fifthcenturycheese Samba Member
Joined: May 04, 2014 Posts: 172 Location: Pismo Beach
Posted: Thu Jul 27, 2017 4:52 pm Post subject: Help identify Wolfsburg/Blaupunkt? Correct for 1964 type 1 ??? |
Hello, I purchased a 64 bug several years ago that came with a blaupunkt radio mounted in the dash by the original owners. I think they installed it in the late 80's or early 90's. It has a wolfsburg face plate but someone removed the id/serial number so I can't identify what model it is. It seems to operate well, just not sure if it is correct for my bug or if I can replace the knobs for a correct looking set up? It is also lacking the rubber seal that separates the face plate form the dash. Can you help id this radio and let me know what parts I might need to make it correct? Here are a couple pictures of the radio...thank you Mike
Last edited by fifthcenturycheese on Fri Jul 28, 2017 4:09 pm; edited 1 time in total |
bluebus86 Banned
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Fri Jul 28, 2017 9:04 am Post subject: Re: Help itentify Wolfsburg/Blaupunkt? Correct for 1964 type 1 ??? |
That looks like the model # on the sticker by the voltage change instructions: EVB 931 21C (??). Where it looks like something was scratched off may have been the serial number. What's on the red sticker under the wiring ..where it says GERMAN ...etc? Perhaps there's more info there? _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Jul 28, 2017 9:38 am Post subject: Re: Help itentify Wolfsburg/Blaupunkt? Correct for 1964 type 1 ??? |
"Correct" would be a block off plate. Radios & antennas for N. America were a dealer sold and installed item. If you had just payed off the last on your VW back in the day, you could then buy a radio with next months extra cash. Also dealers often added a radio to sweeten the used car deal.
Have early 1960s Blaupunkt literature on how to install the particular radio into a pre-1958 Beetle...
Knobs look like from other than VW make of automobile. Usually the push buttons would be same color as the dash knobs. So you might consider if you want to keep the face plate and sell or trade what you have for a radio with silver grey knobs _________________ In Stereo, Where Available! |
Posted: Fri Jul 28, 2017 9:41 am Post subject: Re: Help itentify Wolfsburg/Blaupunkt? Correct for 1964 type 1 ??? |
fifthcenturycheese wrote: |
It has a wolfsburg face plate but someone removed the id/serial number so I can't identify what model it is. |
Model is shown on the top sticker... _________________ In Stereo, Where Available!
wimkever Samba Member
Joined: July 16, 2004 Posts: 412 Location: Holland (the Netherlands)
Posted: Fri Jul 28, 2017 10:04 am Post subject: Re: Help itentify Wolfsburg/Blaupunkt? Correct for 1964 type 1 ??? |
Eric&Barb wrote: |
Model is show on the top sticker... |
That's right. On the sticker you can see the model name : "Frankfurt ATR US".
ATR = All Transistor, US means that it is a model for the USA.
This one is produced in the years 1963 and 1964. There was no rubber seal between the faceplate and the dash. _________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 879 Location: Lanark County, Ontario, Canada
Posted: Fri Jul 28, 2017 10:13 am Post subject: Re: Help itentify Wolfsburg/Blaupunkt? Correct for 1964 type 1 ??? |
With black volume and tuning knobs, this radio could be at home in a Canadian Custom, which has black dash knobs, and no chrome strip across the dash. (Note that this Wolfsburg faceplate does not have chrome strip extensions on the left and right edges, thus it breaks up the continuity of the Deluxe dash chrome strip) _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Posted: Fri Jul 28, 2017 10:23 am Post subject: Re: Help itentify Wolfsburg/Blaupunkt? Correct for 1964 type 1 ??? |
And yes, there was a rubber seal between the faceplate and the dash. It was a strip of grey or black rubber, round in cross-section, ends glued together, and glued into the perimeter channel on the back of the faceplate. They are quite often missing, probably because they fall off after the glue fails. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Posted: Sat Jul 29, 2017 10:10 pm Post subject: Re: Help identify Wolfsburg/Blaupunkt? Correct for 1964 type 1 ??? |
Thanks to everyone for the information on this post. As it turns out, I discovered a guy in New York that has parts for these, sells radios and refurbishes them. This is his website http://www.vintageblau.com/home.html He is pretty quick to email back and has dialed me in on the parts I need to complete this radio...give his site a look.
Mike |
