Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Tue Aug 29, 2017 1:49 pm Post subject: Front door won't open if window down. |
1973 Type 2 / Bus
I tried to search out this problem, but the results focused on advice on how to clean the locks or about keys and mechanisms. Haven't found this problem:
Removed both front door locks for cleaning and adjusting. Came out great! Doors open smartly with just the right finger squeeze, and graphite in the locks after flushing with electrical contact cleaner really compliments the code-cut key.
But wait... now when the driver's side window is rolled all the way down (I have not yet serviced the window regulator) I cannot open the door, either from inside or out. I have to roll up the window about 4 to 6 inches, then I can easily open the door.
What did I screw up? |
Starbucket Samba Member
Posted: Tue Aug 29, 2017 1:57 pm Post subject: Re: Front door won't open if window down. |
pull the door panel off and you will see what's binding. |
Posted: Tue Aug 29, 2017 2:05 pm Post subject: Re: Front door won't open if window down. |
Panel is still off because I need to service the window regulator and make a new plastic sheet. The locking mechanism is recessed behind sheet metal, so I cannot figure out what is hitting it.
I'll have another go with it soon. Just wrapped up three weeks of front end work this morning, and was just glad to actually move the bus off the jack stands. It's like over 100 degrees outside now, and I'm too much of a snowflake to go back out until I get back from work tomorrow morning. |
SGKent Samba Member
Posted: Tue Aug 29, 2017 2:21 pm Post subject: Re: Front door won't open if window down. |
you better get your butt on it before the weekend - it will be 112 F here Friday...
Did the windows come out during this or just the locking mechanism? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51124 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Aug 29, 2017 2:35 pm Post subject: Re: Front door won't open if window down. |
Does the 73 still have the extra window guide section you have to remove to get at the latch? (can't recall whan that got deleted), it may be clipped in wrong at the top and interfering, or the rubber U channel is getting pushed into the works. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Aug 29, 2017 4:10 pm Post subject: Re: Front door won't open if window down. |
SGKent wrote: |
you better get your butt on it before the weekend - it will be 112 F here Friday... |
Sounds great! Plus all the crappy, nose bleeding air that comes with that.
SGKent wrote: |
Did the windows come out during this or just the locking mechanism? |
Just the locking mechanism. It's a tricky little dance, but nothing else needs to come out.
busdaddy wrote: |
Does the 73 still have the extra window guide section you have to remove to get at the latch? (can't recall whan that got deleted), it may be clipped in wrong at the top and interfering, or the rubber U channel is getting pushed into the works. |
Well, there is part of the vertical metal track that has a 10mm cap screw on the bottom that needs to be removed. Then, you have to pull forward on that track... almost to the point of bending it... then the locking mechanism can squeeze by. Maybe I can look up in there with a mini-mag light or something and see what's blocking it.
Probably best if I wait until the concrete is hot enough to scorch my knees as I try to look up there. |
Posted: Tue Aug 29, 2017 4:55 pm Post subject: Re: Front door won't open if window down. |
Wasted youth wrote: |
Well, there is part of the vertical metal track that has a 10mm cap screw on the bottom that needs to be removed. Then, you have to pull forward on that track... almost to the point of bending it... then the locking mechanism can squeeze by. Maybe I can look up in there with a mini-mag light or something and see what's blocking it. |
You know, if you pull down on that it pops out and makes access much easier, maybe it's become unclipped at the top? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Aug 29, 2017 5:00 pm Post subject: Re: Front door won't open if window down. |
Maybe. I will check that out. The locking mechanism also has a odd shaped plastic piece clips over it. It may have become dislodged and is in the way. |
SGKent Samba Member
Posted: Tue Aug 29, 2017 6:49 pm Post subject: Re: Front door won't open if window down. |
That plastic piece gave me trouble on one of my locks when I replaced the latches. the rod that goes to the lock knob on the late bay can also come out of the grommet in the door if you have that style latch. Early latches had the lock as part of the inner handle. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Aug 29, 2017 8:06 pm Post subject: Re: Front door won't open if window down. |
I put on my big boy pants and ventured outside when it got down to just above 90* and discovered that I failed to fasten the vertical window track at the bottom. Track is hanging out, most likely my problem. Screw is missing in action, so I will get it replaced and hopefully I can close out this thread in a swift manner. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Tue Aug 29, 2017 8:27 pm Post subject: Re: Front door won't open if window down. |
Jeez Steve,
I want the two days of my life back I spent reading your thread only to find out you forgot that screw.
Just kidding bro. Glad you worked it out. Come on you guys! It never gets that hot down here. I'm going to Borrego this weekend in search of warm weather. The thing is it will only be 108 by the pool. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Tue Aug 29, 2017 8:33 pm Post subject: Re: Front door won't open if window down. |
Sorry Gary!
And Mark... and Steve... and everyone else.
I'm sure I will be punished in a round fashion shortly for this.
Weather... now the Sierra Nevada is on fire... again. It's a great time to be in the Valley. |
Tcash Samba Member
Posted: Wed Aug 30, 2017 10:04 am Post subject: Re: Front door won't open if window down. |
Yes, parts 9 and 10 were left out by me, causing part 7 to become source of annoyance. |
Posted: Wed Aug 30, 2017 4:29 pm Post subject: Re: Front door won't open if window down. |
Well, the missing screw was not the problem. Still had trouble.
...there is part of the vertical metal track that has a 10mm cap screw on the bottom that needs to be removed. Then, you have to pull forward on that track... almost to the point of bending it... then the locking mechanism can squeeze by. Maybe I can look up in there with a mini-mag light or something and see what's blocking it. |
The window track (Part 7) was deflected during this process. The deflection was just enough to pinch the door lock handle push rod from smoothly operating the door latch assembly. I massaged that straight and smooth again, and the problem is resolved. |
