Plumb1 Samba Member
Posted: Mon Jul 24, 2017 6:01 pm Post subject: Using the oil pressure relief for??? |
Can the oil pressure relief on the drivers side of the block be used to install the temp probe for a Bosch oil/water temperature gauge?
Thanks.. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9969 Location: Huntington Beach, CA
Posted: Mon Jul 24, 2017 10:55 pm Post subject: Re: Using the oil pressure relief for??? |
Hey!
What is your case number?
Why not use the original oil pressure location? You can install a T fitting there for additional accessories. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Plumb1 Samba Member
Posted: Tue Jul 25, 2017 2:50 am Post subject: Re: Using the oil pressure relief for??? |
Because there is already a tee there for the original sending unit and a bosch oil pressure gauge.
With the after market ignition and engine tin, the amount of room doesn't allow for that many brass fittings.
Will have to check on the case number. |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Tue Jul 25, 2017 3:33 am Post subject: Re: Using the oil pressure relief for??? |
Plumb1 wrote: |
Not sure about Bosch, but VDO makes a sender for that location. The thread size is M18 x 1.5. You may have to use an adapter for the Bosch sender. Some people don't like this location because there isn't full oil flow at that point, just what flows past the valve plunger.
http://vwparts.aircooled.net/VDO-300F-Oil-Temp-Sending-Unit-18-X-1-5mm-p/v323064.htm
The original pressure sender location is a fairly poor location for the temperature sender, especially with a T-fitting, because then you have practically no oil flow at the sender.
The other common location for a temperature sender is the oil drain plate, if you have the oil drain bolt in the center, thread size is M14 x 1.5. Best location, if you have an external oil filter, is somewhere in the oil line or oil filter bracket. |
Plumb1 Samba Member
Posted: Tue Jul 25, 2017 2:06 pm Post subject: Re: Using the oil pressure relief for??? |
Good advice David.
I had actually thought of utilizing that drain plug, only for the fact I would be afraid of running something over and the thermometer getting broken off.
But that be where she ends up |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Tue Jul 25, 2017 7:58 pm Post subject: Re: Using the oil pressure relief for??? |
This is not the best pic, but it was all I could find to illustrate possible spots for an oil temp sensor:
If you have a "universal case" you may have the T3 oil dip stick hole located at the red arrow. For Beetles, there will be a block off plate here. Drill and tap a hole and mount your temp sensor. This will represent the oil temp of the oil in the crank case. One thing to consider... the oil level in the crank case of a running acvw engine is almost zero. Ther is already so little oil in the engine, most of it is in motion while the engine is running at anything above idle. You want to mount your sensor as low as possible.
Even if you don't have a pre-drilled hole here you can drill and tap directly into the case if needed. Just make sure there isn't any interference with the engine tin.
An alternate (and possibly better) spot would be the round oil galley plug just to the left of the block off plate area. This is part of the oil galley and is the INLET to the oil pump. This guarantees you will have a flow of oil past the sensor. Again make sure you don't have clearance issues w/ engine tin in this location.
Personally, I don't like the idea of the oil drain plate sensor only because it is at the lowest point of the engine and reduces the ground clearance. But considering adding a deep sump would probably end up with even less ground clearance it is probably okay. It is other wise a very good spot because all the returning oil pools at the sump plate so you get the temp of the oil just as it has returned from around the engine. _________________ AshMan40
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Wed Jul 26, 2017 8:25 am Post subject: Re: Using the oil pressure relief for??? |
ashman40 wrote: |
Personally, I don't like the idea of the oil drain plate sensor only because it is at the lowest point of the engine and reduces the ground clearance. |
Yes, I did break off the Motometer temperature drain plug sender unit I had there, just knocked the end off, no oil leaked out. I ended up buying a VDO temperature sender to replace it, so no guarantee that my Motometer gauge still reads correct "number", but I only use that to check for differences/changes.
That broken Motometer sending unit? Being like many here who never throw anything away, that is now the drain plug for the rebuilt 1600cc engine in my 1970 !!! So it's back in the vehicle that I used with it in the 1970s !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Plumb1 Samba Member
Posted: Wed Jul 26, 2017 6:08 pm Post subject: Re: Using the oil pressure relief for??? |
Wow Ashman.
That is an awesome reply. Thanks for putting in the effort and energy to do that.
Pretty sure I can figure something out from that for sure.
Again, thanks. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Wed Jul 26, 2017 8:16 pm Post subject: Re: Using the oil pressure relief for??? |
Maybe the sender needs a prophylactic to keep it safe. _________________ www.vwnos.com [email protected]
Plumb1 Samba Member
Posted: Sun Jul 30, 2017 8:17 am Post subject: Re: Using the oil pressure relief for??? |
Have been super busy with work all week. This morning was the first opportunity I have had to even go in the shop.
The number stamped on the block is: AK170736
VW identified as 1973, US model.
Another website offers that the case is aftermarket. Not sure how that is possible. It is a 44 year old car, so anything is possible. |
