What did you do for your Bay recently?
Page: Previous  1, 2, 3 ... 413, 414, 415 ... 462, 463, 464  Next
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Sat Aug 12, 2017 9:32 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
After, oh, two-ish+ years of not being used AT ALL I finally started her yesterday Shocked
She sat in front of our [well] pump house and I had a big tarp over her so the only thing that was exposed were the lower half of the tires. Pulled the tarp off and she looked great. Jacked up the rear to put some boards under the left rear tire as it was the only one not resting on asphalt so it sank a couple inched into the earth. There was very little gas in the tank and I added some gas drier (I initially stored her with gas stabilizer, too) then a 1/2 gallon of fresh gas. The batteries were long dead (starter and camping) but I put them on a charger for over 5 hours. During that wait I filled the tires to 40psi just to make it easier to push her. Ya know, after that many years of just sitting the lowest pressure of the four tires was 15psi, the rest were about 20psi-ish. She runs with the Hankook truck tires and they are great!
I tried pushing her from her spot but it was too much for my bad back. So I put the key in the ignition and turned it to the ACC position and everything lit up -- good. I then turned the key to START and she cranked -- good. As she was cranking I heard a cylinder or two fire Shocked Whut? So I started cranking again and she tried to fire again. Third or fourth attempt and she fired! You could hear the air crack from my wife whipping her head around when she heard our Bus come to life Laughing We were both surprised. I should mention that this was a FI engine but I put carbs on it since the FI was being too #$%!ing unreliable and causing me too much time trouble-shooting and fixing (and I actually LOVE FI...old age is making grumpy and less patient). The engine compartment looks just like the day I stored her, you would never know she sat unused for that long.
Drove her down the driveway, around on the street, and back into her parking spot -- but with all four tires on asphalt this time Wink Now that she's moveable she will be taking up the spot where our '76 Apache trailer was in my shop. The reason? I plan on putting my '95 OBD-I VW Jetta engine in her Cool It will take time cuz my Jetta (with Peloquin LSD) is a kick to drive and I will need a replacement daily driver...
[ Aug. 16th - Correction: I actually looked at the license plate tags, the month was 8 and the year was 12 Shocked So the Bus went untouched for 5 years but one would never know it Very Happy ]
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
Spike0180
Spike0180 is offline
PostPosted: Fri Aug 18, 2017 6:40 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I changed out my tie rods. They were old for sure. I could grab them and move them around like nothing there was so much play. I had about 1/4"-1/2" of play in the wheel when grabbing it from 3 and 9. Not anymore though!
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
chaosisme
chaosisme is offline
PostPosted: Sat Aug 19, 2017 4:00 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
New:
Master cylinder
Wheel cylinders
Wheel bearings
Brake hoses
Brake shoes
Bowden tube
Clutch cable
Axle boots
Shift bushings
Shift rod boots
Shift coupler
Fuel filler hose
Breather hoses
Rebuilt:
CV's
Clutch pedal
Brake pedal
'65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's
williamM
williamM is offline
PostPosted: Sat Aug 19, 2017 4:24 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I sold her--- Very Happy Very Happy Very Happy Shocked Shocked This bus needed an adventure and I had 3 others- so when some wayward desperate adventurers showed up- I made them a deal they couldn't refuse.
[img]https://www.thesamba.com/vw/gallery/pix/1681926.jpg[/[img]
img]
[/img]
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Sat Aug 19, 2017 9:30 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Is this Ben and his latest gal? What bus did you sell him?
The Samba member since 2004.
williamM
williamM is offline
PostPosted: Sat Aug 19, 2017 10:20 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
the grey 73 hitopper from Monrovia Ca. I got to keep the entire interior. And got it running the other day- very light rod knock till the OP comes up- but they want a new motor any way.
I personally like them both - and they tolerated me and my dog with dignity.
Don't step in any!
KentABQ Premium Member
KentABQ is offline
PostPosted: Sun Aug 20, 2017 6:39 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
And you even treated them to the World's Best Pizza???
You are a prince among men. Dancing
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
SamboSamba22
SamboSamba22 is online now
PostPosted: Sun Aug 20, 2017 6:44 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Dining with VW bus adventure celebrities!
Ben has shared some magical moments and experiences with us all through his endless obsession of adventure, always sharing love and beautiful imagery.
Got even sweeter when he became Hollywood, the cameras and drones created a whole new perspective and dynamic capturing the awesomeness of their remote campsites and views.
Ready to see more adventures with him, and whomever he may pick up along the way.
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
williamM
williamM is offline
PostPosted: Sun Aug 20, 2017 6:57 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Yes- and a good time was had by all.
Don't step in any!
williamM
williamM is offline
PostPosted: Sun Aug 20, 2017 7:05 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Very Happy I was really surprised and glad to see the grey whale with a future.
From what I can tell- they will have 6 mo visas coming their way- so I've been collecting every part the bus will need for a more or less "uninterrupted " journey-
Leah wanted a swivel seat -check
Ben wants a modern motor you don't have to live under - check ish-
Both want more power- remember they crossed the Andes 7 times--(you kind of have to do that on purpose.) -see above
Wanted indoor security for their stuff- check
No rust--does the battery count- check
So - looks really like this solid Cali Az. bus is going to do it-- Here's hoping.
