Joined: July 09, 2012 Posts: 5 Location: Ontario, Canada
Posted: Tue Jul 17, 2012 6:57 pm Post subject: 71 Campmobile - question |
Does anyone know if you can switch out the pop top with the hammock on a 71 Campmobile, for one with the double bed?
Not sure if there is a size difference or not? Just need the extra space for a growing family. |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Sun Jul 16, 2017 2:58 pm Post subject: Re: 71 Campmobile - question |
I seem to have a fuel leak just under my gas heater in our 71 campmobile. Is that my fuel filter just under the heater in this photo?
I am getting a steady drip of gas from the end of that wing nut and looking for some advice on how to fix it.
thanks everyone! |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Sun Jul 16, 2017 4:24 pm Post subject: Re: 71 Campmobile - question |
I think that is the fuel filter for the gas heater. The fuel pump for the heater is on top. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Sun Jul 16, 2017 4:51 pm Post subject: Re: 71 Campmobile - question |
Stop driving it until fixed.
Once you have identified the make of the heater , ask the mods to split your topic into anew thread on servicing your heater fuel supply _________________ .ssS! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jul 16, 2017 5:09 pm Post subject: Re: 71 Campmobile - question |
Try tightening the wing nut, if that fails you'll have to dismantle the strainer and replace the gasket. To do that you'll probably have to drain the fuel tank unless you have a hose pincher, it's probably time for all new rubber lines anyways. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ccowx Samba Member
Joined: May 15, 2015 Posts: 661 Location: Whitehorse Yukon
Posted: Mon Jul 17, 2017 12:45 pm Post subject: Re: 71 Campmobile - question |
That is an early BN4 heater and yes, that is your fuel filter. You can pinch the line to the heater from underneath. Above the transaxle you will see the fuel tank hose hookup. Likely there is a "Y" there and you can pinch it off with a set of vice grips or similar. Take the filter apart and replace the gasket, making sure to use something fuel and/or ethanol proof.
Chris |
Posted: Tue Aug 01, 2017 9:36 am Post subject: Re: 71 Campmobile - question |
ccowx wrote: |
Chris |
Thanks Chris, I will give that a try. So that cylinder with the wing nut at the bottom is the filter?
I'm wondering if there is an easy way to disconnect fuel to the BN4 heater all together? It works but is old and I don't really need it during the warm months that the bus is on the road.
thanks again! |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Tue Aug 01, 2017 1:52 pm Post subject: Re: 71 Campmobile - question |
Depending on who has done what there should be a Toronto in the fuel line. Trace the line back from the heater ,remove the TV and run the hose from the gas tank directly to the carbs or carb or filter... _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Posted: Tue Aug 01, 2017 4:15 pm Post subject: Re: 71 Campmobile - question |
pioneer1 wrote: |
Depending on who has done what there should be a Toronto in the fuel line. Trace the line back from the heater ,remove the TV and run the hose from the gas tank directly to the carbs or carb or filter... |
I see a Missassauga but no Toronto. _________________ .ssS! |
Posted: Tue Aug 01, 2017 4:35 pm Post subject: Re: 71 Campmobile - question |
Abscate wrote: |
pioneer1 wrote: |
I see a Missassauga but no Toronto. |
And what is Miss assauga doing? Oh wait... is that near London?, as in I see London, I see France, I see Missassauga's ......................?
Did you see that on TV?
I phones are nasty
Even if you don't use your heater it's best to run it every 6 months to keep the diaphragms wet with fresh gas. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Aug 01, 2017 6:02 pm Post subject: Re: 71 Campmobile - question |
Under where? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Tue Aug 01, 2017 6:40 pm Post subject: Re: 71 Campmobile - question |
On Tario _________________ .ssS! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Aug 01, 2017 8:27 pm Post subject: Re: 71 Campmobile - question |
Boy did this disintegrate fast. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
ccowx Samba Member
Posted: Tue Aug 01, 2017 11:40 pm Post subject: Re: 71 Campmobile - question |
In a no doubt vain attempt to bring some dignity to this thread, yes, the cylinder with the wing nut is a filter of sorts. More like a trap under your sink. I basically has a rubber o-ring on top and the wing nut holds it in place.
You can disconnect the fuel supply to the heater altogether by simply removing the t-fitting from the fuel line under the car and running one hose only to the fuel pump. Cap off the heater's fuel line as you see fit and you are done.
Chris |
Tcash Samba Member
Posted: Wed Aug 02, 2017 8:23 am Post subject: Re: 71 Campmobile - question |
The effort you would put forth to disconnect the heater fuel line, you could easily replace the bowl gasket.
If you ever plan to use it again.
busdaddy wrote: |
Even if you don't use your heater it's best to run it every 6 months to keep the diaphragms wet with fresh gas. |
Tcash
ps anyone know where to get a gasket. |
