Opinions on 52 Split Found
txoval
txoval is offline
PostPosted: Fri Aug 04, 2017 5:41 am    Post subject: Opinions on 52 Split Found Reply with quote
As you can tell from my username, I am more experienced with Ovals.
I recently came across this Split. Supposed to be a 1952 with Crotch Coolers, recently imported to the US. I have not seen it in person, so I cannot comment on rust or metal condition, but from the pictures, it appears mostly complete (rims/bumpers?). Supposedly the original engine, transmission, pan, etc
What is this car worth (range) in the real world...
pastellgreen
pastellgreen is offline
PostPosted: Fri Aug 04, 2017 5:52 am    Post subject: Re: Opinions on 52 Split Found Reply with quote
nice and very complete car with much original parts
Mark Evans Premium Member
Mark Evans is offline
PostPosted: Fri Aug 04, 2017 8:02 am    Post subject: Re: Opinions on 52 Split Found Reply with quote
Jump on that!
'55 Ragtop,'63 Ragtop,'68 Riviera
splitjunkie
splitjunkie is offline
PostPosted: Fri Aug 04, 2017 8:09 am    Post subject: Re: Opinions on 52 Split Found Reply with quote
Damn!
Yes wheels and bumpers are wrong.
Looks to be missing the semaphores as well.
The engine looks mostly correct. The manifold is the later replacement 25hp manifold. The coil may be correct. I believe that they switched to that style coil during the '52 crotch cooler model run.
Not sure if the upholstery is original. Almost looks like a corduroy type of material.
If the car is solid it would be a great find.
Not sure on the price. I haven't really been keeping up with that but the missing wheels, bumpers and semaphores do diminish the value and should be used as a negotiating point.
Chris
joey1320
joey1320 is offline
PostPosted: Fri Aug 04, 2017 8:17 am    Post subject: Re: Opinions on 52 Split Found Reply with quote
Nice find. Buy it Wink
**1971 Super Project
**My VW YouTube Channel - AirCooled-Tech
https://www.youtube.com/channel/UCcaFyFZRSq6BrR8_MO6va8Q
splitjunkie
PostPosted: Fri Aug 04, 2017 8:22 am    Post subject: Re: Opinions on 52 Split Found Reply with quote
I would look everything over very closely. If the seats have been redone then the car might have been restored at some point. Make sure the fenders are original split fenders and not later fenders. Split fenders have a slightly larger wheel opening. The rears with have the reinforcment pressings between the mounting bolts and there will be a dimple for mounting the tail lights.
Chris
Mr. OGPaint Premium Member
Mr. OGPaint is offline
PostPosted: Fri Aug 04, 2017 11:13 pm    Post subject: Re: Opinions on 52 Split Found Reply with quote
Looks interesting and definitely worth a closer look. Seats look like they could be the later style thin stripped steifenbraun. Approx late 51 thru 52 pre zwitter material
https://instagram.com/mr_ogpaint
Patrick Hall
Pez
Pez is offline
PostPosted: Sat Aug 12, 2017 8:01 pm    Post subject: Re: Opinions on 52 Split Found Reply with quote
Any news or updates on your potential Split?
Tom
1974 Super Beetle
splitjunkie
PostPosted: Sun Aug 13, 2017 7:19 am    Post subject: Re: Opinions on 52 Split Found Reply with quote
There's a guy in New York who says a project split should only be a couple of thousand dollars.... Rolling Eyes
Seriously I hope you are able to get it if it checks out.
Chris
kokanee
kokanee is offline
PostPosted: Wed Aug 23, 2017 3:43 pm    Post subject: Re: Opinions on 52 Split Found Reply with quote
It's not og paint they didn't use clear back then
johnshenry Premium Member
johnshenry is offline
PostPosted: Thu Aug 24, 2017 5:13 pm    Post subject: Re: Opinions on 52 Split Found Reply with quote
Definitely enough details in the pics to make me want to go look at it. What splitjunkie said, check those things. Stab the bottom of the heater channels with the blunt end of a plastic pen. They rust from the inside out. May look "solid" but be paper thin. Sems are ea$y to get, real split fenders not so much, but that wouldn't keep you from enjoying the car. Same with wheels/rims.
Let us know what the $eller is thinking....
John Henry
'57 Deluxe
'51 11E Standard Sunroof (PhotoBucket resto pics)
Retrovan
Retrovan is offline
PostPosted: Fri Aug 25, 2017 6:05 am    Post subject: Re: Opinions on 52 Split Found Reply with quote
Take it, nothing there that can not be replaced or fixed.
Within the near future these cars will all be snapped up, and you may regret not taking it.
What ever you overpaying for it now, will have been absorbed by inflation by the time you have it on the road.
Enjoy
Herman
1968 Fastback Type 4 2 Lt. twin 34 ICT's (Red)
1952 Split Beetle 1835cc. twin 34 ICT's (Azur blue)
1975 Split Bus Type 4 1914cc. twin 34 ICT's (wh/aqua)
1972 Bay Panel-van with type 4 2 Lt. twin 34 ICT's (white)
