The Stupid Question Thread
Page: Previous  1, 2, 3 ... 338, 339, 340 ... 513, 514, 515  Next
busdaddy
busdaddy is offline
PostPosted: Sun Aug 27, 2017 7:26 pm    Post subject: Re: The Stupid Question Thread Reply with quote
cv66seabear wrote:
This is probably easier to solve than I know... My 79 Campmobile bed has stopped laying down, that is, it seems to only stay at the 90 degree angle even when it would normally lay down. I'm 6'2" so I can't sleep on a 4 foot bed! Any ideas why it won't behave like it did?
Similar occurence last week: https://www.thesamba.com/vw/forum/viewtopic.php?t=685209
Слава Україні!
cv66seabear
cv66seabear is offline
PostPosted: Mon Aug 28, 2017 7:42 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks! I'll be looking at the hinges closer. I never had a problem before, but maybe something got bent or chipped like Mel22B.
Thanks much again,
Kent
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy"
jlarmen
jlarmen is offline
PostPosted: Tue Aug 29, 2017 7:38 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I noticed some Westy's have the opening to the pop top facing forward, some backward. Are they interchangeable? Can I buy the pop-top part from a reseller if it's the forward facing one and use it on my back facing?
Tcash
Tcash is offline
PostPosted: Wed Aug 30, 2017 10:44 am    Post subject: Re: The Stupid Question Thread Reply with quote
Westfalia Pop Top
Late Pop Top (poptop) onto an early bay,bus,t2
https://www.thesamba.com/vw/forum/viewtopic.php?t=634896&highlight=pop
jlarmen
jlarmen is offline
PostPosted: Wed Aug 30, 2017 7:23 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks...going to be quite an adventure, but I'm in no rush.
Tcash wrote:
Westfalia Pop Top
RixiesRide
RixiesRide is offline
PostPosted: Sat Sep 02, 2017 9:03 am    Post subject: Re: The Stupid Question Thread Reply with quote
Don't laugh...
I need to place a wtb ad for a ignition block for my '73 and don't have a picture to show what I need. Can I use a picture that belongs to another member or even from another site in my ad?
Thanks!
Leslie
1973 Wild Westerner "Mr. Peabody"
1967 Beetle "Sherman"
http://s13.photobucket.com/albums/a269/RixiesRide/WW/
kreemoweet
kreemoweet is offline
PostPosted: Tue Sep 05, 2017 11:38 am    Post subject: Re: The Stupid Question Thread Reply with quote
The terms of use at thesamba.com specifically grant (non-exclusive) copyright to any content posted there to the owner of thesamba.com and permission to use as he sees fit. When you link to any image that has been posted at thesamba.com, it is the site that is "using" (or reproducing) the image, not the linker, and it is perfectly acceptable. As for images from another site, the usual copyright rules are in effect, and the owner of the image is entitled to object if it is used without permission.
'67 bug: seized by the authorities
RixiesRide
PostPosted: Tue Sep 05, 2017 12:43 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thank you for this information. I wasn't sure where to look.
I know I've used other member's pictures in the forum threads but I wasn't sure about proper etiquette in regards to using one for a personal ad.
I took a chance and used another member's pic, and hoped I didn't get a warning letter.
Tcash
Tcash is offline
PostPosted: Tue Sep 05, 2017 1:11 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Hi RixiesRide
Check your PM's. I sent you a link.
Good luck
Tcash
RixiesRide
PostPosted: Tue Sep 05, 2017 1:29 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Tcash wrote:
Hi RixiesRide
Good luck
Tcash
Tcash you are the greatest!!! Very Happy
Thank you
hazetguy
hazetguy is offline
PostPosted: Tue Sep 05, 2017 5:44 pm    Post subject: Re: The Stupid Question Thread Reply with quote
https://www.thesamba.com/vw/privacy.php
All contributions to TheSamba.com, and all material therein are copyright by TheSamba.com (while remaining the property of the author)
it is always proper etiquette to ask permission to use other people's pictures before actually using them, or posting them as your own. see the link in my sigline....
thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
RixiesRide
PostPosted: Tue Sep 05, 2017 6:27 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Good to know for future postings.
Thank you!
beatles4
beatles4 is offline
PostPosted: Tue Sep 05, 2017 6:28 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Hey guys, I keep having a problem with my oil pressure sender. I bought a vdo single pole oil pressure sender and a T fitting to tap into my block where I can still use the oem style pressure sender on the other end. The setup works but for whatever reason it seems as though the t fitting is loosening on me and leaking oil all over my engine.
