So Cal Fam's New 1978 Westfalia
Tcash
Tcash is offline
PostPosted: Sun Sep 03, 2017 2:06 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
May need to use a screwdriver and pop the latch open.
Make sure the pin in the Oval hole (red arrow) is all the way against the end.
Once you do get it open. Pull out the latch release and look in the opening and make sure the pin is retracting all the way. If it is not, pull the latch apart and repair. You may need to file the pin down a little and make it shorter.
Be sure to Push on the cross bar as you are lifting.
Good luck
Tcash
Tcash
Tcash is offline
PostPosted: Sun Sep 03, 2017 2:09 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
Pull out on the knob and take another picture of this. You may need to pull down on the handle to get the latch to release.
BayCreamPuff
BayCreamPuff is offline
PostPosted: Sun Sep 03, 2017 2:35 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
Your latch looks normal from here. The latch pulls straight back. Sometimes pulling the handle down while pulling the latch out helps.
Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper
Mell22B
Mell22B is offline
PostPosted: Sun Sep 03, 2017 7:57 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
the knob isn't pulling at all thus the pin isn't moving, i think we have to take the latch off to repair.
1978 Type 2 Westfalia Kombi
Tcash
Tcash is offline
PostPosted: Sun Sep 03, 2017 8:19 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
Did you try pulling down on the black top handle while pulling the knob?
vwwestyman
vwwestyman is offline
PostPosted: Sun Sep 03, 2017 8:36 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
Yeah, sometimes they can get tight if there is some upward pressure on the pop top-perhaps from new gaskets or something being a little out of adjustment. I definitely have to pull down on the black handle on mine when I have the assist struts installed.
Dave Cook
1973 Wild Westerner
My Thing
Clatter
Clatter is offline
PostPosted: Sun Sep 03, 2017 11:15 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
I sometimes have to hang on the big black handle with all of my weight to get the pin to pop out/back..
Also looks like you might have pinched some top material in the latch?
That'll make it harder for sure..
The top doesn't just 'go down'.
Spend a bunch of time rolling it up and tucking it away from everything as it goes down.
Make doubly sure it gets free of the hinges and latch, etc. before clipping it down that last bit..!
Bus Motor Build
What’s That Noise?!?
Mell22B
Mell22B is offline
PostPosted: Mon Sep 04, 2017 1:23 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
So husband said he had tried pulling it down but we tried with me pulling down with all my height while he pulled the knob and it worked!!!! We will be taking a lot more time to put the top down this time.
Getting closer to our first camping trip! Which is scheduled in two weeks!
vwwestyman
PostPosted: Mon Sep 04, 2017 1:26 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
Was the fabric caught in the latch or something?
Glad you got it figured out though! Does seem like something is a little off for it to be that tight.
Dave Cook
1973 Wild Westerner
My Thing
Mell22B
Mell22B is offline
PostPosted: Mon Sep 04, 2017 4:53 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
No fabric seemed to be caught... eventually we are going to put on a new pop top canvas so hopefully we can get it looked at it then
Mell22B
Mell22B is offline
PostPosted: Mon Sep 04, 2017 4:59 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
Here are some pics of the engine!
Tcash
Tcash is offline
PostPosted: Mon Sep 04, 2017 5:15 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
Ok that is a VW Type IV engine with Fuel Injection.
First thing you guys want to do is replace the Fuel Hoses.
Up in smoke... Bus fires... don't let it happen to you!
Fuel Line Fuel hose - Quality, Makers, Sizes FAQ
Fuel Hoses
thnx to mayor ratwell
http://www.ratwell.com/technical/FuelHoses.html
Good luck
Tcash
BayCreamPuff
PostPosted: Mon Sep 04, 2017 8:26 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
Looks like you've got the upgraded 70 amp alternator or at least the pully from one.
Cream Puff
Earl Grey
Marsha Mellow
OB Bus
OB Bus is offline
PostPosted: Mon Sep 04, 2017 8:48 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
So where are you going to camp?
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
Wasted youth
Wasted youth is offline
PostPosted: Mon Sep 04, 2017 10:01 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
Pop top fabric... I do not have experience with the Baywindow pop tops, but have many excellent camping trips in our 1987 Westfalia and support Clatter's practice of taking time to "roll" the fabric up as the top comes down... doing this keeps it from hanging out from under the pop top and getting wind-whipped, as well as allowing the top to seal properly, and keeping it from binding up the whole process. Mine has a small hole where I was careless and let it get pinched by the pop top latch... the thing you and your husband were just dealing with. Be mindful of this. Be a smart sailor! Laughing
Engine looks unusually well-cared for. Cool You definitely want to change the fuel lines with ethanol-rated fuel injection hose. Tcash provided you some info on that. Whatever you do, keep in mind your gasoline supply is under 30-35 PSI. Choose your hose and fittings wisely.
http://www.gates.com/products/automotive/powerspor...n-hose-mpi
Use these types of clamps, available at most auto parts stores:
https://www.summitracing.com/parts/vpe-12235?seid=...UAQAvD_BwE
DON'T use this crap on fuel injection:
http://www.jpcycles.com/product/7200290?utm_term=%...uMQAvD_BwE
Mell22B
Mell22B is offline
PostPosted: Tue Sep 05, 2017 1:10 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
We are going to San Onofre! I see you are in OB! I used to live there and love it so much! A VW hotspot! Now in Bay Park so I still get there quite a bit. Do you have any fav localish camping spots? Especially ones that don't require booking 6 months in advance?
caffeinebean
caffeinebean is offline
PostPosted: Wed Sep 13, 2017 12:48 pm    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
San O is nice. My fave this year was Crystal Cove, Laguna Beach. South Carlsbad is awesome! But these all need reservations way early on. You can get some spots near Julian for this month.
Mell22B
Mell22B is offline
PostPosted: Wed Sep 20, 2017 6:41 am    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
We had an amazing first camping trip this past weekend! Malibu and Encinitas booked for the coming months!
Only issue we had really was the smell of gas. I was reading and I am going to look into my fuel filler liner. Is that something that can easily be replaced by myself? My fuel lines have already been replaced.
Also the lock on my back bench sit is missing so I need to look into a fix for that since I don't like that it can lift up with my son's seat in there. It has the bottom piece but not the top.
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Wed Sep 20, 2017 8:51 am    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
If the rubber fuel filler hose is original going from the fill spout to the tank along with all the vent hoses, they need to be changed. They dry out. The smaller vent lines crack.
There's many threads including in the "stickies" that show how it's done.
The Samba member since 2004.
Tcash
Tcash is offline
PostPosted: Wed Sep 20, 2017 9:31 am    Post subject: Re: So Cal Fam's New 1978 Westfalia Reply with quote
Try a salvage yard for the seat lock
VW Business Listing
https://www.thesamba.com/vw/shops/
Good luck
Tcash
Page 3 of 5
