Kelley Samba Member
Joined: April 03, 2003 Posts: 1432 Location: "Die Sonneküste" Crystal Beach, FL
Posted: Tue Aug 15, 2017 9:50 am Post subject: Re: 009 distributor |
tasb wrote: |
This didn't take long. Please use this chart as a general impression only not so sure that it will pass the veracity test.
Hopefully there's a more accurate one out there. |
Glenn may have a chart as he restores these. And it may differ from the chart you found
. _________________ 74 rusto-custom type 1 Sedan - SOLD
ZRX1100c3, Mean Green - SOLD
Growler wrote: |
I hate people. Are you people? I hate you. |
Just trying to remember classic Samba quotes from the 'Days of Yore' |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Aug 15, 2017 12:22 pm Post subject: Re: 009 distributor |
Btw: that chart that I posted makes me chuckle a bit. Not sure if it came from Hot VW's magazine or whether you're to infer that these are the hot mechanical advance while some are not hot? Does hot mean they are popular- they certainly are. does hot mean they are high performance, they certainly can be. Or, are they hot because they have an aggressive advance which produces more heat... _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Tue Aug 15, 2017 12:28 pm Post subject: Re: 009 distributor |
I have advance curve tables for all three. I've just never put all three into one table. It doesn't strike me as accurate. Keep in mind that many curve tables are for a brand new distributor. You can figure an error factor of two to three degrees on either side from any published chart. In theory an 129 019 could have an nearly identical curve to an 178 009. _________________ Roads Scholar &
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Aug 15, 2017 12:31 pm Post subject: Re: 009 distributor |
That graph is not correct.
Tim knows because he has a distributor machine also. _________________ Glenn
Member #1009
#BlueSquare |
Kelley Samba Member
Posted: Tue Aug 15, 2017 12:42 pm Post subject: Re: 009 distributor |
Glenn wrote: |
I don't know where I've seen it before, but to the eye, it doesn't look right, ha ha.
Glenn wrote: |
Tim knows because he has a distributor machine also. |
Yep. You guys ever compare notes on your rebuilds? _________________ 74 rusto-custom type 1 Sedan - SOLD
Growler wrote: |
hperez71 Samba Member
Joined: March 12, 2017 Posts: 60 Location: Puerto Rico
Posted: Tue Aug 15, 2017 1:40 pm Post subject: Re: 009 distributor |
Are there any good SVDA distributors in the market right now? I have a '71 and it came with a 009 from PO. As expected there is that dreaded flat spot when coming out of dead stop.
What I've seen around also need new coils. Is there any drop in replacement that does not need a matched coil? |
Glenn Mr. 010
Posted: Tue Aug 15, 2017 2:00 pm Post subject: Re: 009 distributor |
The best is a rebuild original German distributor. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Aug 16, 2017 11:35 am Post subject: Re: 009 distributor |
Is there a second best option if a rebuilt German one is not available? |
wcfvw69 Samba Purist
Posted: Wed Aug 16, 2017 2:46 pm Post subject: Re: 009 distributor |
hperez71 wrote: |
Your second best choice is a Bosch made in Mexico SVDA. They are also no longer made and are not as good as the German ones but are vastly superior to any of the "new" Chinese distributors being sold now. _________________ Contact me at [email protected]
The Samba member since 2004.
Broncoblair Samba Member
Joined: July 19, 2017 Posts: 105 Location: Los Angeles
Posted: Thu Aug 17, 2017 5:54 am Post subject: Re: 009 distributor |
What's a good distributor for the 34 PICT 3 carb? The 009 obviously isn't the best, is there a modern distributor or a vintage one to look for ? |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Kelley Samba Member
Posted: Thu Aug 17, 2017 7:13 am Post subject: Re: 009 distributor |
Broncoblair wrote: |
This is a long read. But some of the charts listed have essentially which Single and Dual vacuum advance distributors that were used with which model Solex Carb.
https://www.thesamba.com/vw/forum/viewtopic.php?t=185095&highlight=
The article is meant for those who had questions over the years about the H30/31 carb, but delves into stk config earlier and later Solex/Bocar/Brosal (34pict3) models as well. If you're looking to be as authentic as possible, the charts will help. If you're looking to be close but better than 178-009, the same . At any rate, there are part numbers associated with the particular 34/3 you may be using IF it's a German unit. Check to see if it's German, then check the charts for a corresponding German Bosch distributor part, then check the classifieds. Find a cheap one, probably a rebuild, then have one of the reputable rebuilders here fix it up for you.
The easy answer is a rebuilt German 034. But the info above relates to your knowledge and your ACVW and the combo you have at hand. 034 is not the best for all combos.
Keep your 009 as a spare, if it's German or Mexican. _________________ 74 rusto-custom type 1 Sedan - SOLD
Growler wrote: |
Posted: Thu Aug 17, 2017 2:12 pm Post subject: Re: 009 distributor |
Kelley wrote: |
Keep your 009 as a spare, if it's German or Mexican. |
So are those Pertronix 009 remakes with electronic ignition and vacuum frowned upon ? The Amazon reviews seem very favorable. Along with their coil. Sorry I did not mean to hijack anyones thread. |
Glenn Mr. 010
Posted: Thu Aug 17, 2017 2:18 pm Post subject: Re: 009 distributor |
First off, if it has vacuum advance, it's not a 009 clone.
Lacking a rebuild German or Mexican Bosch unit.. it's the best of the bunch. But that's not saying much since I have a very low opinion of the aftermarket distributors. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Aug 17, 2017 2:26 pm Post subject: Re: 009 distributor |
Glenn wrote: |
Lacking a rebuild German or Mexican Bosch unit.. it's the best of the bunch. But that's not saying much since I have a very low opinion of the aftermarket distributors. |
I see. From what I read the inside is basically the same as a 009 minus the vacuum advance. Do vacuum advance distributers only require you to do a timing at TDC ? |
Posted: Thu Aug 17, 2017 4:38 pm Post subject: Re: 009 distributor |
No, they are very different on the inside. The advance curves might be similar excluding vacuum advance. The only distributors that can be effectively static timed are the vacuum only distributors. _________________ Roads Scholar &
mark tucker Samba Member
Posted: Thu Aug 17, 2017 8:49 pm Post subject: Re: 009 distributor |
Ive never seen a 09 with a curve like that, most Ive seen are 2 stage curves. as in addvance, stop addvancing(flat spot) then start addvancing more later. but Im sure there were a lot of different curves and who made the chart may of had one that had been reworked or somethen rong .mine dosent work perfect, but it works great.if I had a dist machine again I could make it dam close to perfect....for what I want/like. Ive recurved a few 09's for other people with no complaints. and alwasy better than before. IMHO it's the best non vac addvance borsch made , but ....Im not fond of vw dist due to the weights under the breaker plate .pain in the butt to curve.( not a lot different than oh somany others.) |
Posted: Mon Aug 21, 2017 6:50 am Post subject: Re: 009 distributor |
The SVA distributors for VW range from 0 degrees to 10 degrees BTDC it depends on the distributor/carburetor model. _________________ Roads Scholar &
