Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Tue Jun 06, 2017 8:59 am Post subject: EMPI Shift Coupler |
I just received yesterday a shift coupler from a relatively large VW parts supplier, was only one choice available for these from them, didn't know it was EMPI. And the opening was too small to fit over the end of the shift rod, I had to "re-engineer" that. I don't blame that supplier, but I'm sure I'm not the first to have that happen.
I did contact the supplier as they too could get back to EMPI (I'm sure all the EMPI couplers are the same, just engineered and manufactured incorrectly). So basically another example of an imperfect copy, when getting it right would not have required much effort.
I'm not near a city right now, so my only other choice (assuming non-EMPI couplers are available) besides waiting a week/several days would've been using the old coupler which wasn't too bad (my issue was the shift bushing, it turns out) or the EMPI rectangles in the old coupler cage.
New coupler cage on the right definitely has opening smaller by a few mm; even though I didn't have them aligned perfectly for my one-handed photo, the difference is readily apparent.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Wed Jun 07, 2017 1:15 pm Post subject: Re: EMPI Shift Coupler |
last time I bought a coupler, I think I only used the rubber pieces, and put them in my old cage.
that was at least 5 years ago. I can't imagine they have gotten any better _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 556 Location: Anaheim, CA
Posted: Sat Aug 19, 2017 7:52 pm Post subject: Re: EMPI Shift Coupler |
Use NOS/OEM and you hopefully won't have these problems. It is sad that vendors just assume that because it is new and shiny and skin packed that it is good. Past experience should tell them to check these things fit before selling them. Ditto magnetic drain plugs that won't work with oil strainers - well, not unless you want to punch a hole in the strainer when you tighten it down. _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
