Poptopcamper Samba Member
Joined: June 23, 2012 Posts: 490 Location: Sheridan, Wyoming
Posted: Mon Aug 21, 2017 3:54 pm Post subject: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
It's been a couple years since I've worked on my bus. I had two surgeries which required a lengthy recovery and I don't hav a warm garage to work in during our frigid Wyoming winters. The last thing I did was replace the front brake pads, check and adjust the rear brake shoes, bleed all four brake lines and adjust the emergency brake. Then it sat for two years in my garage.
This summer I've been busy making up for lost time, getting a lot done on the bus. I decided to drive it to the gas station, about two miles, to fill it with fresh gas. On the way home, I was doing 45 mph and gently hit the brake pedal to slow for a left turn. A brake on the passenger side locked up and wouldn't release. I left a long black stripe on the road. I finally stopped and traffic was going around me. The brake finally let go and I was able to pull off on the shoulder. I got out to see if there was smoke coming from the tire or brakes, but there was none. So I don't know if it was the from brake pad, or rear brake shoe that locked up. I was able to drive home, slowly so I didn't hit the brakes. But when I stopped on my street and started, they released okay.
Question: where do I start to determine which brake s faulty. What could cause a brake to lock up like that. I'm glad I wasn't doing 65. We might have rolled. Thanks. _________________ If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2021 Dodge Ram 3/4 ton
2020 VW Tiguan
2001 Harley Electraglide Classic
1986 BMW R 800cc motorcycle
2002 Chevy Camaro Z28
1999 Harley Sportster 1200 Custom |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Aug 21, 2017 4:08 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Not this matters in your case but you really shouldn't ever need to adjust your parking brake. When you adjust the rears, the parking brake should tighten up as well. If you adjusted it BEFORE you adjusted the shoes then the parking brake might have been too tight. I guess a likely suspect could be a brake hose collapsing internally. What kind of shape are your hoses in? Keep in mind that lots of time they look ok on the outside. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Mon Aug 21, 2017 4:18 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Another thing I just thought of. When I've left the bus sitting over night and then move it in the morning, the brakes have stuck. I pumped the brakes and they came lose and no Problem. I was going to check the brakes again, but went to gas up before I did. I'm just trying to diagnose the problem. Collapsed brake hoses could be a real possibility, after 39 years. I just put braided steel brake lines on my Harley. I probably need to do that on the bus. _________________ If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2020 VW Tiguan
Posted: Mon Aug 21, 2017 4:22 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Just buy regular hoses and you'll be fine _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon Aug 21, 2017 4:34 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Regular hoses. Right. Thanks. _________________ If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2020 VW Tiguan
Tcash Samba Member
Posted: Mon Aug 21, 2017 4:40 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Chock the front tires. Jack the rear wheel up. Apply the brake, then try and turn the wheel. Repeat process on front wheel. This will isolate which wheel it is. |
Posted: Mon Aug 21, 2017 5:03 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Thanks Tcash. Will do. I've ordered new brake lines from Bus Depot. 39 years on a brake hose is a long time and I drive over 10,000 foot mountain passes in Wyoming. Brakes are a good thing.😎 _________________ If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2020 VW Tiguan
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Mon Aug 21, 2017 6:26 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Leaking wheel cylinders that contaminate brake shoes can make the friction material sticky. Pull the drums & inspect the brakes. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Aug 21, 2017 6:35 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
All good feedback. I plan to pull the wheels and check the brake shoes. _________________ If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2020 VW Tiguan
Posted: Mon Aug 21, 2017 6:38 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Also, rust on the braking surface of the drum where the shoes weren't while the vehicle sat can cause this too.
But if everything checks out visually, suspect the brake hose. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Mon Aug 21, 2017 7:27 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
I judge by your signature line that you are talking about your 1978 Riviera, which should feature front disc brakes.
Twice now on my 1973 bus, the brake calipers have seized due to inactivity. Each event required a disassembly of the caliper. This last time was after a near three-year sitting period... shortly after I rebuilt the calipers!
Jack the front. Relieve the caliper brake pressure from the bleed port because you're changing the hose anyway. Try to rotate the disc.
If they are seized, I got a nice pair of rebuilt ATE calipers from O'Reilly Auto Parts, if you can believe that. |
Posted: Tue Aug 22, 2017 4:41 am Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Living in Wyoming, I have been mail ordering most of my parts and paying shipping. I recently discovered that my local O'Reilly's can order parts for my bus and have them usually in one day. And no shipping fee. Who knew?😎 _________________ If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2020 VW Tiguan
Posted: Tue Aug 22, 2017 6:04 am Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Autohausaz is a good source with no tax and free shipping over $75. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tcash Samba Member
Posted: Tue Aug 22, 2017 11:00 am Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Start soaking those fitting with rust penetrant. You will also need a 11mm Flare nut (brake line) wrench.
Good luck
Tcash |
Posted: Tue Aug 22, 2017 4:44 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
The only times I have seen brakes lock up while driving any automobile or light truck with correctly assembled brakes was due to hypoid gear lube leaking and getting on the shoes or the adjustment being way way off.
Not sure what would happen if you just got wheel bearing grease onto the shoes verses hypoid gear lube.
If your brakes aren't put together right and/or the adjustment is really loose that would be a different story. Yes if you adjusted your parking brake before adjusting the brake adjusters themselves then the normal brake adjustment could be really loose which might well cause problems. |
richard123vmt Samba Member
Joined: February 04, 2017 Posts: 126 Location: california
Posted: Tue Aug 22, 2017 6:47 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
I have had a front caliper lock up partially, enough to get hot, not enough to stop the bus. I did not at that time know about collapsed hoses so switched in a caliper from the then common junkyard vws. The cost of rebuilt calipers is low and I guess as good as new. You need new hoses front and rear (and the quality willnot be as good as original). The cost of wheel cylinders is riddiculously low. If the shoes are not worn out and /or contaminated, you can reuse them. That leaves the MC which is also cheap. But I think if you exmaine the tires you will see which one was stuck. I have never heard of a wheel cylinder locking up. |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Aug 22, 2017 9:45 pm Post subject: Re: Whoa!! Brakes locked up doing 45 mph. That was scary.??? |
Poptopcamper wrote: |
Thanks Tcash. Will do. I've ordered new brake lines from Bus Depot. 39 years on a brake hose is a long time and I drive over 10,000 foot mountain passes in Wyoming. Brakes are a good thing.😎 |
How high is Powder River Pass? I was thinking of heading over that in my '71. More worried about the up than the down though. That's a long climb from either the Buffalo side or the Tensleep side. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