Don't step in any!
Samba Purist
wcfvw69 is offline
I think Ben gets a bad rap. Not many people would WANT his lifestyle and 24-7 adventures on the road. It wouldn't be my cup of tea, even when I was his age. I do enjoy his video's as well.
I've PM'd with him and agree, he is a nice guy.
kruno
kruno is offline
PostPosted: Sun Aug 20, 2017 11:13 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
'58 bug
'54 barndoor
'79 bay window
'05 renault modus Smile a little gallic gay car
toXic rust
williamM
williamM is offline
PostPosted: Sun Aug 20, 2017 4:49 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I bet even Skills pays for a video or music once in a while-
So how come - when some one new shows up with something everybody (150, thou on the net now) wants to listen to and watch-- there's a problem parting with a few bucks or buying a t-shirt---once in a while?
They don't have a "gofuckyou" account- they sold chances on their bus--Oh ya they actually fixed it and gave it away.
After all this time they are finally getting enough attention to sell a little advertising- when did you watch TV wo ads?
So gotta agree- Ben n Leah get the short end every once in a while from people who can't distinguish a "will work for food" sign (but won't)--- from "news at eleven after this short message?"
Don't step in any!
KentABQ is offline
PostPosted: Sun Aug 20, 2017 4:53 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
^ X2 Very Happy
Ben and Leah get a lot of crap from a small number of Sambanistas. There's now a thread belittling all Vanlifers efforts, which I haven't bothered to look at.
Last I checked, we live in a free country. Or we do until the Big Cheeto has his way. Lol!
-Kent-
---WildIdea
williamM
williamM is offline
PostPosted: Sun Aug 20, 2017 5:11 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Shocked Laughing Laughing now thats funny " lord forgive me and all the little pygmies in New Guinea"-
I will say that in my estimation- Ben is pretty transparent-- thats a good thing Ben (in case you ever find this post)-- in other words- I detect no deception or conniving in any of my dealings- (well maybe after being questioned about the Kombi after the lights go out in his QnA blog.) So you wouldn't get that out of most of us sober any way.
I look forward to the "New Adventure" coming up in Nov or Dec when they get back and get started on their new ride. I've driven it - and it's the cats meow. With improvements to suspension and impending engine/trans- transplant- I believe this will be a great transcontinental ride.
Just wish I thought of it.
Don't step in any!
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sun Aug 20, 2017 11:11 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Damn, williamM, that's a big update for a thread that some folks ignore… I'm glad Ben and Leah (that's her name, right?) had the World's Best Pizza too! I'm honored to be in such notable company… Can you BELIEVE that my camera memory card went kaput before I could get ehe pictures of us and Silly Al uploaded? Do you have a copy?
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
williamM
williamM is offline
PostPosted: Mon Aug 21, 2017 7:21 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
asiab3 wrote:
Damn, williamM, that's a big update --- my camera memory card went kaput before I could get the pictures of us and Silly Al uploaded? Do you have a copy?
Robbie
E-mail sent-
GUESS WHO SAW THE PIZZA FIRST//////????
[img]
[/img]
Don't step in any!
static
static is offline
PostPosted: Mon Aug 21, 2017 9:41 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Finally got new seat covers!
The old ones were TMI with West Coast Metric cocoa husk padding. Frankly, that padding was not comfortable. The TMI covers faded pretty badly over the decade and were hard to clean properly. They never really did get clean (my bus is a camping bus, not a show queen).
The new covers are from Sewfine. They were just put on last night (so there are still some wrinkles that I expect will come out) and it took two friends and myself to install them. It is, to put it mildly, a big PITA.
BTW, new covers + pleats + foam cushions & backs + shipping = $490.00
williamM
williamM is offline
PostPosted: Mon Aug 21, 2017 9:49 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
The new covers are from Sewfine. They were just put on last night (so there are still some wrinkles that I expect will come out) It is, to put it mildly, a big PITA.
Getting great seats to look good is one of the best investments you can make.-- Besides brakes and tires- Being able to open the door and get "Oh My" feeling is worth every dime- Nice work---
Don't step in any!
tootype2crazy
tootype2crazy is offline
PostPosted: Thu Aug 24, 2017 6:49 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Made a new muffler using a Flowmaster 12514310. It's supposed to be the highest flowing, quietest muffler around. I must say compared to the small magnaflow I had on there before it is way quieter on the inside of the bus, sounds nearly the same outside though. It is billed as cutting down on interior drone which is what I'm after.
I also moved my wideband sensor to after the muffler on this setup and added a bung extender. I have found that VW exhaust is too short for 02 sensors to be used directly in the pipe as the exhaust gets too hot and damages the sensor.
Not seen in this photo is the hanger I made that attaches to the tailpipe via a u-bolt and then goes up to one of the engine hanger bracket bolts. It's not too pretty but gets the job done of canceling out the end of the pipe bouncing around. The bumper hides it pretty well. Previously on my magnaflow muffler I made a strong solid bracket that bolted to the alternator bracket but found that was bad for the alternator and the heater box on that side, making all of them come loose over time.
air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's)
Page 414 of 464
