drj434343 Samba Member
Joined: January 31, 2016 Posts: 401 Location: Portland, OR
Posted: Thu Aug 24, 2017 1:45 pm Post subject: Propex HS2000 remote control wiring help needed! |
So, during the installation of my Propex H2000, I had to disconnect the remote control using the white disconnect about 6 inches from the remote. Later, in order to route the harness in a tight space, I had to remove the propex side wires from the connector to get it through a tight hole as the connector was too wide.
I noticed at the time the wires were colored, so I had planned to use the remote side wiring to figure out how to reconnect the loose wires into the connector on the Propex side.
It turns out that Propex used different colored wires on the connector side versus Propex side, so I have no way to know the order of the wires.
Can someone tell me which wire colors connect at the white connector a few inches from the remote controller? I can't find any schematics in Propex's documentation. |
calfredson Samba Member
Joined: January 21, 2015 Posts: 70 Location: Vancouver, BC
Posted: Thu Aug 24, 2017 2:15 pm Post subject: Re: Propex HS2000 remote control wiring help needed! |
Here is a photo of my remote:
Posted: Thu Aug 24, 2017 3:04 pm Post subject: Re: Propex HS2000 remote control wiring help needed! |
Here's what I'm looking for.
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Thu Aug 24, 2017 6:48 pm Post subject: Re: Propex HS2000 remote control wiring help needed! |
here you go :
_________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada.
Posted: Fri Aug 25, 2017 11:05 am Post subject: Re: Propex HS2000 remote control wiring help needed! |
That's exactly what I needed, thanks! |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Fri Aug 25, 2017 6:03 pm Post subject: Re: Propex HS2000 remote control wiring help needed! |
When in need of this info, contact the distributor / warranty center direct (me). You're not the first. Also, be careful unplugging/reconnecting the controller, the power to the heater must always be disconnected when doing this or it will blow the thermostat surge fuse on the main board. |
Posted: Fri Aug 25, 2017 8:03 pm Post subject: Re: Propex HS2000 remote control wiring help needed! |
drj434343 wrote: |
thanks for asking; i half-ass installed mine, but i would probably want to do the same thing when i install it properly. now i have a photo. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
