ProjectX Accessory Nut
Posted: Sat Oct 23, 2010 2:26 pm Post subject: |
oval56 wrote: |
IN2VWS wrote: |
Both of these do not look original to me.
Never seen one like the one on the left before, nor have I seen that makers mark.
The one on the right does not look correct on the back.
Here is a pic of the back of an original Lauer 4 brick badge.
cool thing, the seller of thes batches bought them from Lange ( the company who did the crests) direkly out of the old rooms, so not only K.S.P was doing them.
the left & the right came from lauer nürnberg! |
It would appear the tab bar needs to be mounted just above the start of the jail bars on the castle door. Good eye John, you are right about the one not being usable with a VW beetle base _________________ Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible |
KäferKrieger Samba Member
Joined: June 20, 2010 Posts: 331 Location: Pacific Woodpile
Posted: Tue Feb 22, 2011 12:56 am Post subject: |
screws or rivets ?
_________________ I contend that we thinking people should,
"Round-up all religious humans and put them on one island together.
An island where they can permanently sort out their indifferences & insecurities once and for all." |
OilDropMan Samba Member
Posted: Tue Feb 22, 2011 1:35 am Post subject: |
KäferKrieger wrote: |
screws or rivets ?
Screws for sure:
_________________ 1955 Oval Ragtop
1956 Oval Convertible |
Posted: Tue Feb 22, 2011 7:29 am Post subject: |
now thats baroque _________________ I contend that we thinking people should,
69er Samba Member
Joined: July 24, 2009 Posts: 42 Location: Chiang Mai, Thailand
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Sun Mar 27, 2011 1:57 pm Post subject: |
Your badge is a reproduction that incorporates the the city/state crest of Bauden-Wurttemberg's three lions. (scroll down)
http://www.rollintl.com/roll/grcoat.htm _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
69er Samba Member
Posted: Mon Mar 28, 2011 6:37 am Post subject: |
Finally, the answer!!!
Thanks a lot, you're my man. |
Posted: Mon Mar 28, 2011 8:07 am Post subject: |
69er wrote: |
You're welcome. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
franklinunes Samba Member
Posted: Tue Feb 28, 2012 6:40 am Post subject: |
Hello aircooled friends
Recently I bought this hood crest, seems original but another option would be great. I post the pics. Is there writen K. SCHWAGER PFORZHEIM not sure if is ok for this badge.
I cleaned a bit to see the colors better.
Is ok this badge for my split 52? i mean also original?
Thanks and regards
Franklin |
eurodub Samba Member
Posted: Tue Feb 28, 2012 9:18 am Post subject: |
the aluminum base on the crest has the thin edges so is correct for pre 54 cars. later ones have the side edges a little wider... i have a similar one in my 52 split.
.. but i guess you already knew that!
Virtanen posted this pic in the first pages so it explains best how the bases look on early/late vw.
_________________ 1960 1200 model 117 deluxe ragtop
1974 T2 Westfalia Campmobile
1976 MK1 Golf |
fusca66 Samba Member
Joined: September 13, 2007 Posts: 83 Location: Paraná/Santa Catarina Brazil
Posted: Sun Mar 24, 2013 8:15 am Post subject: |
from months of 1951 that came with the hood crest? There are some who came and one that has not come... :roll: _________________ Bug 1966 2280cc
Bug 1951 1900cc
Bug 1952 typ4 1800cc
Sp2 1972 1700cc
Na duvida não ultrapasse |
Dein KDF-wagen Samba Member
Joined: October 17, 2011 Posts: 13 Location: New Zealand
Posted: Sat Jul 27, 2013 7:39 pm Post subject: |
Sorry to drag up this old thread , but I found it really fascinating & informative , Really interesting to see all the various badges that were available ( Fake & non Fake & how to spot the differences )
I see the ‘so-called’ Aussie badge was mentioned near the beginning & IN2VWS made mention that they weren't Australian ( Unfortunately the pictures referring to this are no longer visible )
I was wondering if it was one of these ( see picture )
These are often mistakenly described as coming from “Aussie Specials” Even here in New Zealand & were fitted to some 1300’s post 1965 to 1968
It would appear they were a New Zealand thing only & were fitted on some of the NZ Assembled Beetles that came to NZ as CKD Australian kits .
