Hitch receiver for Cargo Carrier
TheWilliamAlan
TheWilliamAlan is offline
PostPosted: Mon Aug 21, 2017 6:07 pm    Post subject: Hitch receiver for Cargo Carrier Reply with quote
My father in law gave me a little cargo tray about 4'x2' that hooks into a tow hitch receiver. My 91 Syncro doesn't have a hitch. If I only use it for this cargo tray would I be safe building a hitch that just bolts to the loops under the bumper?
'58 Euro Spec Beetle
'91 Vanagon Syncro 2.1
pedrokrusher
pedrokrusher is offline
PostPosted: Mon Aug 21, 2017 7:09 pm    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
Just attached to the tow loops alone? No!
Look here, its exactly what you are looking for:
- Built a 2" receiver trailer hitch
https://www.thesamba.com/vw/forum/viewtopic.php?t=662361&highlight=trailer+hitch
Pedro
1989 vanagon Karmann Gipsy #652, TDI AFN
1991 vanagon westfalia conversion TDI ALH Silverfox
ex-1989 vanagon syncro passenger Syncrofox (Sold)
http://www.thesamba.com/vw/forum/viewtopic.php?t=598791&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=493964&highlight=speed+aap+trans
http://www.thesamba.com/vw/forum/viewtopic.php?t=496589&highlight=carrier+bars
http://www.thesamba.com/vw/forum/viewtopic.php?t=506025
Sodo
Sodo is offline
PostPosted: Mon Aug 21, 2017 7:35 pm    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
Thx PedroC glad u like my hitch design. But the hitch I had before I rebuilt it .... was the standard style that attaches to the two "tow loops" and it was rated for 500 lb. thats a LOT of cargo. (!! ERROR !! , I don't have the sticker anymore but I think it was rated for 100lbs of tongue weight at the ball)
500 lbs is a large motorcycle (that's too much for a vanagon!) I think it would be fine for your cargo shelf. I doubt you'll even have 200 lbs, that would be so much it would cover the van.
EJ25, Peloquin diff, locker, transaxle oil cooler/filtration system
....KTMs, GasGas, and a Stumpjumper
One apple every 8 hours will keep 3 doctors away - B Kliban
TheWilliamAlan
PostPosted: Tue Aug 22, 2017 8:09 am    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
Ok. So I could bolt to the loops and run some supports to the bars under the motor. No prob. Thanks! I saw that thread but didn't realize he had removed the loops so I wasn't sure what he had done. Reading more carefully he welded to the supports for the loops instead of bolting to them.
Sodo
Sodo is offline
PostPosted: Tue Aug 22, 2017 9:41 am    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
My hitch (modified extensively) attaches to the tow loops but has added supports to the Syncro skid bars below, to be able to carry a motorcycle (with confidence).
campism
campism is offline
PostPosted: Tue Aug 22, 2017 3:53 pm    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
Sodo wrote:
...500 lbs is a large motorcycle (that's too much for a vanagon!) I think it would be fine for your cargo shelf.
Five hundred pounds is about average for many midsized street bikes. The large ones easily top 800.
'87 Westy in Wolfram Grey Metallic
jberger
jberger is offline
PostPosted: Tue Aug 22, 2017 4:13 pm    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
Cargo trays should not be installed on the typical bolt-on-to-tow-hook receiver hitches without other means of support. I have seen many tow hooks bend under quite minimal load and your tray will be dragging ground. Tongue weights are usually rated at the ball or close to it. If you put 500lbs 24" off the CL of the ball, well.. that's quite a lever.
djkeev Premium Member
djkeev is offline
PostPosted: Tue Aug 22, 2017 4:24 pm    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
IF I were to buy a ready made bumper hitch, this would be my go to source.
http://burleysmotorsports.com/index.php?main_page=...e6v67tgvg2
Dave
Ghia
Vanagon
Beetle
Sodo
Sodo is offline
PostPosted: Tue Aug 22, 2017 4:44 pm    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
Yes that's way too much. 200 lbs; 12" rearward might be a good limit for a cargo shelf on a Vanagon with a tow-hook mounted hitch.
Maybe filnd a 200 lb person, have them stand in the center of your cargo shelf and bounce on it. If you see any flexing, then find a different monkey that woughs less (150 lbs, 100 lbs) and reduce the 'weight limit' of your cargo extension accordingly.
Wolfram
Wolfram is offline
PostPosted: Tue Aug 22, 2017 4:47 pm    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
As DJKEEV notes, Burley is the way to go. We have one and it is rock solid. Bolts to chassis rails.
88 Westy, '07 EJ25 Vanaru.
Either van-less on Waiheke Island in New Zealand where we spend the Southern summer, or Wolfram is in Seattle/Olympia in storage.
jberger
jberger is offline
PostPosted: Tue Aug 22, 2017 10:33 pm    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
Re-read your post above. You make it sound like the tow-loop receiver hitch can carry 500lbs on a carrier. It simply can not.
Sodo
Sodo is offline
PostPosted: Wed Aug 23, 2017 10:42 am    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
If anyone thinks I suggested 500 lbs, I apologize for that, and don't want wrong info on TheSamba. I walked out to the van and looked at the tow-loops. My hitch-rating sticker is long-gone but in my foggy memory it that may have stated 100 lbs tongue weight??? Certainly not 500 lbs! That rating means 100 lbs about 6 inches behind the bumper. Note that "200 lbs, 12 inches behind the bumper" is 4X overweight of the rating. It would take a lot of effort to get 200 lbs onto a cargo shelf, so that's not likely anyway.
A hitch mounted cargo carrier will clear out space inside the van and is useful. I would trust --->myself<--- to assess it's carrying capacity with some simple tests. But to stay within the hitch's tongue weight rating, the cargo shelf PLUS its cargo should be limited to 50 lbs. That's not much, but you can choose bulky, lightweight items.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Wed Aug 23, 2017 10:58 am    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
I like having a cargo carrier for carrying large bulky but not too heavy items that take up space inside the cabin. I made my own from a swing-down bike carrier, but next year I'll use a swing-out base unit. I needed to have the load platform higher in order to clear the road when I back out of my sloped driveway. I might use this one on my Vanagon if I can convert it to 1.25"
Casey--
Volkswagens powered by Volkswagen
'89 Bluestar TDI
'01 Weekender VR6
Oly Bulli
kamzcab86
kamzcab86 is offline
PostPosted: Fri Aug 25, 2017 4:40 pm    Post subject: Re: Hitch receiver for Cargo Carrier Reply with quote
GoWesty receiver hitch (which uses the loops & reinforcement T-bar) + riser adapter + aluminum Hitch Haul (drilled new hitch pin holes for it to mount closer to the bumper):
Works for me...
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
