KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Sat Jun 10, 2017 5:54 pm Post subject: Installed correct unbroken distributor... let's see how she runs |
I have had overheating and pinging issues since my rebuild, and it's been a strange trail to work to resolve them. After switching to a 20W-50 oil from 30 weight I had been using for the last year, the oil pressure is where it should be and it's running a bit cooler as a result. And I relocated my oil temp sensor to get it out of the hot cooling air stream, so it's more correct now. Other threads detailed those past adventures.
But I've still had wonky ignition advance, and so I investigated a bit. After rebuilding (and no doubt before as well, no reflection on my meticulous engine guy--I did all assembly past the long block stage), we checked the advance, and found way too much.
From TDC at idle, it was hitting 33 degrees just on the mechanical, and the vacuum added another 10 or more. At high loads and speeds, these would work in tandem, and the whopping 45 degrees made it ping under load, and no doubt also contributed to the high oil temps. So we removed and plugged the vacuum advance. With FI, you must keep timing at TDC statically or at idle, so the practice of just playing with the distributor position was not an option.
So I went to Bentley to see what advance I should have. Turns out I was way over spec on the mechanical side. At 2500 rpm, I should be looking at about 20, and then add 10-12 for vacuum, for a reasonable 32 total. So why the heck did I have 33 mechanical?!
I figured the weights or springs must have broken inside, which would also explain the changing idle timing and also my tach being very jumpy. Thinking back to last year's Type 3 Invasion and my variable timing, this seemed like the answer.
From an idle, it ran better if I gave it a bit more static advance, but that made the pinging worse, so I backed it off and put up with a little hesitation and the elusive Type 3 FI bucking if I jammed the pedal at 2000 rpm or less.
I had a spare distributor, but it was for a '71 automatic. Looking at Bentley, that actually seemed like a more reasonable curve for my 1776, higher compression engine:
- quicker mechanical advance off the line
- less mechanical at higher rpm where I had pinging
- WAY less vacuum advance
Frustratingly, the Bentley graphs are not to the same scale, so I scanned them and overlaid them to compare:
The Bentley graphs are expressed in distributor shaft, not engine, RPM and degrees, so double these figures for your tach readings.
The orange dotted line was my readings after the rebuild. With sky-high mechanical, something was wrong.
So I put the '71 AT distributor on, including the vacuum advance, and it drives much better. The bog is gone, so throttle response is smoother and a bit quicker. I took a brief run at freeway speeds and it accelerated great, with no pinging; however, it's cool out today so I can't really push her to see if the pinging is gone. Next weekend should be 90 or above, so that will make a better high speed test.
The weirdest thing I found, is that I had the wrong distributor in it! The unit I pulled is a 1970 MT "AB" unit, not the correct "AC" version. I know the history of this car and engine; my dad bought it new and gave it to me. Nothing in the docs I have shows a distributor change! This was an early '71 so maybe they used the older unit, but I doubt it-- '71 federal smog rules made that unlikely.
But look at the blue AB curve-- high mechanical advance at high rpm. I was even higher than that (orange dotted line) due to some malfunction. But the stock '70 curve would probably have been too much even if it was working correctly.
No wonder it was pinging!
Fingers crossed for next weekend's testing in hotter weather, but I may be onto the root cause!
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Sat Jun 10, 2017 9:18 pm Post subject: Re: Installed correct distributor... let's see |
The joys of 45+ year old EFI and distributors. . . _________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
KTPhil Samba Member
Posted: Fri Jun 16, 2017 8:27 pm Post subject: Re: Installed correct unbroken distributor... let's see how she runs |
Update:
Still a higher reading on the temp gauge than I'd like, but it's not calibrated, so it's more the behavior not the absolute reading, so...
It's 90+ out today and I ran it for long stretches on the freeway at 70-75mph, and oil temp slowly rose to 260F. A bit high but I could not get it any higher no matter how hard I pushed it further.
Before the swap, I could get the oil temp that high faster, at lower ambient temps, at 65mph, and it was still rising so I would cut it down to 55 or 60 max and worry a lot.
So this is real progress. Much smoother, not a hint of pinging, very much better low end smoothness (no bucking even if I boot it at 1500 rpm).
I'll work on checking the gauge with an IR gun. Last time I did it was reading about 20F too high. If I convince myself that differential is real, I'll put a resistor inline to calibrate it.
So far so good, thanks for listening.
danielheff Samba Member
Joined: January 22, 2016 Posts: 136 Location: San Diego, CA
Posted: Mon Jul 10, 2017 3:00 pm Post subject: Re: Installed correct unbroken distributor... let's see how she runs |
Hey just wondering your outcome of this new distributor? I'm thinking my distributor could be contributing to my engine running hot at high RPMS as well.
I'm using the VW 311-905-205AB, Bosch 0231 163 008
Which has this advance range:
Advance/Retard Range: Vacuum: 8-12deg Adv; Centrifugal: 10-14deg @ 1500rpm, 20-23deg @ 2300rpm, 27-30 @2800rpm
So with full vacuum and mechanical advance it can be pulling 42º of advance. I can't hear any pinging, but seems hard to imagine that so much advance would be necessary.
