Vintage1966 Samba Member
Posted: Sun Jul 23, 2017 7:57 am Post subject: Bug Appears to be wired for positive ground |
Thanks for the add. I have a 66 bug with a 72 DP 1776. The battery cables are throwing me off. It has positive red cable & terminal clamp from the body ground to battery & black wire from positive to starter. Is this a positive grounded bug? I have it hooked up now negative to ground & positive to starter. It runs & lights, horn work but my generator light is on. Would the bug still start & work if the battery was hooked up backwards? It's been sitting for 2 years, I didn't get to take the old battery out. Old owner doesn't know about it |
vwjetboat Samba Member
Posted: Sun Jul 23, 2017 9:11 am Post subject: Re: Bug Appears to be wired for positive ground |
ignore the color of the wires.. no its not a positive ground bug.. someone bought cheap cables.. |
Posted: Sun Jul 23, 2017 9:49 am Post subject: Re: Bug Appears to be wired for positive ground |
vwjetboat wrote: |
Thank you |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun Jul 23, 2017 11:58 am Post subject: Re: Bug Appears to be wired for positive ground |
Ok now I'm confused.
Was the negative wire from the battery connected to the starter and the positive cable from the battery connected to the body of the car? If so, it was setup positive ground. It's been done before.
vwjetboat - He has a gen light illuminated on the dash on indicating it's not charging. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
DuaneL Samba Member
Joined: February 02, 2012 Posts: 511 Location: Spokane WA
Posted: Sun Jul 23, 2017 1:05 pm Post subject: Re: Bug Appears to be wired for positive ground |
this has come up a lot in the forums, but when some one does reverse the polarity of the bug it usually fries the voltage regulator. so replace vr maybe polarize the generator and you are good to go (and yes the bug would still start & work if the battery was hooked up backwards) _________________ ____________
1971 std bug, 1776, ACN Super Stock 34-3, dvda dist, 27x8.50 14 tires |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Sun Jul 23, 2017 2:14 pm Post subject: Re: Bug Appears to be wired for positive ground |
Vintage1966 wrote: |
Any color wire from positive battery terminal to starter is normal (negative ground). _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
gt1953 Samba Member
Posted: Mon Jul 24, 2017 6:49 am Post subject: Re: Bug Appears to be wired for positive ground |
What does the volt meter tell you when connected?? _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Mon Jul 24, 2017 10:57 pm Post subject: Re: Bug Appears to be wired for positive ground |
gt1953 wrote: |
What does the volt meter tell you when connected?? |
i don't own a volt meter yet. The wires were colored & set up positive ground & negative starter. I thought they must have used what they had so I hooked it up negative body & positive to starter. It starts & runs but have gen light on. No generator it's 12v / alternator.
. I tried to search forum but couldn't find an answe, sorry for duplicate questions
Wasn't sure if it would be obvious if it was hooked up backwards without actually doing it & messing anything up. |
Slow 1200 Samba Member
Posted: Tue Jul 25, 2017 4:53 am Post subject: Re: Bug Appears to be wired for positive ground |
for future reference, ground cables are brown on a vw, black are ignition-switched positive |
nsracing Samba Member
Posted: Mon Jul 31, 2017 3:36 am Post subject: Re: Bug Appears to be wired for positive ground |
Positive ground? WTF - |
