Need help with mystery engine miss
Page: 1, 2, 3  Next
fifteenduth
fifteenduth is offline
PostPosted: Fri Aug 11, 2017 1:39 pm    Post subject: Need help with mystery engine miss Reply with quote
Mysterious engine miss shows up after running very well for all summer. So this is the data I have;
- 74 Westy, mostly stock
- stock Solex dual carbs, stock muffler
- ACN SVDA dizzy, with Computronix ignition
- 60,000 miles on original engine
On a trip with my son for a few days a couple weeks ago, we noticed a rough idle after filling up at a remote gas station with premium (91 octane) plus I add Lucas Octane Booster to each tank. Wasn't sure if I got bad gas maybe so topped up tank on the way home.
Limped it home with a couple stops to check plug wires, possible vacuum leak...
Got home and found the vacuum booster check valve connection with the line had come off so reconnected and thought I had found the issue. It was a bit better but still a miss. We had driven some rough roads so thought I would check timing. Before that I thought I would see if there was a specific cylinder that was the culprit and found that when I pulled #3 wire there was no change in engine idle. Hmm... I thought. Maybe bad plug or bad plug wire? Pulled all plugs and no issues but replaced with new. Checked wires, all good, replaced anyways since I had a spare set. Replaced dizzy cap with good clean spare I had and cleaned rotor. No improvement. So I'm sitting behind the engine (back is back!) as it is idling and I'm watching sparks jumping from the two coil terminals to the tower on the coil where the main wire is connected. Hmmm....thinking bad coil. So change coil from Bosch Blue that I've been running since 2009 back to original coil. No improvement.
- when I pull the #3 plug wire, I get a good spark and the engine idle does not change but when I put it back, there's a popping in the exhaust, like a vacuum leak would produce, but I can't find a vacuum leak.
Hmmm... What next? Checked timing....right on, all good. Inspected guts in dizzy and no indication of problems. Check fuel cut off solenoid. No problem.
Hmm.... so now I'm thinking of getting out the incense sticks to look deeper for a vacuum leak and also checking my #3 valve clearances, which were fine last tune up.
Can anyone think of something I may have missed here?
She's been running great since I got her back in 2009 and I have had a couple issues related to vacuum leaks which I have been able to isolate and solve but this is mystifying.
Thanks in advance for any help.
Ronnie C
'74 Westy - "Josée"
2014 Beetle GSR - "Ozzy"
2006 Jetta TDI - "Jerry"
[email protected]
Samba Peckerhead
PostPosted: Fri Aug 11, 2017 2:18 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
sounds like a possible plugged jet by your description.
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
fifteenduth
PostPosted: Fri Aug 11, 2017 2:26 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
So if it's a plugged jet why would the issue only be #3 and not #4 cylinder too? This is the struggle I'm having with fuel delivery since both cylinders are fuelled by the same carb.
'74 Westy - "Josée"
[email protected]
Samba Peckerhead
PostPosted: Fri Aug 11, 2017 2:35 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
a quick and dirty test is to start the bus, CAREFULLY fog/dribble some carb clean into the carb. if it smooths out, I would suspect the carb or a vac leak
Jake Raby wrote:
Brian wrote:
SGKent Premium Member
SGKent is offline
PostPosted: Fri Aug 11, 2017 2:40 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
You need to do a better explanation on this statement above. Where the wires plugged in or is this when you were pulling then to listen for an idle change? If they were plugged in and the sparks were going from the center coil to where the wires plug in, you have a bad cap and rotor. Replace both with genuine Bosch ones. Plan on replacing the wires too. If you were testing when this was happening please clarify your statement to reflect that.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing it right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
Bus Engine Cooling Issues? https://kentcomputer.com/77VW/BusEngineCooling.pdf
Starbucket
Starbucket is offline
PostPosted: Fri Aug 11, 2017 2:55 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
Check the valve clearance, you probably got a chunk of carbon stuck on a valve seat or you burned a valve. Do a compression test.
Wildthings
Wildthings is offline
PostPosted: Fri Aug 11, 2017 3:06 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
Yes he may have a burned up resister strip on the rotor or a bad center button on the cap. A careful visual check should show this.
He should do a quick and dirty compression test as well, but turning the warm engine over two complete turns by hand and seeing if the compression feels the same on all four cylinders. If not he may have a bad valve or a ring problem on #3.
fifteenduth
PostPosted: Fri Aug 11, 2017 3:29 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
Thanks for the replies.
I forgot to say that I did a compression test on #3 and it was fine (~110 PSI).
SGKent - what I saw was arcing between the negative and positive posts of the coil and the centre post of the coil. Assumed the centre post of my coil was cracked but can't see any sign of crack with naked eye. Also when this happened I realized the #3 plug wire was not connected to the spark plug. Not sure if that means anything with respect to what I was seeing. Hope that clarifies my statement.