This was the particular t fitting I bought.
https://www.egauges.com/T-Adapter-VW-male-M10-x-1-p/240-850.htm
and this is the particular sender I bought.
http://www.egauges.com/80-PSI-5-Bar-M10x1K-10-180-Ohms-Single-p/360-001.htm
The T fitting I counted screwed in about 8 full rotations into the block and I did not want to over tighten it so I left it at that. Now it does seem a bit loose from what I imagine is oil having made it's way past and allowing it to leak. What would you guys do? I was thinking maybe the weight of the 2 senders and t fitting were too much and maybe getting an extension tube and mounting everything to the tin so there isn't weight on the fitting but I want to make sure it doesn't leak anymore.
I know the OE sender is a taper fit and the fitting I bought it m10x1 but that seems to be the correct style of thread. Thoughts? Would some kind of permatex or loctite product be the ideal fix?
Click to view image
http://www.vw-mplate.com/mplate2-27771.png
kooper271
kooper271 is offline
PostPosted: Tue Sep 05, 2017 7:16 pm    Post subject: Re: The Stupid Question Thread Reply with quote
You should hang the tee remotely, by running a flexible hose from the sender hole to it. Mine is hung from the firewall. The reason being that the tee can snap off due to vibrations from the engine if it is just screwed into the case.
Blue loctite or permatex will help to stop it from leaking and coming unscrewed, but you should combine that with a tapered fitting.
beatles4
beatles4 is offline
PostPosted: Tue Sep 05, 2017 9:58 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Would you happen to have a good suggestion for a tapered fitting remote line? I am all ears on that idea.
Click to view image
Wildthings
Wildthings is offline
PostPosted: Tue Sep 05, 2017 10:38 pm    Post subject: Re: The Stupid Question Thread Reply with quote
It would help in preventing hurt feelings if you gave the photographer credit when you use his picture, no matter what the rules of the site say.
Tcash
Tcash is offline
PostPosted: Wed Sep 06, 2017 7:28 am    Post subject: Re: The Stupid Question Thread Reply with quote
http://www.ebay.com/itm/400082825646
http://vwparts.aircooled.net/Stainless-Steel-Oil-P...on-kit.htm
http://www.42draftdesigns.com/vw-audi-oil-pressure-relocation-kit/
Vince Waldon wrote:
If you're only relocating a single sender so don't need a splitter...brake hoses are M10x1, just like the oil sender, and come in many convenient lengths. Smile
Just gotta remember to ground the sender... and use teflon tape where appropriate.
fifteenduth wrote:
Just installed with a Beetle front brake flex hose. Perfect. No leaks. Used a sealing washer at engine block and wrap around strap on sender screwed to engine tin for grounding. If only I could get power to the gauge
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Wed Sep 06, 2017 9:52 am    Post subject: Re: The Stupid Question Thread Reply with quote
I agree that it's good etiquette to do that. I personally don't care if anyone uses the pictures I post on this site as long as they don't take credit for the picture or work.
The Samba member since 2004.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Sep 06, 2017 10:49 am    Post subject: Re: The Stupid Question Thread Reply with quote
The asiab3 Basic Rule of Thumb for Using Samba gallery pictures:
If the owner of the photo is the kind of person who posts helpful things, and is here to help people with their cars, I use it without permission. If the owner of the photo is helpful but kind of a peckerhead, I use the picture without asking and give them credit. (Hi Skills!) If the owner of the picture is a complete asshole, I'll take my own because honestly, if you're posting your pictures on here and you're NOT ok with them being used for the good of the hobby and VW community, you can take your ball and go home. Or purchase your own web server space. Or find a hobby where it's cool to help some and not others.
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
RBurn
RBurn is offline
PostPosted: Thu Sep 07, 2017 8:37 am    Post subject: Re: The Stupid Question Thread Reply with quote
Ok searching for this item is littered with anything heater hose...
I found this on ww.. no pict and out of stock. Heres a pict of mine. Can this piping be had? Ive not removed it yet but im not sure how its connected to the heater box thingy. I see its rusted and not connected at this point.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=221255601
70 Karmann Ghia Vert
67 Beetle deluxe
62 Single Cab
70 T2 Model 221 *CARR FIRE Victim
70 T2 Model 231 *CARR FIRE Victim
Page 339 of 515