I'm also running dual carbs instead of FI. |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Mon Jul 10, 2017 4:08 pm Post subject: Re: Installed correct unbroken distributor... let's see how she runs |
danielheff wrote: |
That 42 degrees is only under a light load, where that much advance isn't harmful to the engine. Under a heavier load, the vacuum drops to almost zero, and advance is strictly mechanical.
This type of combination advance eliminates the throttle "flat spot" under partial acceleration.
All of this assumes your distributor is working as designed. Have you checked total advance with a strobe? _________________ 71 Elm Green FI A/T Squareback |
KTPhil Samba Member
Posted: Mon Jul 10, 2017 4:27 pm Post subject: Re: Installed correct unbroken distributor... let's see how she runs |
danielheff wrote: |
Hey just wondering your outcome of this new distributor? I'm thinking my distributor could be contributing to my engine running hot at high RPMS as well. |
It's running very well, thank you very much!
It doesn't have as much pep as with the extra advance, but it pulls SO much better from low rpm that it's faster overall, and a LOT easier to drive. It is smooth down to 1500 rpm under load, but still revs (eventually) to nearly 5000 (my personal redline).
Even though in theory the vacuum advance is ineffective at full throttle, I believe there was a footnote to that.
With my larger engine, and the slightly undersized runners, I think at high load and rpm, the vacuum advance was in fact pulling at least another 5 degrees, maybe more, on my old distributor.
I tried A-B comparisons, with and without the vac hose connected. With the hose, it pinged at high speeds and loads (like 75mph on the freeway, while passing at full throttle). Without it, it did not. I think this also contributed to the overheating from too much advance.
So with the non-broken mechanical advance, and the weaker (automatic) vacuum advance, my total advance is back where it belongs. No sign of pinging or overheating now. |
Posted: Thu Jul 13, 2017 10:10 am Post subject: Re: Installed correct unbroken distributor... let's see how she runs |
Glad its running better.
I had Tasb test and inspect my distributor and it's very close to factory spec. Vacuum can pulls exactly 12º and this is what he found for the mechanical advance:
Advance Specification RPM My Distributor
10-14 1500 15
20-23 2300 26
27-30 2800 31
I too have a larger engine and wonder if the vacuum can is making things worse at higher rpm. I have an 1835cc.
Is it possible for the engine to be pinging lightly? Or in a way that I can't hear it?
I had my carbs tuned professionally from a shop that hooked it up to the exhaust analyzer so I'm pretty sure my fuel/air mix is correct. Thats why I'm questioning the ignition now. It really only runs hotter on the fwy, especially climbing any kind of hill. |
KTPhil Samba Member
Posted: Thu Jul 13, 2017 11:31 am Post subject: Re: Installed correct unbroken distributor... let's see how she runs |
danielheff wrote: |
10-14 1500 15
20-23 2300 26
27-30 2800 31
That's a little high but not enough to cause problems, other than maybe at low rpm. Any chance you have wear in the distributor drive, or excessive crankshaft endplay?
danielheff wrote: |
I too have a larger engine and wonder if the vacuum can is making things worse at higher rpm. I have an 1835cc. |
Mine was 1776, so it's possible with your 1835.
danielheff wrote: |
Is it possible for the engine to be pinging lightly? Or in a way that I can't hear it? |
It was most obvious with my popout windows open, and driving in the fast lane next to a K-rail. On the open road with windows closed I was not hearing it.
danielheff wrote: |
Unless they have a dyno, they probably can't simulate high rpm combined with high load, which is when I was seeing too much advance. Or, if they installed a bung in the resonator and used a live A/F meter while driving under load they can do it. |
Posted: Thu Jul 13, 2017 12:50 pm Post subject: Re: Installed correct unbroken distributor... let's see how she runs |
I'm going to re-install the distributor soon after I get the cap & rotor back from Tasb. He installed a shim in the distributor to take up some slack. But the engine is pretty new. Around 2k miles on it.
Maybe I'll try plugging the vacuum can, but I really like the way it gives a little life to the lower RPM torque. Around town its awesome.
Right they didn't check the tuning under load.
Should I modify this mechanical advance to maybe only pull 28º and let the vacuum do the rest? Or is there a different distributor that will have a more agreeable advance curve? Maybe replacing the vacuum can to something meant for a bigger engine? |
Slow 1200 Samba Member
Posted: Mon Jul 17, 2017 4:00 am Post subject: Re: Installed correct unbroken distributor... let's see how she runs |
I'm assuming you are running stock PDSITs? which of them? if they are setup for vacuum only distributors they will pull vacuum at full throttle for sure |
Posted: Mon Jul 17, 2017 11:12 am Post subject: Re: Installed correct unbroken distributor... let's see how she runs |
Yes they're PDSIT's, re mfg by Bert. But since the engine is larger than stock I made the Venturi's 28mm and re-jetted to match.
Sorry for hi-jacking your thread Phil. |