Bosch wires, and cap were the replacement. Using NGK BP5E plugs
'74 Westy - "Josée"
Tcash
Tcash is offline
PostPosted: Fri Aug 11, 2017 3:51 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
Ignition High Tension Leaks
busdaddy
busdaddy is offline
PostPosted: Fri Aug 11, 2017 4:26 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
fifteenduth wrote:
......Got home and found the vacuum booster check valve connection with the line had come off .....
How long was the drive home?
Was that compression test performed hot?, or semi cool?
Time for a valve adjustment I suspect.
SGKent is offline
PostPosted: Fri Aug 11, 2017 4:37 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
you have some exceptionally high voltage there. I have never seen a coil arc from the center to the negative. My first thought would be failing insulation on the plug wires at that point. I'd go for a new set of wires, regap the plugs and replace the rotor and cap with genuine Bosch ones. If you have points and a condenser replace both.
fifteenduth
PostPosted: Sat Aug 12, 2017 9:40 am    Post subject: Re: Need help with mystery engine miss Reply with quote
Thanks again for more replies.
Busdaddy - the drive home from when I first noticed the rough idle, while stopped in construction zone, was about 400 kms or 250 miles. Compression test was done semi-warm I'd say, if I remember correctly. And I agree that valve adjustment should be next step. May be able to get to it today.
SG - I've never seen that arcing either. I was kinda shocked!!! Pun intended!! Gotta keep a smile through all this, eh? I did change out the Bosch Blue coil to the original Bosch coil and I changed and gapped new plugs, new Bosch wires, cleaned rotor but didn't replace. The arcing was not present after changing coil. I'm running Computronix ignition which has been running great since installed a few years ago. Not sure if something can go wrong with components of that unit but I may check with John at ACN about that since I got it from him. I thought about switching back to points and condenser as a test since I carry a set with me always anyways.
Again the puzzle for me is why it's isolated to only one cylinder, which is making me think it's a valve problem at that cylinder. I thought if it was a stuck valve I'd have harder starts and that's not the case, nor have I noticed a significant power loss.
Thanks folks.
Ronnie C
'74 Westy - "Josée"
fifteenduth
PostPosted: Sat Aug 12, 2017 9:55 am    Post subject: Re: Need help with mystery engine miss Reply with quote
Also I did replace the cap with my original one, well the last one I had put on before switching to the SVDA dizzy a few years ago. Obviously cleaned the contacts prior to installing.
'74 Westy - "Josée"
Tcash
Tcash is offline
PostPosted: Sat Aug 12, 2017 3:06 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
What where the results of this test. Even if you can't see the crack with the neked eye. This test will reveal a crack.
Move #3 spark plug wire and see if the problem moves.
Then move the spark plug.
Good luck
Tcash
fifteenduth
PostPosted: Sat Aug 12, 2017 3:47 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
Didn't do the test, since I replaced coil, but will include on my list of tasks as I continue troubleshooting. I'll reinstall the coil in question and run the test.
Thanks,
Ronnie C
'74 Westy - "Josée"
fifteenduth
PostPosted: Tue Aug 15, 2017 10:55 pm    Post subject: Re: Need help with mystery engine miss Reply with quote
So I checked #3 valve clearance and all ok. I'm down to my last troubleshoot idea of going back to points, assuming my Computronix has an issue. I would welcome any other ideas.
'74 Westy - "Josée"
Wildthings
PostPosted: Wed Aug 16, 2017 3:20 am    Post subject: Re: Need help with mystery engine miss Reply with quote
Buying the premium gas in a remote location may have caused your problems. The stuff may have been sitting in the tank with water on the bottom for months. You may have ended up with a tank of watery ethanol and not gas. If you haven't done so yet try some FI cleaner in the fuel and see if that will clear things up. I have found with old alcohol laced fuel that I sometimes have to remove the jets and use a toothpick to break the crud caused by the gasohol loose. I have had to do this with both main and idle jets.
Starbucket
PostPosted: Wed Aug 16, 2017 6:32 am    Post subject: Re: Need help with mystery engine miss Reply with quote
Try sticking the fuel pump pick up hose in a can of fresh gas and if it starts to run well, drain and refill your tank.
fifteenduth
PostPosted: Wed Aug 16, 2017 6:47 am    Post subject: Re: Need help with mystery engine miss Reply with quote
Thanks. The fuel question has been in my mind the whole time, but again, why isn't #4 affected when it is fed fuel by the left carb just like #3? I have added some Sea Foam magic potion Laughing but have not driven far since so maybe I will go and fill up today with fresh fuel and drive a bit to see if it will clear up.
If I go back to points, or try my Pertronix that is still in the box from several years ago, and it doesn't fix it I will have tried everything I can think of and then the sad face will show up.
'74 Westy - "Josée"
SGKent is offline
PostPosted: Wed Aug 16, 2017 7:07 am    Post subject: Re: Need help with mystery engine miss Reply with quote
tonight go out to the bus at dark and start it. There is a good chance that in the dark you will see sparking and halos on the wires. be careful of the fan belt in the dark.
Page: 1, 2, 3  Next
