Type 3 Truck - the "other" vw
Page: Previous  1, 2, 3 ... 75, 76, 77, 78, 79, 80  Next
dc
dc is offline
PostPosted: Mon Aug 07, 2017 5:33 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
This were the Spring-Loaded tubes- hoping it is not TOO big a deal to fix Shocked
As far as the aircleaner bracket goes: A bit of research shows the I'm missing the bracket UNDER the bracket that I already have Confused It's the one that doubles as a support for the balance tube and turns 90 degrees for the aircleaner bracket Question Exclamation
Jason? I know you're close to this stage with your motor-- got an extra?
Joel?
ISP?
Bueller? Wink
1964 Type 3 Truck
dc
dc is offline
PostPosted: Mon Aug 07, 2017 6:33 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Ok - climbed under the car and discovered the oil leak source(s)
Look- #3 is split and the other look deformed or squished with sealant.
Hope to pull lower tin and get at this problem...
Other side is totally dry and sealed with the same style of collapsible tubes
1964 Type 3 Truck
Mike Fisher
Mike Fisher is offline
PostPosted: Mon Aug 07, 2017 8:06 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Tram just had to replace a split/leaking New solid pushrod tube on Dan & Neena's Bus.
http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
MonT3
MonT3 is offline
PostPosted: Mon Aug 07, 2017 8:29 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Glad you made it home. One thing, check your accelerator cable against the back tin piece as it looks to be rubbing against the cable outlet piece. May be bent a little.
MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild
dc
dc is offline
PostPosted: Mon Aug 07, 2017 9:00 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Good catch - I thought was supposed to be at an angle- wasn't sure.
Just grab with pliers and bend?
1964 Type 3 Truck
MonT3
MonT3 is offline
PostPosted: Mon Aug 07, 2017 10:27 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Maybe lite taps with a rubber mallet to get it where you want it.
MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild
Bobnotch
Bobnotch is offline
PostPosted: Tue Aug 08, 2017 10:05 am    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
What pushrod tubes are those? I'm used to seeing a bellows on the ends (stock). I'm wondering if those are set up too long.
Bob 65 Notch S with Sunroof
mark tucker wrote:
dont the youthinasisa make all our vw stuff? Shocked
Tram wrote:
dc
dc is offline
PostPosted: Tue Aug 08, 2017 10:35 am    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
The springs are just out of sight to the left - they are the two part collapsible tubes - not solid
1964 Type 3 Truck
dc
dc is offline
PostPosted: Tue Aug 08, 2017 8:33 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Here's the piece I'm missing to make the air-cleaner work:
Anyone out there have this part?
1964 Type 3 Truck
dc
dc is offline
PostPosted: Sat Aug 12, 2017 10:19 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Got that bracket - thanks to Joel Very Happy
So the air cleaner assembly is all back to stock - this makes me happy Very Happy
Tomorrow - I plan to change the oil (break-in procedures) stop some leaky pushrod tubes and dial in the state of tune Cool
1964 Type 3 Truck
dc
dc is offline
PostPosted: Sun Aug 13, 2017 2:19 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
For my notes:
14828 - Car comes home (likely installed with 18425)
14836 - Top off gas tank (gauge is not working - touchy wire)
14850 - Changed to Stock Aircleaner and Changed oil (some minor metal filings typical for break-in or so I've been told)
Next break-in oil change and set valves-
15125 (300 from new)
I may change the oil again before 300.
1964 Type 3 Truck
dc
dc is offline
PostPosted: Wed Aug 23, 2017 4:21 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Out driving around today - School starts up on September 6th so I went by to get some work done on setting up my classroom Confused
Our site is under construction - we are getting a massive remodel / new facility Very Happy
Truck is running well.. still leaking a fair amount of oil because I haven't fixed it!
Looks like I have a poor quality filler tube - it's leaking in addition to the pushrod tubes Sad
1964 Type 3 Truck
dc
dc is offline
PostPosted: Sun Aug 27, 2017 1:44 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Update -
Got some shop time this morning:
14925 -
Re-sealed pushrod tubes on the left side, flipped them around
Changed Oil
Replaced Oil Filler Tube
Applied some undercoating on the pan while it was up in the air
Set Valves all around
Hoo-ray! Cool
1964 Type 3 Truck
dc
dc is offline
PostPosted: Fri Sep 01, 2017 8:26 am    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Truck is not leaking oil!!!!
Runs Great!!!
Finally - it was last summer that it started running "weird" - Rolling Eyes
So. yesterday I drove to my neighborhood garden center/nursery:
Guess what I found--- no plants or trees or garden supplies but this nasty project car:
Not a good time for me to pick this up but I thought you all would enjoy seeing it! I have the details if your interested. It's listed on Seattle Craigslist as well.
It has a clean title... '66 Squareback - Fat Trim - The car is pretty complete, rusty pan and parts of the body. Smashed up- probably from when they dragged it out of the field/blackberries Crying or Very sad Anyway.. Question
1964 Type 3 Truck
dc
dc is offline
PostPosted: Fri Sep 15, 2017 5:11 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
http://cdn.thedarkroom.com/26000004_85637_lrg_1505364394.jpg
http://cdn.thedarkroom.com/26010017_85637_lrg_1505364453.jpg
Random shots from this summer
1964 Type 3 Truck
ALLWAGONS
Location: Fracc Soler, Tijuana Baja California Zona Norte
ALLWAGONS is offline
PostPosted: Fri Sep 15, 2017 5:32 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Nice!
is you hood handle upside down?
"Don't laugh! That's my Wisconsin ID picture!" overheard at a Local California Hipster Restaurant.
Just found out I am allergic to lead in capsules(bullets)!
dc
dc is offline
PostPosted: Fri Sep 15, 2017 6:03 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
ALLWAGONS wrote:
Nice!
Thanks!
Not upside down, but it definitely sits weird- it's a '69 hood that I just put an early handle on. Maybe I did it wrong Question
1964 Type 3 Truck
Peters Van
Peters Van is offline
PostPosted: Fri Sep 15, 2017 7:26 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
all about the aerodynamics.............
1965 Type 3 Panel Van
1963 EH Holden Station Wagon
notchboy
notchboy is offline
PostPosted: Fri Sep 15, 2017 8:46 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Yes it should be level not pointing down.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
dc
dc is offline
PostPosted: Sat Sep 23, 2017 5:21 pm    Post subject: Re: Type 3 Truck - the "other" vw Reply with quote
Re-worked the bed cover to reduce weight and used black convertible top material instead of the vinyl.
Took it to a mini-truck show Shocked Laughing Exclamation
1964 Type 3 Truck
Page 76 of 80
