limon Samba Member
Joined: September 05, 2013 Posts: 45 Location: United States
Posted: Wed Aug 09, 2017 4:49 pm Post subject: Bolt On Sand Seal |
I just finished installing an EMPI pulley and sand seal kit; instructions said to use #9118 Crank Bolt and Washer. I bought that too, but it stuck out about 1/16" of an inch after torquing it down. I reused the bolt that was on the engine, and it looks much better now. 30mm Kobalt socket was $6 at Lowes.
Posted: Wed Aug 09, 2017 5:56 pm Post subject: Re: Bolt On Sand Seal |
You want to have 5 threads or so screwed into the end of the crankshaft. Maybe add an additional grade 8 washer under the head of the longer bolt, and/or grind a thread or two off of it. |
limon Samba Member
Posted: Wed Aug 09, 2017 7:15 pm Post subject: Re: Bolt On Sand Seal |
Thanks Wildthings. I didn't count how many threads are seated - if it's not enough - I'll "Stack" both washers on the longer bolt. |
Posted: Thu Aug 10, 2017 5:35 pm Post subject: Re: Bolt On Sand Seal |
limon wrote: |
You just want to be 100% sure that the bolt doesn't bottom out in the hole. It also looks like one of your washers is concave, if you use two washer think carefully about which one to use where. |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Aug 14, 2017 4:24 am Post subject: Re: Bolt On Sand Seal |
You need that longer bolt due to the shim that goes between the crank and pulley. Without it the pulley with bottom out on the seal and destroy itself. |
