electronictofu Samba Member
Posted: Mon Aug 21, 2017 1:28 pm Post subject: Front Emblem Install Trick? |
Is there a trick to reaching the top stud on the front emblem stud, getting the nut on there? It's the one inside behind the dash below the windows, it's crazy insane to reach in there. I can get a finger on it, but threaded a nut, seems to be quite challenging. |
dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Mon Aug 21, 2017 1:38 pm Post subject: Re: Front Emblem Install Trick? |
how about putting some puddy on there? the other 3 will keep it in place, and the puddy will keep it from rattling or moving around? _________________ regards
Uli
Posted: Mon Aug 21, 2017 1:42 pm Post subject: Re: Front Emblem Install Trick? |
a lot of people did thread them, to better protect them from theft. _________________ regards
Uli
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Aug 21, 2017 1:50 pm Post subject: Re: Front Emblem Install Trick? |
my friend ran a jet boat repair service-- the thieves plugged into his outdoor outlet and used a sawzall to cut the entire transom out of a $40,000 boat to steal the motor n pump.
so-- maybe --- a $125 front emblem vs a torn cut dented nose is a consideration here.
Personally- I'm going to use R Earth magnets. and fake emblems from door skin ply before my next emblem is stolen. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Mon Aug 21, 2017 2:11 pm Post subject: Re: Front Emblem Install Trick? |
Would a local Ace or Emigh Hardware have something like that:
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=N120811
I've got nuts on the other studs and they secured nicely, but that top one I bet I'll need to use a clip to get it on there. Nice tips! Yeah, it would suck to have it stolen but if there on there TOO SECURE someone could pry and damage the front end. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Mon Aug 21, 2017 5:25 pm Post subject: Re: Front Emblem Install Trick? |
electronictofu wrote: |
Yes, Ace has clips but they are not metric last time I checked so you might have run a drill through them to widen them a tiny bit.
I've done that in the past. _________________ How to Post Photos
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Mon Aug 21, 2017 7:20 pm Post subject: Re: Front Emblem Install Trick? |
I got it on by removing the parcel tray and possibly the wiper motor. _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Single carbs are for lawn mowers! |
Don't forget those seat-belts!
Click to view image |
velvetgreen Samba Member
Posted: Mon Aug 21, 2017 8:58 pm Post subject: Re: Front Emblem Install Trick? |
^^ another vote for rare earth magnets on the back of the emblem. allows you to take the emblem off and store it in the car if you think your logo is in risk of being pinched. The problem with making the logo too secured to the bus is that a determined thief will end up trashing the nose of the bus in their effort to remove the emblem |
Pinetops Samba Member
Posted: Mon Aug 21, 2017 9:00 pm Post subject: Re: Front Emblem Install Trick? |
I had to get my friend with small hands to do it. I think he may have put double sided tape on his finger and the clip. _________________ "A rolling bus gathers no rust." |
Posted: Mon Aug 21, 2017 10:47 pm Post subject: Re: Front Emblem Install Trick? |
On my '61:
For the top push-on clip, I remember holding the clip with a pair of needle nose pliers while my wife pushed the emblem down from the outside.
This gave me enough hand space to hold it from a distance.
As kevin said, it's possible I dropped the parcel tray too, can't remember.
I definitely didn't pull the wiper motor.
Don't forget the little rubber seals on the posts too. _________________ How to Post Photos
Don66bus Samba Member
Posted: Tue Aug 22, 2017 4:37 am Post subject: Re: Front Emblem Install Trick? |
Last time someone snatched my emblem, they left their blood (plus a trail of bloody tissues up the street). I doubt it was worth it.
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Tue Aug 22, 2017 5:46 am Post subject: Re: Front Emblem Install Trick? |
mandraks wrote: |
a lot of people did thread them, to better protect them from theft. |
I threaded mine on my DC more for ease of install vs. theft, although that is a close second. I believe it was an M5 x .8mm die, which worked perfectly, and The Depot even had SS wingnuts to make installation a breeze. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Thu Aug 24, 2017 7:20 pm Post subject: Re: Front Emblem Install Trick? |
Don66bus wrote: |
Did you sharpen the emblem to a razors edge? _________________ some days I get up and just sit and think. Some days I just sit.
