Removal Of Engine Mounting Bolt Issue
bugguy1967
bugguy1967 is offline
PostPosted: Sat Aug 12, 2017 9:18 pm    Post subject: Removal Of Engine Mounting Bolt Issue Reply with quote
I'm pretty sure my cross shaft or t/o bearing broke. I went to pull my engine today and the upper driver's side mounting bolt has a 17mm hex! What's worse is the trans has a cutout in the trans housing to stop the hex from spinning, similar to how the starter has a provision to stop the half moon bolt from spinning. This is in a 67 Bug. I have no idea how someone got it in there. The other end is the captive nut that comes in the late cases. Other than grinding the head off. Looking for alternative ideas before I go out there tomorrow. Thanks.
ach60 Premium Member
ach60 is offline
PostPosted: Sat Aug 12, 2017 9:45 pm    Post subject: Re: Removal Of Engine Mounting Bolt Issue Reply with quote
Sorry man I did that in 1979, when I put a '72 engine in the '67.
I swear to god I put a washer on that bolt before I put it in.
Smack the socket onto the 17mm bolt, and turn away.
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Dale M.
Dale M. is offline
PostPosted: Sat Aug 12, 2017 10:13 pm    Post subject: Re: Removal Of Engine Mounting Bolt Issue Reply with quote
You have to struggle to get it out enough with open end wrench to where you can get box end wrench on it or find really thin wall socket.... Yeah it's a problem... When you put motor back in put two or three washers on bolt first or grind lip back to where you can use socket.... One option we used was allen head cap screw in that location... Another was to relieve the area with dremel tool and cutting burr...If you can get in there with small burr you can relieve it to get bolt out...
Yes its B!%$H and you just have to tough it out...
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
stealth67vw
stealth67vw is offline
PostPosted: Sat Aug 12, 2017 11:26 pm    Post subject: Re: Removal Of Engine Mounting Bolt Issue Reply with quote
On my car some dope put a triple square M12 bolt near doghouse cooler. I spent a good 2 hours trying to back it out before removing all the top tin and oil cooler and drilling it out from the back side. It turned a 5 minutes job into a 5 hour ordeal.
John Bates
JB Machining Services
bugguy1967
PostPosted: Sun Aug 13, 2017 6:54 am    Post subject: Re: Removal Of Engine Mounting Bolt Issue Reply with quote
Ok, good ideas! I don't know why I didn't think of smacking a 17mm socket onto that area. I could also drill it out. From the other side. Maybe I should turn down a socket on the lathe so it'll chisel in easier. Thanks all!
dgsaz
dgsaz is offline
PostPosted: Sun Aug 13, 2017 9:25 am    Post subject: Re: Removal Of Engine Mounting Bolt Issue Reply with quote
I just went through a similar situation. I got lots of good info from this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=681511&highlight=dgsaz
Cusser
Cusser is offline
PostPosted: Sun Aug 13, 2017 9:47 am    Post subject: Re: Removal Of Engine Mounting Bolt Issue Reply with quote
You could grind a 17mm socket narrower using a bench grinder (and eye protection); I've got a few of those "special" sockets. And use a washer on re-assembly.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
esde
esde is offline
PostPosted: Sun Aug 13, 2017 3:00 pm    Post subject: Re: Removal Of Engine Mounting Bolt Issue Reply with quote
That bolt is even worse with the early bus curved throwout arm, that points the clutch cable end right at the head of the bolt. It can be a real puzzle if the cable is stretched, and the "extra" cable runs clear to the bolt head, so there's no room to get the wrench on. Fun, fun, fun.
modok wrote:
busman78
busman78 is offline
PostPosted: Sun Aug 13, 2017 3:29 pm    Post subject: Re: Removal Of Engine Mounting Bolt Issue Reply with quote
How about a 3/8" drive 12pt socket, then a u-joint, then enough extensions to get your ratchet to the front side of the axle, worked for me on some tight fits. If and when you get it out find a reduced head bolt, it will use a 15mm socket.
bugguy1967
PostPosted: Mon Aug 14, 2017 6:43 pm    Post subject: Re: Removal Of Engine Mounting Bolt Issue Reply with quote
I ended up grinding a 17mm socket paper thin. I got it out. Replaced it with a 15mm head, flanged bolt. Thanks all!
