Pacblue63 Samba Member
Posted: Thu Aug 17, 2017 3:48 pm Post subject: Re: Empi rear disc brake |
roachdub58 wrote: |
I've got no problems helping people wanting to do it right. You are going to be soooo happy with 4 wheel discs once you get it dialed in. Now that I know you have somewhat heavier 17" wheels with a LOT of tire contact, drum brakes are a waste in my opinion. That car will stop on a dime and not just slide on the road when the wheel locks up in a panic stop.
I've made hundreds of fully hydraulic crimped stainless braided brake lines for all sorts of applications, race cars, hot rods modified motorcycles... I specialized in hose and fittings while working at a hot rod shop. I can steer you in the right direction and tell you where you can get anything to plumb it. You can PM me if you need.
I don't have any experience running 17" wheels on a VW but even on airbags there's always a way. I sectioned my headlight buckets and if you or someone you know can weld decent, it's not too hard, just time consuming. I wouldn't be scared to section and stretch some fenders an inch or two if you really want to lay it out and have no fender rub. |
Thank you again
Here is pic of my dubs front
Committed to doing disc up front and
Changing all lines backside
thanks 👍 |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Thu Aug 17, 2017 6:44 pm Post subject: Re: Empi rear disc brake |
roachdub58 wrote: |
First off, the soft rubber hoses have a tendency to swell shut when old or contaminated, causing calipers and wheel cylinders to have all sorts of problems. You have extra soft lines to connect the hard line looping over the axle to connect to yet another hard line going to the caliper. That shit needs to go in the garbage can no matter what.
Go to any decent parts place and pick up new hardlines in the proper length to do one long metal line. They come in 10" increments, you are looking for 3/16" diameter metric/bubble flare 10mm x 1.0 thread size for stock VW fittings. The new hard lines are straight, so you will need to bend them, it's easy. If your calipers are not this thread, you need an adapter to covert it. Buy the new hardlines and compare the thread AND style of flare, they should match.
The next steps depend on if you want to do a proper 4 disc setup, so I need your input. Otherwise put drum setup back on but still throw those extra soft lines in the trash. |
The brake kit has floating calipers, so there should be a soft line going to the caliper. A hard line will flex when the caliper moves and could eventually break. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Thu Aug 17, 2017 9:01 pm Post subject: Re: Empi rear disc brake |
vwfreek61 wrote: |
roachdub58 wrote: |
The brake kit has floating calipers, so there should be a soft line going to the caliper. A hard line will flex when the caliper moves and could eventually break. |
My CB kit didn't even mention anything about the hoses or hardlines. It just says to "connect it". I don't trust a hose right by the hot exhaust not to melt. The OP setup looks hokey, is that how the Empi kit comes? _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
Posted: Thu Aug 17, 2017 10:48 pm Post subject: Re: Empi rear disc brake |
roachdub58 wrote: |
vwfreek61 wrote: |
roachdub58 wrote: |
My CB kit didn't even mention anything about the hoses or hardlines. It just says to "connect it". I don't trust a hose right by the hot exhaust not to melt. The OP setup looks hokey, is that how the Empi kit comes? |
Pm'd u bout front discs |
