chromecarz00 Samba Member
Posted: Fri Jul 21, 2017 3:20 pm Post subject: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
I've got an electric ignition system and an aftermarket filter on top. I just want to make sure i'm not missing anything on the carb. It won't idle right and lurches a bit, so I'm going through piece by piece and seeing why.
Thanks! |
Bama Dave Samba Member
Posted: Fri Jul 21, 2017 3:23 pm Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
Photos will help. Other engine specs will help. _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Fri Jul 21, 2017 4:30 pm Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
If you have a 34PICT-3 carb and all the vacuum ports are capped off, chances are that you have the 009 type centrifugal advance distributor.
This is a known poor performing combination. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Fri Jul 21, 2017 4:56 pm Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
Current thread that may interest you https://www.thesamba.com/vw/forum/viewtopic.php?t=683114&highlight= _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sat Jul 22, 2017 3:37 am Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
1600 single port. Keep forgetting I don't have that in my signature.
How can I tell if it's a 009? Can't see any writing on it |
Posted: Sat Jul 22, 2017 3:52 am Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
The serial number on it. _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Sat Jul 22, 2017 4:29 am Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
If the distributor has no numbers anywhere on the body, and has no vacuum canister, its more than likely an 009 type.
How do you have the timing set? Generally with an 009 you set the timing at around 28-30 degrees at full advance, and the idle timing falls where it wants to. The quality of the distributors varies wildly, as does the amount of advance, so you really need to use a timing light and actually measure the idle timing to see if its anywhere near suitable.
Single port engine never came with 34 pict 3 carburetors, so it would help to know the specific carburetor you have. Is it a Solex or aftermarket version, and is there a number stamped onto the side of the mounting flange? |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Jul 22, 2017 9:40 am Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
[quote="David_nc_72std"]If the distributor has no numbers anywhere on the body, and has no vacuum canister, its more than likely an 009 type[/quote]
I'll up that to "without a doubt". Adding that it is a Chinese clone. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Mon Jul 24, 2017 10:45 pm Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
I'm not sure where the timing is set, I took it to a mechanic who put all these parts in when I got it and haven't touched it yet. However, I put some fresh fuel and got tighter caps for the vaccuum lines and everything is working much better now.
I'm going to futz with the timing though as I feel it may have gone off slightly. Any pointers? |
Posted: Tue Jul 25, 2017 4:03 am Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
With an 009, set the timing at around 28-30 degrees at full advance, instead of at idle.
If you have a dual-port engine, check the left side casting where the intake splits, sometimes there is a vacuum port there, and if its plugged it might be leaking too.
Instead of the vacuum port plugs, I prefer actual vacuum line plugged on the end - a round-head screw with an unthreaded section, with the threads cut off, makes a nice plug, or solid aircraft-style rivets. Most vacuum plugs I've seen are rather thin material and don't seem to hold up well. |
Posted: Sun Jul 30, 2017 7:37 am Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
The "vinyl" looking vac caps hold up way better than the rubber ones. I just got done doing a quick initial repair on a 73 standard thats in the shop right now. Car wouldn't idle for crap. 3 of the caps were all cracked and leaking. After replacing the caps, adjusting the choke and tuning the carb, it runs great. Still need to get out my crank pulley template and make marks on the pulley for 28 and 32 degrees so I can properly set the timing. It looks close (about 10 degrees at idle), but max advance setting is what it needs. If you dont have a degreed pulle, but have a mark for TDC, you can download and print the template that is on here somewere or go to the "hot spark" website and download it from there. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Jul 30, 2017 7:45 am Post subject: Re: Looking at my Pict 34 carb and all of the vacuum hoses are cappe |
Here:
https://www.thesamba.com/vw/archives/manuals/degree_wheel.php _________________ Roads Scholar &
