bruce cook Samba Member
Posted: Mon Jul 17, 2017 4:47 am Post subject: Re: Type 64 Coming to the 36hp Challenge |
Dave Miller is making a race deck lid it will be on the car soon. _________________ land speed nut |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Mon Jul 24, 2017 6:15 am Post subject: Re: Type 64 Coming to the 36hp Challenge |
More work on the racer as we near testing time
Posted: Tue Aug 15, 2017 4:33 am Post subject: Re: Type 64 Coming to the 36hp Challenge |
Chassis sensors are in place, now for the under body defuser
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Aug 17, 2017 4:43 pm Post subject: Re: Type 64 Coming to the 36hp Challenge |
][][][][ _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
JeeWee Samba Member
Joined: February 05, 2011 Posts: 120 Location: Garijp, the Netherlands
Posted: Sun Aug 20, 2017 10:21 am Post subject: Re: Type 64 Coming to the 36hp Challenge |
bruce cook wrote: |
After only 4 pulls on the dyno with small venturis Whitey Worsham 36 based
race engine made 172 H.P. now for some BIG venturi!!
wow I am impressed with the results, thanks for sharing! Any specs about the engine setup? Looks very epic so I expect quite some custom made parts! |
obieoberstar Samba Member
Posted: Sun Aug 20, 2017 4:28 pm Post subject: Re: Type 64 Coming to the 36hp Challenge |
bruce cook wrote: |
I have been following this build for a while now. Excited with each update.
Could you describe the function of these chassis sensors? |
Posted: Mon Aug 21, 2017 4:07 am Post subject: Re: Type 64 Coming to the 36hp Challenge |
The chassis senors are to measure down force and lift, this is needed to set the car up. The engine is the work of Whitey from German Automotive with 1699cc _________________ land speed nut |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1274 Location: australia
Posted: Fri Aug 25, 2017 1:31 am Post subject: Re: Type 64 Coming to the 36hp Challenge |
You broke the 100bhp/L mark, all motor! I knew it was possible, congratulations and great work. |
Posted: Fri Nov 17, 2017 2:52 am Post subject: Re: Type 64 Coming to the 36hp Challenge |
After over 6 years in the works The Type 64 Land Speed Racer will run at
the first ECTA event in Arkansas this coming April 2018
36hplandspeedracer Samba Member
Joined: January 30, 2006 Posts: 847 Location: Ivins, Utah
Posted: Sun Feb 11, 2018 4:08 pm Post subject: Re: Type 64 Coming to the 36hp Challenge |
The Type 64 tribute car is finished and race ready.
The results of the Team Versuchwagen Type 64's A2 Wind Tunnel test were spectacular and verified the aero efficiencies of Kommendas original sketches. And some surprises as well. In the tunnel, the vehicles tires are placed on top of sensitive computer connected electronic scales mounted under the floor which record variations in pressure as air flows over, under and around the body at various wind speeds. The biggest surprise (lesson?) came when improvement was found by removing the Copacetic Metal Shaping fabricated full belly pan along with the rear fender skirts/spats. This combination provided the most stable pressures at higher air flow speeds. It was determined the rear skirts/spats added 50 pounds of lift to the rear! It was also determined that installing a 4 3/4 inch tall perfectly vertical spoiler at the rear deck lid area would actually reduce lift, add stability "and reduce drag" making higher speeds possible without increasing horsepower. There is no front splitter, air dam or spoiler. The wind tunnel engineer running the tests indicated he had never seen such a early example of aerodynamics prove so successful. Kudos to Erwin Kommendas foresight and natural aero expertise.
Photo Copyright Roger Ball / www.callball.com
This car will be raced just once in the Type 64 configuration, in April at the ECTA speed trials in Blytheville, Arkansas, http://ecta-lsr.com/. After that, Dave will remove the T64 tribute body where it will then be installed on a second VW chassis/floorpan designed strictly for street driving at which point you can expect to see Dave enjoying the car at east coast Volkswagen and Porsche events. Bruce Cooks race based VW Beetle floorpan will then have a stock Volkswagen Type 1 sedan body installed and then delivered to the A2 Wind Tunnel to give us the first actual wind tunnel test of a Beetle air cooled sedan. After the VW Beetle wind tunnel test, the Bug will return to Arkansas for a attempt to capture the 36hp Challenge DSS (vintage dual carb) Bug record. |
Axel Andersson Samba Member
Joined: June 03, 2011 Posts: 132 Location: Sweden - Europe
Posted: Mon Feb 12, 2018 5:09 am Post subject: Re: Type 64 Coming to the 36hp Challenge |
Impressive work Bruce and the others.
Best of luck with the future of the T64 Project.
Jorgen |
Braukuche Samba Member
Posted: Mon Feb 12, 2018 1:49 pm Post subject: Re: Type 64 Coming to the 36hp Challenge |
That's THE only car I wish I had that I don't have. A work of art. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1973 Ghia convertible |
Posted: Tue Mar 06, 2018 11:45 am Post subject: Re: Type 64 Coming to the 36hp Challenge |
Press Release
Team Versuchen
Type 64 Tribute Vehicle
March 5, 2018
For immediate release:
Deja Vu
It has happened again. In 1939 Dr. Porsche created the KDF Typ 64 competition car to race in the Berlin to Rome high speed endurance race. World War 2 happened and the Typ 64 never turned a wheel in anger, leaving Dr. Porsches dream unfulfilled. Deja vu, and now the new handcrafted Typ 64 tribute car created to race for top speed records has met a similar fate.
Much to our regret, Team Versuchen, the group preparing to race the recently completed Type 64 KDF/VW/Porsche tribute car, has no option but to announce that planned competition with the car in April at the E.C.T.A. land speed event in Blytheville, Arkansas, will not take place. Due to legal complications, Team Versuchen has severed all ties with Copacetic Metal Shaping and Dave Miller.
It saddens us to advise all Team Versuchen followers, especially after all the effort and investment over the past six years, that it will not be possible to utilize the Type 64 tribute body or the unique custom components designed specifically for this special vehicle in a competitive environment.
All of your interest and support has been greatly appreciated.
Sincerely
Team Versuchen
Bruce Cook |
D-train Samba Member
Posted: Tue Mar 06, 2018 12:56 pm Post subject: Re: Type 64 Coming to the 36hp Challenge |
What? That’s not good! Will it ever race?
Or will you now drop it off to my house? _________________ shiny paint doesnt make it worth any more |
Posted: Tue Mar 06, 2018 12:59 pm Post subject: Re: Type 64 Coming to the 36hp Challenge |
D-train wrote: |
Or will you now drop it off to my house? |
Sadly, no....................... |
Posted: Tue Mar 06, 2018 1:35 pm Post subject: Re: Type 64 Coming to the 36hp Challenge |
36hplandspeedracer wrote: |
D-train wrote: |
Is that no for racing?
Or no for my house? Hehe
What was the reason if you don’t mind me asking? _________________ shiny paint doesnt make it worth any more |
Posted: Wed Mar 07, 2018 12:49 am Post subject: Re: Type 64 Coming to the 36hp Challenge |
Bruce - Very, very sorry to hear this.
Is there still a chance there will be a turn of events? |
AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 292 Location: Saskatoon, Sk Canada
PeteSC Samba Member
Posted: Sat May 04, 2019 8:08 pm Post subject: Re: Type 64 Coming to the 36hp Challenge |
I believe this is the same car in this thread. I took these photos at “Cars on Kiawah” today in Charleston, South Carolina. Absolutely incredible machine. It was driven to the show from North Carolina.
