EmpiGT Samba Member
Posted: Tue Jul 18, 2017 12:01 pm Post subject: Re: 1952 Deluxe |
Did your bus not come equipped with the upper corner supports in the rear? I heard of some early deluxes without them. But most I've seen do. Trying to figure out the quirks to these early ones. Bus is looking great! |
DSweinhagen Samba Member
Joined: July 30, 2002 Posts: 382 Location: Phoenix, AZ
Posted: Tue Jul 18, 2017 4:15 pm Post subject: Re: 1952 Deluxe |
EmpiGT wrote: |
Thanks. Not my bus but a customers. I'm not sure what you mean by corner supports. Are you talking about the pieces in the picture below. I've never really known what to call them but Everett is calling them speaker brackets in his description... If that's it, No, this bus doesn't have them.
_________________ David S |
Posted: Wed Jul 19, 2017 12:34 pm Post subject: Re: 1952 Deluxe |
Here's a pic of the upper inside corner...
The front floor is all there but pretty rough. It had a bunch of those screwdriver-punched holes which distorted areas and then some pretty heavy pitting. This is another area I started on years ago, welding up the holes, straightening it out and lightly body working it. Since it had been a while I had the blaster strip it again while it was there. The center section was the worst, and I ended up grabbing that piece from Gerson at OCTO and replacing a section of it. It really helped straighten to the floor, then spent a little more time straightening out the other pieces and filling the pitting.
Posted: Thu Aug 10, 2017 9:19 am Post subject: Re: 1952 Deluxe |
I noticed the door gaps just slightly changed while on the dolly, so I reinstalled the front and rear axles before finishing the welding.
The nose is welded back on, body-worked and primed...
type241 Samba Member
Joined: June 02, 2006 Posts: 972 Location: MOSES LAKE, WA
Posted: Thu Aug 10, 2017 10:03 am Post subject: Re: 1952 Deluxe |
Are the four holes in the corner where the speaker bracket was welded?
RockStock Samba Member
Joined: November 26, 2004 Posts: 3924 Location: England
Posted: Fri Aug 11, 2017 1:22 am Post subject: Re: 1952 Deluxe |
The earliest deluxe we have confirmed as having the speaker pods fitted is a Sept 52.
https://www.thesamba.com/vw/forum/viewtopic.php?t=344969
This bus is a Feb 52, I think.
From memory the speaker pods on my 55 are each spotwelded around 10-20 times along that inner gutter tray area. The pods are fitted inside that gutter tray edge. Removal is arduous.
Maybe the early pods (meaning pre-52/deep skylight) used much fewer spotwelds. They could even have been fitted on the 'outside' of that gutter tray edge, making removal much easier.
The 4 holes in the above picture are in exactly the right place to be drilled pod spotwelds. And talking generally, the factory gutter tray doesnt have any holes in it elsewhere.
So, either the really early deluxes didnt have them fitted...or they have been removed. Not much help, am I _________________ -StockRocks- |
Lazaa Samba Member
Joined: January 03, 2011 Posts: 228 Location: Voiron, France
Posted: Fri Aug 11, 2017 2:31 am Post subject: Re: 1952 Deluxe |
RockStock wrote: |
The earliest deluxe we have confirmed as having the speaker pods fitted is a Sept 52. |
Mine is very late june 52 (29559, left factory early july) and he has the pods. |
Posted: Fri Aug 11, 2017 3:06 am Post subject: Re: 1952 Deluxe |
Do you have a picture?
Fitted inside or outside the gutter tray?
How many spotwelds?
My money would be on the pods being fitted to all deluxes from the start. _________________ -StockRocks- |
Lazaa Samba Member
Posted: Fri Aug 11, 2017 3:33 am Post subject: Re: 1952 Deluxe |
Mines are the smooth version fitted inside the gutter with 4 screws on the approx. same locations of the holes of the previous picture posted here. No weldings !
Maybe the first ones were installed that way on order ?
Also mines have 4 holes to hold the speaker, against 3 holes on all the other pictures posted before.
They have been in used, there is still the speaker cables going through the small folding tab. |
Hellberg Samba Member
Posted: Fri Aug 11, 2017 7:43 am Post subject: Re: 1952 Deluxe |
Thanks for the info guys. I didn't think those holes were related to the speaker brackets but sounds like it's possible if they were just screwed in. This bus had so many holes drilled in it I just figured they were more of the same. I looked at my '54 deluxe and like RS mentioned, there's a lot of spot welds. Other than the four holes, there's no other sign of spot welds or remnants of them on the backside. Anyone have pictures of the '52 style ones? _________________ David S |
Posted: Fri Aug 11, 2017 7:44 am Post subject: Re: 1952 Deluxe |
Hellberg wrote: |
amazing! |
Thanks, I thought the repair of your truck was amazing. _________________ David S |
Lazaa Samba Member
Posted: Fri Aug 11, 2017 8:19 am Post subject: Re: 1952 Deluxe |
DSweinhagen wrote: |
Anyone have pictures of the '52 style ones? |
This is my june 52 with the screwed pods.
It's a little dark but i think you can see the screws anyway
Posted: Fri Aug 11, 2017 10:03 am Post subject: Re: 1952 Deluxe |
Good stuff. Good proof. They look like engine tinware screws. You'd imagine the speaker pod would have 4 weldnuts attached. _________________ -StockRocks- |
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 878 Location: Cornwall, UK
Posted: Fri Aug 11, 2017 12:32 pm Post subject: Re: 1952 Deluxe |
Yep. I have the same bolt on type on my June 52. _________________ 1951 Samba 20-017894
1952 Samba 20-028952 |
Posted: Sat Aug 12, 2017 8:05 am Post subject: Re: 1952 Deluxe |
Thanks for the picture Florian. Looks likely that's what was on this bus. The holes are large so something like a 6mm screw would make sense. I guess I won't weld those up for now. _________________ David S |
Posted: Wed Aug 16, 2017 10:06 am Post subject: Re: 1952 Deluxe |
Right cargo floor section is welded in...
Pinetops Samba Member
Posted: Tue Sep 05, 2017 9:08 pm Post subject: Re: 1952 Deluxe |
Incredible work, I just went through the thread for the first time. _________________ "A rolling bus gathers no rust." |
Posted: Wed Sep 13, 2017 11:18 am Post subject: Re: 1952 Deluxe |
Pinetops wrote: |
Incredible work, I just went through the thread for the first time. |
Thanks!!
I installed a new heater tube insulation and finished welding in the cargo floor. Sprayed epoxy primer and some filler primer, but kept the filler primer off the areas where I still need to weld in the seat brackets and plates. I'll weld those in and go over it once more...
flat59 Samba Member
Posted: Thu Sep 14, 2017 4:29 am Post subject: Re: 1952 Deluxe |
Damm!!
Nice job dude |
