Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
Posted: Mon Aug 07, 2017 7:36 pm Post subject: Trav'ler Stove questions |
Hey guys I recently picked up an original Westy Trav'ler stove for my 72 that was not equipped with one from the factory. My original sink was missing so I decided to modify it so I could install this stove/fridge combo. Plan is to make this unit removable since I have a family of four.
Has anyone ever hooked up their stove to a 1lb green bottle? If so, do I need a regulator or just a simple adaptor?
Thanks guys. Oh and some pics.
_________________ Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Aug 07, 2017 7:47 pm Post subject: Re: Trav'ler Stove questions |
you will need a regulator _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1731 Location: Portland
Posted: Mon Aug 07, 2017 9:05 pm Post subject: Re: Trav'ler Stove questions |
The first time you turn it on without a regular is very interesting. Ask me how I know.
If you have any supply house with a fitting and regulator for the 1# bottle, you can get the threaded adaptor to the stove at Ace hardware that has a barbed house fitting. _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Tue Aug 08, 2017 6:09 am Post subject: Re: Trav'ler Stove questions |
You'll have better luck at a place like Ace Hardware (or other locally owned hardware store) than Home Depot finding what you need, and a much better chance finding someone working there who can help you put together the kit you need to hook up your small cylinder safely.
You'll need a regulator for the small bottle, hose from the regulator to the flexible metal line I see there, and an adapter connector between the two.
If possible, if I were you, I would see if you can remove the flexible metal line and hook up your new rubber line directly to where the metal line connected. _________________ Dave Cook
1973 Wild Westerner
My Thing |
danfromsyr Samba Member
Posted: Tue Aug 08, 2017 7:21 am Post subject: Re: Trav'ler Stove questions |
farm & fleet or Tractor supply often has a nice propane fitting rack.
you need one of these threaded into a propane BBQ regulator/hose assembly
it will replace the plastic tank adapter, it can be tough to remove, the inside of the plastic will accept a socket, the outside of the regulator will accept a crescent wrench. unscrew the old and screw on the new. USE THREAD SEALANT.
and ditch the metal corrugated line.
the fitting on the stove is 3/8 flare
Abscate wrote: |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Tue Aug 08, 2017 7:25 am Post subject: Re: Trav'ler Stove questions |
williamM wrote: |
you will need a regulator |
Define "need" - do you mean if you wish to continue living?
Good on OP for researching this first. _________________ .ssS! |
Posted: Fri Aug 11, 2017 2:04 pm Post subject: Re: Trav'ler Stove questions |
Abscate wrote: |
williamM wrote: |
Good on OP for researching this first. |
I always encourage independent thought and the chance to "Learn by doing"-- or not doing-- We studied Darwin in high school. _________________ some days I get up and just sit and think. Some days I just sit.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Aug 11, 2017 4:30 pm Post subject: Re: Trav'ler Stove questions |
williamM wrote: |
Abscate wrote: |
williamM wrote: |
I always encourage independent thought and the chance to "Learn by doing"-- or not doing-- We studied Darwin in high school. |
Eyebrows are over rated, who needs them? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Aug 12, 2017 6:05 am Post subject: Re: Trav'ler Stove questions |
Does Blazecut make a hat???- like birthday party balloons _________________ some days I get up and just sit and think. Some days I just sit.
