Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Aug 07, 2017 9:50 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Tcash wrote: |
Install the inner bearing and C-clip and see if the bearing outer race is walking in the housing. |
I did and it wasn't. The aftermarket new drum is the issue. See long post above. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Aug 07, 2017 10:03 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
skills@eurocarsplus wrote: |
the nut not pinching everything together is an issue. it could be the nut "snout" on the drum is incorrect, or the inner "snout" isn't deep enough.
basically, like the pipe idea the drum is nothing more than a spacer to pinch the bearing stack together...you just need to find where the deficit is...either the drum of the aftermarket spacer. sadly, you can't snake the big girl spacer out without removing the bearing.....and getting all covered in poop again |
Ya know, Skills, you're a jackass just like me and we've always despised each other but as it winds up I gotta say you actually called the problem on Page 1. Maybe you're not really as worthless as you are. Props. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Tcash Samba Member
Posted: Mon Aug 07, 2017 10:04 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Click on pic
Good luck
Tcash |
Posted: Mon Aug 07, 2017 10:09 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Tcash wrote: |
Click on pic
Good luck
Tcash |
Good tips for future reference, actually. Thanks! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Aug 07, 2017 10:20 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
I am having trouble figuring out what is going on here. You said that:
"If I drop the drum onto the stub axle sitting on the bench it drops on far enough that I can wind the nut on BY HAND to several turns beyond where I need it to be to get the full cotter key hole, so unfortunately that ain't it."
So it sounds like the new drum fits fine onto the axle shaft. Also when you assembled the stack outside the hub it sounds like the bearing was pressing against the inner spacer, yet for some reason when assembled in the hub the drum wasn't going all the way on and the race for the inner race for the outer bearing must not have been tight against the spacer.
Please tell me what I am missing here? |
Posted: Mon Aug 07, 2017 10:25 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Wildthings wrote: |
Old OEM used drum fits right with no play.
New aftermarket drum hides part of the cotter key hole and has play.
As to why? I'm beyond giving a shit at this point. An OEM used drum works. I'm going with what works. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
D/A/N Samba Member
Posted: Tue Aug 08, 2017 1:09 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Tram wrote: |
Wildthings wrote: |
As to why? I'm beyond giving a shit at this point. An OEM used drum works. I'm going with what works. |
Wait, this is assembled or not? On Saturday, there was play with both drums with everything in place on the bus. |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3897 Location: Seattle, WA
Posted: Tue Aug 08, 2017 8:53 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Well drat, it seems we are all left to speculate about the cause of the grossly excessive play when the axle nut is tight.
I can't see how any brake drum, whether new and badly made, or old and correct, can have any effect on that play, unless
it is jamming on the end of the splines on the stub shaft and not actually contacting the spacer.
It keeps being said that the inner ball bearing is not moving, because it had to be pressed in, but I've had to "press" in
inner bearings that moved easily in/out and rotated on its seat with finger pressure. Also, there are incorrectly made
snap rings being sold that are too thin, and allow axial movement. I got one from Bus Depot that was 1.5 mm thick
instead of the correct 2 mm. _________________ '67 bug: seized by the authorities
Posted: Tue Aug 08, 2017 9:55 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
D/A/N wrote: |
Tram wrote: |
Wildthings wrote: |
I have it temporarily assembled with the best of the used brake drums. Today I'll swap drums side to side but there are a few other things I want to get done first. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Tue Aug 08, 2017 10:09 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
kreemoweet wrote: |
instead of the correct 2 mm. |
So they can't even get the snap rings right now? Swell.
Yes, I know it's strange. Yes, I know it doesn't make a whole lotta sense. I really don't get it either. All I know is what I see with one drum to another plus the fact that, as I mentioned earlier, 95% of the "WTF?" VW problems I see are due to shitty replacement parts that just fail in utterly amazing ways.
There's still slight play with the used drum, but it's *almost* what I would consider "acceptable float", likely less than a mm. Could it be the snap ring issue you mention? Maybe. Thanks for that. But when I put on the new drum, I get a couple to a few mm play straight in and out just like what we started with. I switched between drums a couple times and the results were dead consistent.
Why does the new drum only go on as far as it does when it's assembled? You got me. No clue. As I said earlier when I had the bare stub on the bench, the drum dropped right on the splines and all the way down, no issue. Go fish. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
D/A/N Samba Member
Posted: Tue Aug 08, 2017 10:42 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Tram wrote: |
D/A/N wrote: |
Tram wrote: |
Wildthings wrote: |
I have it temporarily assembled with the best of the used brake drums. Today I'll swap drums side to side but there are a few other things I want to get done first. |
Well, if that solves it, I'm glad. I just don't get how on Saturday the used OEM drum made no difference and now it's the solution. Same used drum? |
Posted: Tue Aug 08, 2017 10:46 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
D/A/N wrote: |
Tram wrote: |
D/A/N wrote: |
Tram wrote: |
Wildthings wrote: |
Yes, but see above where I spent a copious amount of time cleaning/ polishing the new stub, then I put the stub in the freezer and heated the bearing with a heat gun to make it go together easier. It's possible I never had the stub quite all the way seated before.
