dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
Posted: Fri Aug 18, 2017 3:25 pm Post subject: Fuel Line Inlet Fittings / Weber IDF 40 |
OK, I have started the process of plumbing my newly reconditioned gas tank, new fuel filter (not located in the engine bay) and finally attaching the new fuel line to the new Weber IDF 40's.
Here is where I've got questions. The fittings from the fuel tap and in and out of the fuel pump are (I think) 5mm German braided lines. Everything fits like a glove until I get to the carburetors.
The inlets at the carbs looks to be 7mm. I played with a bit a of lube but the smaller lines do not want to attach to the larger inlet fittings.
Are there 5mm inlets for the Weber IDF? Do I need to keep the 7mm inlets?
This is my first go around with dual carbs and I'm a bit out of my sphere of knowledge.
Here is a photo of the dilemma.
You can see the difference between the fuel pump and the carb inlet.
How to proceed?
Thanks folks,
dgsaz |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Fri Aug 18, 2017 5:05 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
If you can get another threaded barbed fitting for the fuel pump hose 'size' put the two together with a plumbing coupling as an adapter. From 1/4" to 5/16"
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Aug 18, 2017 5:43 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
I went with push-lock hose and -4 fittings. I run an electric FP up front w/ a CIS filter (also up front) and a compression to AN fitting on the metal line at frame horn. And then a "T" fitting on driver's side near carb. No hose clamps needed. cost was a little more, but very reasonable and hose and brass have dealt very well with todays fuels.
modok Samba Member
Posted: Fri Aug 18, 2017 5:52 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
You can change whatever parts you want, but I think you should use 1/4 or 5/16 fuel hose, because this is the USA and that's what's available.
The weber barbs are most likely 8mm (same as 5/16) |
dgsaz Samba Member
Posted: Fri Aug 18, 2017 6:37 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
After reading the comments thus far, I would like to find 1/4" fuel intakes for the carbs and plumb the entire system in 1/4".
Does anyone know of a source for 1/4" Weber fuel intake? Metric threads.
I thinks that's the way to go.
dgsaz |
modok Samba Member
Posted: Fri Aug 18, 2017 6:57 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
The threads are about the same as our oil pressure sensors, meaning probably metric but it's SO close to 1/8 pipe that you can hardly tell for sure which it is. I've seen 1/8 tapered pipe barbs or 1/8 straight pipe thread screwed into them but I don't think it's right, but it's close enough to work. Dab of red loctite to make sure it seals and won't come loose is a good idea in any case, just make sure to rinse and blow out any excess.
It's also possible to fit MOST brands of 1/4 fuel line over the 5/16 barb, and once again that's not really "correct" but put some silicone grease on there and some Gates, Goodyear, or other GOOD brand of low pressure fuel line, it'll go, it will go, and plenty tight.
Dealing with fuel I can't endorse doing anything fishy like that but IMO, that's less risky than using some unmarked fuel hose like some places are selling. With no brand and part number to read, you don't know if it's Continental or imitation, ethanol safe or not. There is "mystery hose" out there and it IS causing trouble. |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Fri Aug 18, 2017 8:39 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
Use one of the plastic fuel filters just out of the tube by transaxle. 5mm cuel line coming off metal line and i to fuel filter......7mm fuel line coming off of fuel cilter to go to carbs. Thkse filters are stepped to allow you to do this. Cheap....easy....and made to do that way. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Fri Aug 18, 2017 8:42 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
You should be able to buy a reducer in a barbed fitting |
Dale M. Samba Member
Posted: Fri Aug 18, 2017 9:50 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
Come out of fuel pump and use 1/4 to 5/15 barbed fitting (reducer) and do all plumbing from adapter to carbs in 5/16...
Should be available at most any hardware store or big box store...
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Fri Aug 18, 2017 9:53 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
dgsaz wrote: |
Does anyone know of a source for 1/4" Weber fuel intake? Metric threads. |
I do!
Definitely NOT pipe (taper) threads!
I ordered these . . . http://www.ebay.com/itm/Metric-M10-M10X1-Male-X-6m...25cc0d6b9f
The photo in the 'Bay ad is not the actual fitting!
What they sent to me looks quite different . . . The new 1/4" barb (on the right) is plated brass . . . that's the O.E.M. Weber fitting on the left
_________________ Jesucristo es mi Señor y Salvador!
mcdragracer Samba Member
Posted: Fri Aug 18, 2017 10:11 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
Just use the cone shaped fuel filter it has 2 different size stems.
That will be your adaptor, I've alway used that with a dual carb set up, works just fine. |
modok Samba Member
Posted: Fri Aug 18, 2017 10:29 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
yes that's it, -10x1 thread-
Not too keen on the plastic fuel filters......but I might endorse a T fitting, a odd tee fitting with one 1/4 and two 5/16 barbs is probably easier to find than the 10x1 1/4 barb fitting, which....hey it's great that it does exist.... but you gotta admit that's a mutant bastard child of a fitting if there ever was one |
Posted: Fri Aug 18, 2017 10:45 pm Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
modok wrote: |
I'm with ya Glen on the plastic filters . . . especially when placed between the pump and carb(s)!
Wasn't gonna mention it because OP is lookin' for fittings to fit his carburetors, but . . . .for my Italian IDFs, one of these from the same seller . . . http://www.ebay.com/itm/Reducer-Hose-ID-5-16-to-1-...mp;vxp=mtr _________________ Jesucristo es mi Señor y Salvador! |
Posted: Sat Aug 19, 2017 7:42 am Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
Possibly...
https://www.belmetric.com/barbed-hose-adapters-c-1...10768.html
dgsaz Samba Member
Posted: Sat Aug 19, 2017 9:16 am Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
57BLITZ wrote: |
dgsaz wrote: |
I do!
We have a winner. I bought two of these and I believe this should solve the dilemma.
Thanks all,
dgsaz |
buggeezer Samba Member
Posted: Wed Apr 12, 2023 5:29 am Post subject: Re: Fuel Line Inlet Fittings / Weber IDF 40 |
I am almost finished restoring and building a big engine for a 1958 Beetle European. I need 1/4 inlet fittings too but I solved that by tapping in a piece of 1/4 inch copper tubing and soldered that. If you want a "barb" you could use a tubing flare tool and slightly "bulge" the tubing. Works for me! https://www.facebook.com/profile.php?id=100086344580438&is_tour_completed=true If you are interest in following me (I'm 80 now and spent 40 years restoring VWs and I do it all) this is my Facebook page "VW BeetleMania"[. |