They were fitted to the Right front 1/4 panel only ( never on the hood in this case ) & secured by two threaded tabs with small Bolts & washers. They had no base frame as the hood versions do on earlier cars & the badge is self is flatter as it was designed to be fitted to the 1/4 panel as per picture below.
Unfortunately , as the decades have passed, little is now known of these so called “ Specials “ apart from the idea that they came standard with a few factory fitted accessories .
I think the whole “ Australian Special “ as some call them ( & which turns out to have nothing much at all to do with Australia ) , got that name more out of Chinese Whispers , i.e., some one said it, so some one else repeated it, then two more people followed suit & said it to 4 others & so on & over time, almost every one is referring to them this way. |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Fri Aug 02, 2013 2:10 pm Post subject: |
fusca66 wrote: |
from months of 1951 that came with the hood crest? There are some who came and one that has not come... |
Starting April 13th, 1951. _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1772 Location: Winnipeg
Posted: Fri Mar 21, 2014 7:42 am Post subject: |
You know, these things amaze me, here's why: Having watched many episodes of How It's Made, I have a pretty good idea of how they were made. The metal backs were probably cast using the lost wax technique, chromed and had the mounting tab brazed on. All the colours were then filled in by hand and it looks as if a cap of some sort was put over the front and then the crest was fired in a kiln. Coming out of the kiln, they were polished again one at a time by hand and then packaged and shipped to the VW factory where they were unpackaged, inspected and transported to the crest installation station on the production lines. I say lines because, and this is the amazing thing, in 1959 the factory was making approximately one thousand, five hundred cars A DAY! This means that these crests were being made at a rate of approximately 1,500 a day. This must have employed a considerable number of people just making crests. Consider this as well: there were several companies over the years that made them, was this sequential? Did PuC at one time lose the contract? What happened when someone lost the contract and they went from making 1,500 a day to none a day? These things have always amazed me. Women's purses amaze me too.
There must be people around that worked at the crest factories that someone could interview that could taklk about what it was like making these things and why all the little differences.
Don |
GERMANAIRE Samba Member
Joined: August 25, 2007 Posts: 689 Location: BUFORD,GA.
Posted: Mon Aug 07, 2017 6:02 pm Post subject: Re: Hood crests |
slammed shady Samba Member
Joined: January 19, 2006 Posts: 257 Location: Wolfsburg, Germany
Posted: Tue Aug 22, 2017 1:01 pm Post subject: Re: Hood crests |
Hi,
I've seen a Hood Crest "Braunschweig" for sale on TheSamba about 10 years ago. Didn't buy it and regret it now, as I am living in Braunschweig today. I can't even find any pics of it anymore, any one on here has a pic of it?
Thanks,
Jan _________________ https://slammedsixty.blogspot.com
https://www.instagram.com/slammedsixty |
jays58s Samba Member
Joined: August 23, 2004 Posts: 2133 Location: Nor-Cal
Posted: Fri Sep 08, 2017 2:56 pm Post subject: Re: Hood crests |
Does anyone know the exact month they changed the colors of the crests? I have an October of 1959 1960 Euro that came with an earlier style 4 brick hood crest, so I was curious if it was changed at some point, or if they used up some left over early parts on my car. |
janerick3 Samba Member
Posted: Sat Sep 09, 2017 3:46 pm Post subject: Re: Hood crests |
Four-brick crests were replaced by three-brick crests sometime in 1955, so it isn't original to your '60. _________________ Thanks,
Jan K. |
Posted: Sat Sep 09, 2017 4:15 pm Post subject: Re: Hood crests |
janerick3 wrote: |
Four-brick crests were replaced by three-brick crests sometime in 1955, so it isn't original to your '60. |
You need to re-think what you said.........three bricks WERE REPLACED by 4 bricks.........not the other way around. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Sat Sep 09, 2017 4:22 pm Post subject: Re: Hood crests |
53 0val wrote: |
janerick3 wrote: |
You need to re-think what you said.........three bricks WERE REPLACED by 4 bricks.........not the other way around. |
That's what I thought, don't you have a 53 or 55 that's pretty original? I'm curious what month they changed from the blue/green crest to the black/red green me? |
