Balmoral1958 Samba Member
Posted: Mon Jul 17, 2017 7:38 am Post subject: '77 Bus Fuel sender - to cut or not to cut |
Need to replace my sender - to do it "properly" need to remove my carbs etc.....
or do i just cut an access hole?
Thoughts appreciated |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51124 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jul 17, 2017 7:46 am Post subject: Re: '77 Bus Fuel sender - to cut or not to cut |
Only you can answer that question, but once you cut a hole it's hard to undo that.
Shop carefully for a new sender or rebuild yours, most new ones require the hole since you'll be changing it often. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jul 17, 2017 7:53 am Post subject: Re: '77 Bus Fuel sender - to cut or not to cut |
thanks -
If I could make a good looking "hatch" that would help - I have a "European" made sender which may be of marginally better quality... |
chachi Samba Member
Joined: November 18, 2003 Posts: 858 Location: the weeds
Posted: Mon Jul 17, 2017 8:11 am Post subject: Re: '77 Bus Fuel sender - to cut or not to cut |
i say just fix it right and let the next guy fix it in 20 years. _________________ '74 transporter panel
'91 vanagon carat NAHT |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Mon Jul 17, 2017 9:14 am Post subject: Re: '77 Bus Fuel sender - to cut or not to cut |
Balmoral1958 wrote: |
Easy one. A note pad and situational awareness can replace a fuel gauge until such time as the engine needs to come out for a maintenance item - at which time out comes the fuel tank for refreshments of hoses and sender. _________________ .ssS! |
Okay - I believe I can remove the firewall with the engine in... just... |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Mon Jul 17, 2017 9:36 am Post subject: Re: '77 Bus Fuel sender - to cut or not to cut |
Why do people ask this? Like some dude on a forum really matters...
With all the junk parts out there....do it. I did and have for several others. Do it nice and neat. Shit....it was a fix that vw did as well.... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Mon Jul 17, 2017 9:46 am Post subject: Re: '77 Bus Fuel sender - to cut or not to cut |
I just cut mine. My reasoning was that VW would have made a access port but they were all into saving money. So I cut the hole and made a cover out of donar metal cut from the baggage floor of a similar year bus. In the end I did a good job and it's all covered up anyway.
Whatever you do, try to replace the sender with an original one, not one made in China. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Mon Jul 17, 2017 9:49 am Post subject: Re: '77 Bus Fuel sender - to cut or not to cut |
Thanks - the forum serves a great purpose of giving a diversity of feedback - as we have seen. I'll see if I can find a piece of matching metal...
Any pictures of their hatch would be great... |
Posted: Mon Jul 17, 2017 10:17 am Post subject: Re: '77 Bus Fuel sender - to cut or not to cut |
This is one I did in a 1972 bus
And I used a marine access cover
I can't seem to find pics of a cover I did using donar metal _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
mainstreetprod Samba Member
Joined: March 09, 2017 Posts: 313 Location: Tennessee
Posted: Mon Jul 17, 2017 10:34 am Post subject: Re: '77 Bus Fuel sender - to cut or not to cut |
Easiest , cheapest and safest way is a 4 1/4" hole saw from Harbor Freight on a variable speed drill, with a little cutting oil. No sparks at all= no blowing up the block, as you might do with a grinder and cutting wheel if your sender gasket leaks any fumes at all. And you get a nice neat hole that can be covered with the marine cover posted prior. This may be considered a hack, but with the quality of today's senders it is a necessary hack. |
Posted: Mon Jul 17, 2017 10:44 am Post subject: Re: '77 Bus Fuel sender - to cut or not to cut |
Thanks! Appreciate the responses. |
Tcash Samba Member
