Enkiel Samba Member
Joined: October 21, 2004 Posts: 2771 Location: Quebec, Canada
Posted: Wed Sep 06, 2017 5:27 am Post subject: Removing studs from drums |
So, yeah.
I have these type 3 drums that i want to install on my bus. The problem is that they have studs, and the studs lack tread to install stock rims (about last 3/4 inch is treadless).
So i'd like to remove them. Problem is, i have no clue how, or if its even possible.
My research so far have been... fruitless. Some people seems to use puller, like those used to remove door hinge... Are those studs screwed there or tapped? There's no tread to save when removing them?
here's a picture of the stud ;
_________________ 1964 Turkis Flipseat |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Wed Sep 06, 2017 5:36 am Post subject: Re: Removing studs from drums |
Take a closer look at those splines. _________________ Jack Staggs
Actual name |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Wed Sep 06, 2017 5:58 am Post subject: Re: Removing studs from drums |
Jacks wrote: |
Take a closer look at those splines. |
Jacks right- that drum ia scrap- but back to your question- they look like you can BFH them from the thread end like an american drum. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Enkiel Samba Member
Posted: Wed Sep 06, 2017 6:03 am Post subject: Re: Removing studs from drums |
i think i need enlightment!
why is it scrap?
and... BFH? _________________ 1964 Turkis Flipseat |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Sep 06, 2017 6:29 am Post subject: Re: Removing studs from drums |
the splines are worn out to the point of them being almost completely stripped, probably caused by the axle nut being run loose for a long time.
that drum is junk.
BFH = BIG FAWKIN' HAMMER
personally, i would press them out on a shop press. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Wed Sep 06, 2017 8:47 am Post subject: Re: Removing studs from drums |
Even if that drum had usable splines I would wonder how it was butchered to accept pressed in studs. Did the just blast the studs into the threaded hole? And if so how F'd are the threads? Did they drill the threads out for a proper clearance hole? Meaning you will need to press studs back in. |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Wed Sep 06, 2017 9:41 am Post subject: Re: Removing studs from drums |
You could run a spacer between drum and rim.. Or take them to a machine shop and have smaller (length) studs pushed in. If they were done the right way like Toolbox mentioned.
spacer example. _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Thu Sep 07, 2017 9:17 am Post subject: Re: Removing studs from drums |
Erik G wrote: |
don't you need a spacer to run stock wheels anyway? otherwise the wheel hits the springplate? |
Yes, my tires rubbed on the springplate cast housing. _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
