Gerrelt Samba Member
Joined: December 22, 2004 Posts: 682 Location: The Netherlands
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Fri Sep 01, 2017 5:47 am Post subject: Re: Mexican fuel injection |
If you don't want to make one, I bought my adaptor from Manfred (www.1600i.de) for ~40 Euros when I first got my car. Antonio has them as well. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
vwjim Samba Member
Joined: November 14, 2003 Posts: 135 Location: Hampshire, UK
Posted: Fri Sep 01, 2017 6:58 am Post subject: Re: Mexican fuel injection |
Excellent, thanks. |
vwjim Samba Member
Posted: Fri Sep 01, 2017 8:16 am Post subject: Re: Mexican fuel injection |
Talking to the owner of the Bug, he tells me someone has already changed the TPS, TB & air temperature sender.
When you change these on a VW ECU, do you have to calibrate them or are they plug +play? I know you would if it was an aftermarket ECU, but not worked on a VW ECU before.
The engine is poor to start / flat spot / stalls when coming down off idle.
Cheers |
hopkin Samba Member
Posted: Fri Sep 01, 2017 8:55 am Post subject: Re: Mexican fuel injection |
vwjim wrote: |
Cheers |
I wish I had an answer for you, maybe you should post over on the Mexican Beetle thread:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8543726 _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
vwjim Samba Member
Posted: Fri Sep 01, 2017 8:59 am Post subject: Re: Mexican fuel injection |
Thanks. |
Antonio Trejo VW Parts Dealer
Joined: December 17, 2003 Posts: 937 Location: Mexico City
Posted: Fri Sep 01, 2017 10:20 pm Post subject: |
vwjim wrote: |
Antonio Trejo wrote: |
7. Fuel and ignition are controlled by a Digifant 1.82 ECU system. This system is unique to the air-cooled engine, although similar in concept and procedures to many VW cars. The control unit includes non-volatile memory for storing adaptation values matching the ECU to the car sensors, and for storing fault codes for diagnostics. The Digifant ECU communicates for adjustments and diagnostics. It is intended to use the VAG1552 or VAS5052 diagnostics tool used by VWoA dealerships. However, it does not use the now-standard 16 pin DLC connector as do US models, so it requires an adapter cable. |
Any idea where the adapter cable etc etc is available to communicate with the ECU?
Thanks |
To scan the mexican Sedan 1600i you will need:
a) Ross-Tech interface
b) Ross-Tech software (free download from their web site)
c) VW Sedan special adapter cable
I sell the genuine special VW adapter cable to scan the Sedan 1600i (1993-2004). _________________ Parts VW
"From Volkswagen of Mexico factory..."
Genuine VW Sedan parts
Genuine VW Ultima Edition parts
Genuine VW Type 2 watercooled parts |
vwjim Samba Member
Posted: Sun Sep 03, 2017 2:21 pm Post subject: |
vwjim wrote: |
Thanks |
I sell the genuine special VW adapter cable to scan the Sedan 1600i (1993-2004). |
Can you PM payment details Inc UK shipping please. |
Ace192 Samba Member
Posted: Thu Mar 29, 2018 8:17 am Post subject: Re: Mexican fuel injection |
Do you happen to have the Bosch part number for that distributor? |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Thu Mar 29, 2018 1:48 pm Post subject: Re: Mexican fuel injection |
9 237 040 023.
AFAIK NLA everywhere except Mexico (from Antonio) or VW Classic Parts in EU (not sure if they still have it). _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Posted: Thu Mar 29, 2018 10:16 pm Post subject: Re: Mexican fuel injection |
GArBa wrote: |
9 237 040 023.
AFAIK NLA everywhere except Mexico (from Antonio) or VW Classic Parts in EU (not sure if they still have it). |
Bosch distributor for VW Sedan 1993-2004. Electronic ignition, digifant system.
rhd914 Samba Member
Posted: Thu Apr 05, 2018 5:56 pm Post subject: Re: Mexican fuel injection |
Hi, i have been searching with little success for a complete ACD engine to buy.
Would like complete, running condition with wiring harness and ecu.
Does anyone know of one or have leads?
Will need to be boxed and i can arrange shipping.
Any help appreciated.
Thanks
Geoff |
