Kiwi1966 Samba Member
Joined: August 18, 2009 Posts: 168 Location: Ohoka New Zealand
Posted: Sun Jul 30, 2017 6:37 am Post subject: Seam sealer |
Just getting ready to seal up seams on front apron.Going to seal areas in red, can anybody advise if areas in blue seamsealed from factory Thanks Ross
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1544 Location: oregon
Posted: Sun Jul 30, 2017 8:09 am Post subject: Re: Seam sealer |
I'm not sure on the seam sealer but man that looks like nice work you're doing! _________________ 71 Westy 1600 DP, all stock Bus 1
1970's Snow Trac 1600 SP (sold 12/2016)
1968 Tucker sno cat, sold 2021
1969 Tucker Sno cat 542
2017 VW Alltrac
71 tin top stock 1600 DP (project but runs)
Twin 71 White Westy, Bus 2, that I pulled from a 15 year slumber in a dry eastern WA field in 2015.
1966 Sundial Camper "Boomer" |
Posted: Sun Jul 30, 2017 4:23 pm Post subject: Re: Seam sealer front apron |
Cheers for that , put a black 2 pack epoxy primer on and hoping someone can confirm if seam sealer was applied to the areas circled in blue |
busdaddy Samba Member
Posted: Sun Jul 30, 2017 6:01 pm Post subject: Re: Seam sealer |
Yes, all those seams were sealed. Early bay's had cleanish seams where it looked like someone actually stuck a finger in it, around 74 the bead changed to ~ 10mm wide and sitting on top with a rectangular profile, all were white and most seem to be applied after final paint and look like they just came out of the nozzle, they often crack off in large chunks as the heavy outer excess shrinks and debonds.
At least the later ones didn't look as messy as what was going on over at the Wolfsburg factory, late bugs have an incredible mess that looks like it was sprayed on from 6" away, all spattery and more than an inch wide, yuk. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jul 31, 2017 12:02 am Post subject: Re: Seam sealer |
Thanks Busdaddy for that info - going to tackle that seam sealer in the morning
Regards RossD |
