rusty busty Samba Member
Joined: May 27, 2015 Posts: 310 Location: Vancouver BC
Posted: Tue Aug 01, 2017 9:23 am Post subject: Funny wiring problems 78 bus |
Hear me laughing?
It seems that there are some wiring gremlins living in my bus.
Here's a run down of the issues so far
With light switch on and engine running the headlights don't come on, but front marker lights and taillights come on. When I press the horn button the headlights come on (but horn doesn't).
The right turn signal activates the turn signal light on the dash, but no lights on the outside of the vehicle. Left turn signal activates the horn (at least they'll hear me turning). Hazard lights don't work. All the dash warning lights seem to work except the oil light.
Under the dash I noticed that the hazard switch was in 2 pieces. I replaced it with a switch that is intact, but untested. The new old switch made no difference.
I've been staring at the wiring diagram and I can't see how the horn, headlights, and turn signal could cross paths unless someone has wired things incorrectly in the steering column or something. Any ideas before I rip apart the steering column and/or dash?
I'm going back to work on the bus today. I'll start by continuing to clean up all the grounds I can find. _________________ 1978 CEII Get-away hightop
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Aug 01, 2017 9:26 am Post subject: Re: Funny wiring problems 78 bus |
Grounds yes- once worked on Lauren's SAAB when the right window was rolled up- it stopped half way and the wipers took a pass.- was the master ground by the radiator mount. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Tue Aug 01, 2017 9:29 am Post subject: Re: Funny wiring problems 78 bus |
Oh I almost forgot. With the key turned forward the windshield wipers are on full time. Might not be an issue in the PNW but I'd like to travel to other places too. _________________ 1978 CEII Get-away hightop |
Posted: Tue Aug 01, 2017 9:34 am Post subject: Re: Funny wiring problems 78 bus |
williamM wrote: |
Grounds yes- once worked on Lauren's SAAB when the right window was rolled up- it stopped half way and the wipers took a pass.- was the master ground by the radiator mount. |
Yup I was thinking grounds too. But there's also evidence that someone was into the steering column in the past. _________________ 1978 CEII Get-away hightop |
Tcash Samba Member
Posted: Tue Aug 01, 2017 10:23 am Post subject: Re: Funny wiring problems 78 bus |
rusty busty wrote: |
Oh I almost forgot. With the key turned forward the windshield wipers are on full time. Might not be an issue in the PNW but I'd like to travel to other places too. |
Pull fuse #10 for the windshield wipers and see if your problems goes away.
If they do the problem is in the wiper circuit.
Good luck
Tcash |
Posted: Tue Aug 01, 2017 3:15 pm Post subject: Re: Funny wiring problems 78 bus |
Problem solved! The trouble was indeed the master ground by the radiator mount. _________________ 1978 CEII Get-away hightop |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Tue Aug 01, 2017 4:24 pm Post subject: Re: Funny wiring problems 78 bus |
Problem solved! The trouble was indeed the master ground by the radiator mount. |
Funny guy over here _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Aug 01, 2017 4:26 pm Post subject: Re: Funny wiring problems 78 bus |
Those damn radiators are trouble indeed
So did you fix it?, or does it persist?, has it always done it?, or is this new? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Tue Aug 01, 2017 4:31 pm Post subject: Re: Funny wiring problems 78 bus |
sjbartnik wrote: |
Funny guy over here |
that was awesome.
Did you actually solve the problem? Idk if you saw on my thread over here but I just went through the steering column and under dash wiring last summer. Learning to read the Bentley's wiring diagrams along with seeing it in real life and tracing things to where they are supposed to go...it makes you feel like the world's greatest detective. _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
Posted: Tue Aug 01, 2017 5:15 pm Post subject: Re: Funny wiring problems 78 bus |
busdaddy wrote: |
So did you fix it?, or does it persist?, has it always done it?, or is this new? |
Yes all electrical problems are now solved. I cleaned and put diabetic grease on all grounds, all light bulbs and light bulb sockets. The turn signals were fixed with a new relay.
It's a new problem for me but it may be a very old problem. This is the first time that the bus has run since the early 90's.
secretsubmariner wrote: |
sjbartnik wrote: |
that was awesome.
Did you actually solve the problem? Idk if you saw on my thread over here but I just went through the steering column and under dash wiring last summer. Learning to read the Bentley's wiring diagrams along with seeing it in real life and tracing things to where they are supposed to go...it makes you feel like the world's greatest detective. |
The bently diagrams aren't that bad, but then I didn't really need them it seems. Luckily I didn't have to change any wiring. Just take things apart, clean, then reconnect. Easy peasy _________________ 1978 CEII Get-away hightop |
Posted: Tue Aug 01, 2017 6:10 pm Post subject: Re: Funny wiring problems 78 bus |
Well I shouldn't say all electrical problems are solved. Still no oil light, the fuel gauge isn't working even though there's a new sender, and the brake light is on, although the whole brake system has been gone through with mostly new parts. The fun times continue. _________________ 1978 CEII Get-away hightop |
Tcash Samba Member
Posted: Tue Aug 01, 2017 6:53 pm Post subject: Re: Funny wiring problems 78 bus |
Gotta ask what was the deal with the windshield wipers? |
Posted: Wed Aug 02, 2017 1:32 am Post subject: Re: Funny wiring problems 78 bus |
Tcash wrote: |
I'm not exactly sure. I removed fuse 10 as you suggested. That stopped the wipers. I then proceeded to clean all the grounds. I also moved the plastic cover on the steering column aside and then disconnected and reconnected the wiring harnesses a couple of times. After I was done everything I put the fuse back in and everything works as it should. I now have 2 wiper speeds and the option to turn them off if I so desire. _________________ 1978 CEII Get-away hightop |
Tcash Samba Member
Posted: Wed Aug 02, 2017 8:45 am Post subject: Re: Funny wiring problems 78 bus |
Tcash wrote: |
I'm not exactly sure. I removed fuse 10 as you suggested. That stopped the wipers. I then proceeded to clean all the grounds. I also moved the plastic cover on the steering column aside and then disconnected and reconnected the wiring harnesses a couple of times. After I was done everything I put the fuse back in and everything works as it should. I now have 2 wiper speeds and the option to turn them off if I so desire. |
The switch only would only turn one click? Or would turn two clicks before?