Grasping at straws. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
neena Samba Member
Joined: September 10, 2010 Posts: 581 Location: Brooklyn, NY
Posted: Tue Aug 08, 2017 11:12 am Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Tram wrote: |
Grasping at straws. |
Gotcha. We plan to head back your way in a few hours and don't want to pack up the bus in anticipation of leaving and then unpack it on account of an issue yet again so if this isn't a semi-permanent to permanent fix, let us know!!
All the rubbing is gone too, right? |
Posted: Tue Aug 08, 2017 12:03 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
neena wrote: |
Tram wrote: |
Not yet! I still need to put the axle, etc. back on but before that I am going to pull it back apart quickly to check for any float on the inner bearing and mike the snap ring. Then we have the good pedal but doesn't want to stop issue to chase but I have a fairly solid idea what that is.
THEN we need to get the carb properly set.
Sorry, I'm just one guy with two hands! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
D/A/N Samba Member
Posted: Tue Aug 08, 2017 2:31 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
kreemoweet wrote: |
What did you do to make up the .5mm of slack? A shim? Or were you able to find the right snap ring? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51117 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Aug 08, 2017 2:54 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
Actually, no, but... really?
I replaced a master cylinder on a Type 3 a few months ago that had the identical issue and the rule has always been you don't touch the length of the push rod but that just ain't so anymore... even with new ATe cylinders. So, first thing I was going to check was for proper clearance at the rod.
Honestly, if I find that issue with the new shoes I think my VW days are over. They may be already anyways because I went back to double- check myself on the original issue of end float and yep, the inner bearing moves in and out just about 1/2 mm with my fingers even though I had to drive it in there with an appropriate large socket. Now I get to find out if the fucking snap ring is 0,5mm thinner than it should be like kreemoweet found, or if it's a new defective bearing.
I'm not going to bail on customers ACVW projects I already have in the queue, but I'm going to choke it off beyond that. I have to. I love these cars and I always will, and I'll always have a few around for myself, but this is a business decision. So far on this project I've dealt with splitting push rod tubes, three bad drums, two bad axle nuts, a bad rebuilt carburetor, shitty one- piece heater box to muffler clamps that just don't, shitty gaskets under the clamps, and now this. It's just no longer productive. When I can either work on on a Mercedes or a Porsche and get the correct parts that work right off and troubleshooting and diagnosis are straightforward or flail with this shit this ain't a good option. This is nothing against the owners and nothing against the Bus, but this is day 9 of dealing with new parts issues after the initial road test and I could have been banking $50/ 75 an hour plus 20% on parts working on other stuff during that time. Or I could have read a few good books for the same amount of revenue. If this was a Benz it would have been turn the key, road test it, inspect it, and gone.
I'm not in this for my health! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Tue Aug 08, 2017 3:43 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
So it's not just me then, I hear ya and feel the same way.
I've been working on some prewar MG's lately, it may take 4 hours+ to fit a new simple part (even if it's OEM) because every part on those cars is file to fit, put on/take off, file, shim, curse, repeat ......, I don't even try to estimate time on some jobs on those any more.
At least the customer understands and is willing to pay for the asspain, hard to find a VW owner like that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Tue Aug 08, 2017 3:59 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
here is a thread from another Samba forum with a similar kind of drum problem that I think Tram is describing. See the difference in height?
gestatin wrote: |
Here are a couple pics detailing the difference in height (or depth,if you prefer) of the splined section of the drums. Part numbers are correct for 64-67 bus. What I do find interesting though is that the part number and "VW" are different sized font. Also the swirly ribs are different sizes with one drum being noticeably larger.
Anyway, I've got them shimmed right now so the axle nut shows two threads or so on the outboard side.Hubcaps are still a bit close to the stub axle and are actually (barely) touching. The drums feel well centered and do not rub on the shoes.
Insights? Here's the pics:
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Aug 08, 2017 4:13 pm Post subject: Re: Stub axle/bearing woes on a 70 Riviera |
busdaddy wrote: |
At least the customer understands and is willing to pay for the asspain, hard to find a VW owner like that. |
Exactly. And it isn't that the VW owner is even "cheap" so much as it is "What? I never had to pay for this/ do this before! You sure you know what you're doing here? I think you're taking me to the cleaners!"
On the prewar Brit stuff, YOU know what to expect and the CUSTOMER knows what to expect because it's always been like this. But it's never been LIKE THIS on ACVWs before. I never know what to expect and I always feel like a beginner now because the shittiness of the parts is constantly moving the cheese. It's tough to make consistent cream out of shit when you're always getting shittier shit. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
