange on the top and sides. Bend and shape the flanges in your workbench vise. The top flange would have 2 holes drilled to attach under the dash bottom flange. The side flanges would be so that when you bend up the bracket sides (form the gentle curve along the bottom outer corners using a wooden dowel) you can rivet them together with two evenly spaced 1/8" rivets. For the front (towards front of car) of the bracket, you'll need to figure out how to hang it below the dash. Then make cutouts in the face for your radio knobs and the central pushbutton/frequency box.
When you have it all assembled, paint it with black wrinkle-finish paint. I'm nearly certain that the metal one I found in the mid '80's in a junked, heavily rusted 5-bolt wheeled two-toned Notch had either a black wrinkle finish, or a heavy pebble surface in flat black. You could also wrap the bracket with black pebble-grain vinyl glued on with contact cement which would help hide the rivets.
From that car I also removed a genuine Bambus under-dash shelf. Junkyard was located just outside New Milford, CT. I didn't even have a Type 3 at the time, but knew those were rare parts so I removed and kept them. I remember the car being safari beige with a black roof.
Would probably take you a full afternoon or two. You'd have to assess if your fabrication time can justify/balance the cost (and availability) of finding a used bracket.
notchboy
notchboy is offline
PostPosted: Fri Jul 07, 2017 9:00 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
The cover is molded foam rubber with a pebble grain cover like the dash and the wrap around sections have. Its all the same texture to match. There is no metal in it, just one molded foam piece.
Id have to see a pic of the dash you have as there are old repops and new ones floating around now. One has a meh ok finish to it the other does not replicate the finish at all.
And yes you are correct in needing a good original to truly replicate. That sir is the key. Find one or the person willing to front it. Wink Laughing
1964 1500 S
Erik G
Erik G is offline
PostPosted: Fri Jul 07, 2017 9:35 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
He's going custom. No need for a correct dash right? Do good enough and leave the dashes for people wanting correct cars?
Just saying... muuhwaahwaaa and all that. If you are custom this, custom that, no need to spend $1k plus on a dash
Bobnotch
Bobnotch is offline
PostPosted: Fri Jul 07, 2017 10:15 pm    Post subject: Re: February 1963 with sunroof, actually just boxes of parts LOL Reply with quote
From the pic, it's hard to tell if the beam was swapped, or if just the spindles and rotors were swapped. The rear brake backing plates did come from a later 4 lug car though, as you can see the adjuster holes (66 on).
Tram wrote:
Page 2 of 16