Tcash |
Posted: Wed Aug 02, 2017 9:10 am Post subject: Re: Funny wiring problems 78 bus |
The switch would go into all 4 positions, high, low, off, and wash but no matter the position the switch was in the wipers were on high speed. Gremlins in the steering column is the only logical explanation. _________________ 1978 CEII Get-away hightop |
Posted: Fri Aug 11, 2017 9:13 pm Post subject: Re: Funny wiring problems 78 bus |
Well I though I was so smrt when I fixed all my troubles with emery cloth and diabolic grease but it seems obvious now that I'm missing something.
So the other day my wipers decided to work full time again. I'm on a road trip so didn't want to dig into it too much. I just pulled fuse 10 and figured if it rains then I'd just put the fuse back in and have wipers again. Well I've run into some weather in the past while so I went to put the fuse in and found that when it's wet out the wiper fuse just blows right away. After things dried out I tried again and we're back to full time wipers.
So when it's raining I have no wipers. When it's dry I have wipers that won't stop. Great. Sounds about right.
Also, today I crossed the border back into Canada and they searched the bus pretty hard. I think they messed up my electrics even more because now none of the interior lights work and neither does the ambulance fan. That stuff was all working 100% before the trained border monkeys and their dog tossed my bus. Grrr!
It was dark by the time I found out I don't have any lights of course so I'll have to look into that tomorrow. Fun times. _________________ 1978 CEII Get-away hightop |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Aug 11, 2017 10:01 pm Post subject: Re: Funny wiring problems 78 bus |
As the thread goes on I can't tell if this is the OP's problem. However, once or twice along the way I've had problem once or twice when I had the steering column wires undone. It is pretty easy to plug them back in a spot over on late Bays, so then they will do all sorts of crazy things. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Aug 11, 2017 10:59 pm Post subject: Re: Funny wiring problems 78 bus |
Oh gawd.
First thing is to rid yourself of all the diabolic diabetic grease.
You might decide to stop driving your bus and take ONE circuit at a time and map it. Ideal wire labels are sold at most decent hardware stores and big box places like Home Depot:
https://www.eslsupply.com/ideal-industries-44-104-...gJwWvD_BwE
Start by removing the steering wheel, then the instrument cluster. Set up a work light and get comfy in the driver's seat.
Do you know how to make a continuity tester?
https://www.youtube.com/watch?v=GuLqtGKAVu0
Disconnect your battery from the bus.
Start at Fuse 1 and clip one wire on the tester to the hot leg of the fuse holder. Take the other end of test wire and start touching all the things the Fuse 1 is supposed to provide current to. Every time the bell rings, make notes and label the wires right where they terminate. Check this against your wiring diagram.
Now make sure that circuit isn't providing current paths to anything else by touching the test lead to other things. Make notes, fix problems... one circuit at a time. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Fri Aug 11, 2017 11:22 pm Post subject: Re: Funny wiring problems 78 bus |
The windscreen wipers go strange if their earth wire is missing under the dash. There a should not be any water going in there.. Windshield seal has probably given up and letting water onto electrics and filling up relays..
My strangest one was when I set fire to my bus and in the aftermath some melted wiring in the engine bay shorted and it sounded like the horn went off in a half hearted way.
It was Ok I was driving it 2 days later..Fuel cutoff solenoid valve under tank worked. _________________ Ancient vehicles and vessels
Posted: Sat Aug 12, 2017 4:26 am Post subject: Re: Funny wiring problems 78 bus |
vwwestyman wrote: |
As the thread goes on I can't tell if this is the OP's problem. However, once or twice along the way I've had problem once or twice when I had the steering column wires undone. It is pretty easy to plug them back in a spot over on late Bays, so then they will do all sorts of crazy things. |
I'm pretty sure this is what the initial problem was. The PO had the steering column apart and put the wiring harness back together wrong. That's why horn = lights, turn signal = horn, etc. That stuff was solved when I unplugged the harness and inadvertently plugged it back in correctly.
I've put over 5000 km on my bus in the past week and except for the wipers everything worked correctly until the goon squad went through my bus yesterday. Now I'm living in the dark.
I'm now 5000 km from home and living in my bus for the next month or so. Not driving it isn't an option at the moment. In the next few days I should be able to take a day or 2 for maintenance and repairs. There's also a few non electrical issues I need to deal with.
I have a full set of tools including a multi meter with me. The main thing I've been lacking is time. I have a wedding to go to today which is why I've had to drive across the country in a bus that wasn't quite ready.
I do HVAC for a living so I'm not totally unfamiliar with low voltage control wiring. Automotive wiring makes my eyes glaze over sometimes. Maybe because I don't have all the circuits and colour codes memorized like I do with the HVAC stuff. One circuit at a time..
Yes the windshield seal badly needs to be replaced. That will happen this fall or winter for sure. _________________ 1978 CEII Get-away hightop |
