burner208 Samba Member
Posted: Tue Aug 08, 2017 10:31 pm Post subject: half decklids |
I'm looking for photo examples of bajas that still retain half of there deck lids. I have a project that I may take this route. |
DWP Samba Member
Posted: Wed Aug 09, 2017 3:06 am Post subject: Re: half decklids |
Here's the deck of my baja.
One thing to consider is how to mark the deck for cutting.
If you just measure from the top down it will look like a arc or semi circle cut.
I Put the deck lid on the car and using the rear cage, and a level marked for the cut even with the ground. Mark it up with some tape and you will see.
DWP
Posted: Wed Aug 09, 2017 7:50 am Post subject: Re: half decklids |
Do you have a problem with it flapping and did you reinforce the cut edge any way? |
DWP Samba Member
Posted: Wed Aug 09, 2017 9:06 am Post subject: Re: half decklids |
What I did was to cut the lid 3/4" longer than needed. Using a rounder over steel bar as a "anvil" I hammered a lip on the lower edge. I did have to make a few slices on the curve parts. Take you time.
As far as flapping goes right now I am using a spring to keep it shut.
One of these days I will come up with some under hood latch
If you need more info just ask
DWP |
Posted: Wed Aug 09, 2017 9:06 pm Post subject: Re: half decklids |
DWP wrote: |
DWP |
Any photos of the rounded edge? I left mine about as long as yours however mine was very twisted when I started and this may just be my experiment unit.
brotherbob Samba Member
Joined: July 10, 2004 Posts: 367 Location: millsap texas
Posted: Sat Aug 12, 2017 8:12 am Post subject: Re: half decklids |
Mine-
BB _________________ In wine there is wisdom , in beer there is freedom , in water there is bacteria ! |
Bad_chopper Samba Member
Joined: August 15, 2012 Posts: 295 Location: Portland, or
Posted: Sun Aug 13, 2017 11:21 am Post subject: Re: half decklids |
Surprising to me I actually have decent pics..i use the stock deck lid spring it flexes a bit when I open and close it bit my car don't have decent paint so no biggy..
I like the looks of it, about as much as I like the normal baja style rear cover. _________________ my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267 |
