GERMANAIRE Samba Member
Joined: August 25, 2007 Posts: 689 Location: BUFORD,GA.
Posted: Mon Dec 20, 2010 5:25 pm Post subject: |
JonnyCakes wrote: |
Clyde at Athens German Aircooled usually has Brazilian brake parts in stock. I got some front wheel cylinders from him a couple of months ago. Since he is close by, you can save alot on shipping and help out a local vendor at the same time! |
I am glad you posted would you have his number I always see him at show and had his # but dont remember where I put it. Thanks,Peter |
DiggerD Samba Member
Joined: August 11, 2006 Posts: 278 Location: North Georgia
Posted: Mon Dec 20, 2010 6:08 pm Post subject: |
PM sent..... _________________ 63 Beetle
66 Deluxe Bus |
Posted: Mon Dec 20, 2010 8:10 pm Post subject: |
JonnyCakes wrote: |
PM sent..... |
Thank You for the hook up just picked up the wheel cylinders and will be putting them on tomorrow and will be posting the outcome.
Thanks Again, Peter |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Mon Dec 20, 2010 10:02 pm Post subject: |
You could have run the bigger super beetle or type 3 front wheel cylinders in the rear along with the 4 piston calipers puts a little more braling to the rear.
Remember that the SACO caliper have 4 bleeders each. Bleed the inside first then the outside ones bottom first then the top.
Is it the type 1 disc brake master you have. _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Posted: Tue Dec 21, 2010 8:11 am Post subject: |
splitpile wrote: |
Is it the type 1 disc brake master you have. |
Yes Ronnie thats the one they told me to use I will try it if it does not work right I will switch it. If you can recommend one I would appreciate it. Thanks for the bleeding instruction I am defenitly learning thru this thread Thanks to all for the help and heads up! |
VW Aircooled Society Samba Member
Joined: November 17, 2014 Posts: 68 Location: Coral Springs ,FL
Posted: Sat Feb 06, 2016 12:22 am Post subject: Re: Dual M/C-New Saco Disc Brakes-New Rear W/Cylinders Leaki |
How is this kit ? _________________ Innovating Parts for Aircooled VWs & Dune Buggies
www.vwaircooledsociety.com |
gleason Samba Member
Posted: Mon Jul 10, 2017 4:16 pm Post subject: Re: Dual M/C-New Saco Disc Brakes-New Rear W/Cylinders Leaking!! |
Yep, like he said, what is the story on this kit??? Any feedback?? |
