Oil leaking from transmission side of driveshaft?
lintbrush
lintbrush is offline
PostPosted: Sat Jul 01, 2017 9:42 am    Post subject: Oil leaking from transmission side of driveshaft? Reply with quote
I woke up to about a 12" puddle of oil this morning. Upon inspection it looks like it's leaking from where the driveshaft meets the transmission. In this pic, I've cleaned off all the oil, but the arrow points to where it appeared the source was. Is there a seal behind this? I have to replace the boots anyways, but figured that housed grease in these IRS ends and replacing the boots wouldn't sole this oil leak. Thoughts?
1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/
busdaddy
busdaddy is offline
PostPosted: Sat Jul 01, 2017 9:47 am    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=597080&highlight=output+seal
Слава Україні!
Wildthings
Wildthings is offline
PostPosted: Sat Jul 01, 2017 9:50 am    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
A bit of seepage isn't a big deal so you don't have to act immediately, but do plan this in. You also need to replace at least that one cracking axle boot.
You might also consider doing the inner and outer rear wheel bearing seals at this point.
lintbrush
PostPosted: Sat Jul 01, 2017 11:07 am    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
Perfect! Thank you. I cleaned everything off and just returned from a 15 minute jaunt down the freeway so I can confirm the leak point. Of course nothing is leaking now, which makes me think I should check the hypoid level Smile. Is this a job worth tackling without the specialized tools? I see some used makeshift PVC and other tools with various levels of success.
Wildthings
PostPosted: Sat Jul 01, 2017 12:26 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
About the only specialized tool you need is a tool to pop the seal out and a pair of duckbill snapring pliers. You can improvise if you want but a seal puller will save a lot of aggravation and doesn't cost much. Some pullers are pretty junky though so buy with care.
These seals can weep for years hurting little, as I suggested above you should consider doing other work at the same time that requires having the axle removed to do.
lintbrush
PostPosted: Tue Jul 11, 2017 5:29 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
A lot of heavy, gritty sediment, but seals don't look horrible so far. Waiting on parts, but here is where things are at:
busdaddy
busdaddy is offline
PostPosted: Tue Jul 11, 2017 6:08 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
How does the outer edge (snout) of the drive flange look where the seal rides against it?
Слава Україні!
lintbrush
PostPosted: Tue Jul 11, 2017 7:29 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
Smooth. The marks shown below cannot be felt.
Clearly leaking though. I haven't drained the fluid yet. I figured I didn't have to until I got to the inner seal. It only appears to be leaking from one side.
busdaddy
busdaddy is offline
PostPosted: Tue Jul 11, 2017 7:34 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
I was more interested in the side of that area. (you may want to clean it up first)
Слава Україні!
skills@eurocarsplus
Samba Peckerhead
skills@eurocarsplus is online now
PostPosted: Tue Jul 11, 2017 7:48 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
^^^^X2
make sure the sealing surface on the flange hasn't had a groove worn in it.
also, there is a big o-ring behind that diff nut that likes to bleed oil as well
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
airschooled
Air-Schooled
airschooled is offline
PostPosted: Tue Jul 11, 2017 8:36 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
Don't drain the fluid until both sides are complete. You want the fluid to flow out of the junction so debris has a harder time finding its way in. Once you've done all your work (both sides) then consider draining or topping off to complete the job.
Like the posters above say, your output flange sealing surface should be groove-less and shiny clean.
When reinstalling the circlip, make sure that it fully seats; no sense in having the flange pop off down the road somewhere.
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
lintbrush
PostPosted: Wed Jul 12, 2017 4:45 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
Okay, here are pics of the snouts. The wear lines are faint and hard to feel.
Left:
Right:
Also, when I pulled the right drive flange out (I have them just placed in there just to keep them covered) I'm guessing this that I found on the ground is the thrust/spring ring? I haven't pulled the final seal out yet so wasn't expected to see this ring quite yet.
busdaddy
busdaddy is offline
PostPosted: Wed Jul 12, 2017 5:27 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
The ring is responsible for the marks on the ends of the snouts so you can figure out where they came from by that.
While you await the new seals shine up the seal areas on those flanges with steel wool or super fine sand paper so they are like a mirror and smooth as a baby's ass.
Слава Україні!
mikedjames
mikedjames is offline
PostPosted: Thu Jul 13, 2017 1:09 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
On my transmission the oil leaked because the bearing was a little loose and the splined shaft could move from side to side a little and let oil pass the seal at speed.
I suspect this was from when the transmission was reconditioned and it was not exactly set correctly.
I tightened the side plate maybe a millimetre of rotation and replaced the seals and it has not leaked since.
Ancient vehicles and vessels
lintbrush
PostPosted: Fri Jul 14, 2017 10:40 am    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
Duh, that was easy...
I didn't see it mentioned anyplace, but based on the snout wear marks and the matching marks on the washer it appears the narrower side of the washer faces the transmission?
kreemoweet
kreemoweet is offline
PostPosted: Fri Jul 14, 2017 3:34 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
That ring is called "thrust ring" in Type 2 Bentley manual, "spacer ring" in Type 1 manual. It's shown in Type 2 manual, but no mention of correct orientation.
Type 1 manual specifies that flat side goes toward CVJ flange, and rounded (narrower side, as you put it) side towards differential.
'67 bug: seized by the authorities
lintbrush
PostPosted: Mon Jul 17, 2017 11:37 am    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
Finished. Not the funnest, cleanest or exciting project. Hardest part was getting the seal to seat. I used the 46mm socket and mallet, but realized after I was done I could have put a bolt/washer/nut thru it and used it as a press.
For the benefit of others tackling this in the future, here are a few photos...
The seals are definitely taller than the originals by ~7mm:
New seal in:
New sidescrew lock/coverplate:
Cleaned up the drive flange :
Final drive seal...done.
Tcash
Tcash is offline
PostPosted: Mon Jul 17, 2017 12:49 pm    Post subject: Re: Oil leaking from transmission side of driveshaft? Reply with quote
For the future
Tcash wrote:
68-79 Bus Drive Flange Seal
http://germansupply.com/Scotts_Folder/Tech_Article...0Seal.html
Replacing transmission drive flange oil seal -pics-
Differential Side Seals
