barefootjohnny Samba Member
Posted: Fri Aug 18, 2017 9:45 am Post subject: Engine upgrade |
I own a 77 baywindow. I lack a lot of knowledge on vw bus' and engines, but have been reading and learning as much as I can. I would like opinions from this community of vw experts.
Starting with the engine what parts should I replace (can't afford a whole new engine right now) that would make it run better or parts that are more likely needed replacing after all these years to get better mpg or overall performance. I understand its not a drag car, but I wan't to replace anything you think will cause a rougher ride due to years of wear or just due to better options today then was available in 1977.
also, recommend aftermarket performance exhaust?
Thank you for all the help. I truly appreciate it as I learn. |
lightice Samba Member
Posted: Fri Aug 18, 2017 9:57 am Post subject: Re: Engine upgrade |
Maybe you can start listing down what engine is in your 77.
Is it a type 1 or type 4 engine?
What have you done to it, and why do you think it needs parts replacement. |
airkooledchris Samba Member
Posted: Fri Aug 18, 2017 10:15 am Post subject: Re: Engine upgrade |
If your engine runs and you don't know much about them, don't think about anything that would be considered an 'upgrade' for now. Just pay attention to every little hose and bolt and make everything that you DO have currently - work as well as it can by being sure it's setup properly.
If you don't already, get this manual:
When you have time, take pics of your stuff and upload it here. |
cmonSTART Samba Member
Posted: Fri Aug 18, 2017 10:39 am Post subject: Re: Engine upgrade |
I have to say my stock 2.0 FI engine is pretty nice. _________________ '78 Bus 2.0FI
de K1IGS |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Fri Aug 18, 2017 10:50 am Post subject: Re: Engine upgrade |
There are very few bolt-on "upgrades" that improve performance much over stock. If your engine is in good condition, you would be surprised by how much you can upgrade it's performance by proper tuning and updated maintenance. |
Terminatez Samba Member
Joined: June 07, 2015 Posts: 340 Location: Sun Valley, CA
Posted: Fri Aug 18, 2017 10:56 am Post subject: Re: Engine upgrade |
From other threads I've read, replace all the hoses and make sure all the tins are setup correctly/replace missing tins. Check your brakes and anything that has to do with your brakes. A safer ride is a better ride. _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
I don't think I've ever seen an engine in worse shape. |
SGKent Samba Member
Posted: Fri Aug 18, 2017 11:18 am Post subject: Re: Engine upgrade |
Find a mentor who has gone thru this already and whose bus / work you respect. Work with them privately so they can mentor you to improve your bus. This forum is great but you will go nuts listening to 20 different opinions to each question. Think of it like a journey - there are many paths that reach the same destination. Like any car the repairs will never end if you drive it a lot- although they will become maintenance instead after awhile. A mentor can assist you thru the many obstacles you will face like poor quality replacement parts, or no longer available parts etc. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Fri Aug 18, 2017 1:52 pm Post subject: Re: Engine upgrade |
barefootjohnny wrote: |
Starting with the engine what parts should I replace (can't afford a whole new engine right now) |
If you can't afford a new engine save your money until you can. The "come on baby, just the tip for just a minute" approach doesn't work when it comes to engine work...you're all in...or you're not.
Focus on making yours run as good as possible....don't cobble up anything thinking you'll be ahead...it doesn't work that way _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
wcfvw69 Samba Purist
Posted: Fri Aug 18, 2017 2:20 pm Post subject: Re: Engine upgrade |
You can also get some better answers if you post pictures of you engine. The type 4 guys (if it's a type 4 engine) can look it over and point out any obvious concerns or issues. _________________ Contact me at [email protected]
The Samba member since 2004.
timvw7476 Samba Member
Posted: Fri Aug 18, 2017 2:23 pm Post subject: Re: Engine upgrade |
The stock exhaust keeps up a certain back pressure that makes the bus
generate decent torque right where a 3,000 lb bus needs it, plus decent
fuel use & quiet. Don't toss it if it is in decent shape. |
