VIN confusion
Page: 1, 2, 3  Next
jlarmen
jlarmen is offline
PostPosted: Fri Sep 08, 2017 10:57 am    Post subject: VIN confusion Reply with quote
So, I ran the plates through the vm-mplate.com decoder and received the below listing. What I'm confused about is the bus as I bought has a pop-top and what looks like factory or original holes and hardware for a camper, yet the listing says 7 seater. Were the Westfalia or other company doing campers after the fact or were they shipped as campers? I know it's not an after factory hack because the hardware matches all photos I've seen of Westys, though the interior seats and cabinets are long gone.
Model Type 2 (T2) mod. 221(1) :
- Microbus
- 7 seater (arrangement 2-2-3)
- Sliding door right
- LHD
Chassis number 229136402
Serial number 136 402
Modelyear 1969
Planned production date February 24 ,1969
Type of engine Type 1 (B5) - 1584cc, 35 kW (47 bhp DIN)
Type of transmission Manual 4-speed gearbox
Paint color
Color upper part : L581 - Cloud White
Color lower part : L610 - Delta Green
Interior color (doorpanels and seats) 33 - Light Grey/Medium Grey Leatherette
Destination USA, New Orleans
busdaddy
busdaddy is offline
PostPosted: Fri Sep 08, 2017 11:42 am    Post subject: Re: VIN confusion Reply with quote
Post some pictures, Westfalia did conversions before they got on the boat and the M plate says so (unless sometimes when the destination says Germany), many aftermarket conversion companies used whatever the dealer had in stock or the customer brought them. Could also have been done by a PO with a donor camper. Some pics of the bus inside and out should give it away.
Слава Україні!
jlarmen
jlarmen is offline
PostPosted: Fri Sep 08, 2017 12:34 pm    Post subject: Re: VIN confusion Reply with quote
Thanks, so this is the bus before I've stripped everything. Working on a partial roof replacement and currently having the top refinished by a friend who works fiberglass.
I'll see if I have any pictures after the top was taken off.
busdaddy
busdaddy is offline
PostPosted: Fri Sep 08, 2017 12:38 pm    Post subject: Re: VIN confusion Reply with quote
You'll have to put those in the gallery first: https://www.thesamba.com/vw/forum/viewtopic.php?t=6
Слава Україні!
Tcash
Tcash is offline
PostPosted: Fri Sep 08, 2017 12:42 pm    Post subject: Re: VIN confusion Reply with quote
Better take a look at the numbers in the other locations.
VIN, Chassis, Engine number locations
Here is a 1969 Campmobile decoded M-Plate
Note the 517, 518, D67 M-codes
https://www.thesamba.com/vw/forum/viewtopic.php?p=7584246#7584246
Westfalia's where built in Germany. Not the USA.
Good luck
Tcash
jlarmen
jlarmen is offline
PostPosted: Fri Sep 08, 2017 1:42 pm    Post subject: Re: VIN confusion Reply with quote
I'll get some pics of the opening. It doesn't look like a homegrown cutout or install. There is the extra roof section under the main that opens to the opening as well the rubber for the hammock.
jlarmen
jlarmen is offline
PostPosted: Fri Sep 08, 2017 1:47 pm    Post subject: Re: VIN confusion Reply with quote
Good luck
Tcash
Thanks, here's the other VIN and the one I fed into the decoder.
Tcash
Tcash is offline
PostPosted: Fri Sep 08, 2017 1:55 pm    Post subject: Re: VIN confusion Reply with quote
What about the vin on the dash and the one in the engine compartment?
jlarmen
jlarmen is offline
PostPosted: Fri Sep 08, 2017 2:08 pm    Post subject: Re: VIN confusion Reply with quote
The engines a rebuilt donor and I'll check the dash when I get home.
busdaddy
busdaddy is offline
PostPosted: Fri Sep 08, 2017 2:24 pm    Post subject: Re: VIN confusion Reply with quote
A 69 won't have a plate on the dash, that didn't start until 70.
Слава Україні!
Tcash
Tcash is offline
PostPosted: Fri Sep 08, 2017 2:35 pm    Post subject: Re: VIN confusion Reply with quote
Whoops
Not the engine number. The Chassis number stamped on the body to the right of the engine in front of the air cleaner.
Middle picture.
busdaddy
busdaddy is offline
PostPosted: Fri Sep 08, 2017 3:09 pm    Post subject: Re: VIN confusion Reply with quote
Anyone else notice something odd about the rivets on that M plate? Confused
Слава Україні!
67ctbug
67ctbug is offline
PostPosted: Fri Sep 08, 2017 3:21 pm    Post subject: Re: VIN confusion Reply with quote
Yup, It's got the wrong rivets... OG ones are put on backwards. That is not good at all. You might have a stolen bus or something.
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
Tcash
Tcash is offline
PostPosted: Fri Sep 08, 2017 4:20 pm    Post subject: Re: VIN confusion Reply with quote
Good eye BD. Doesn't mean it's stolen. They may have took them off to paint at one time?
jlarmen
jlarmen is offline
PostPosted: Fri Sep 08, 2017 4:56 pm    Post subject: Re: VIN confusion Reply with quote
Yeah, that's a little presumptuous. It's been in storage for 18 years, clean title, two owners. It has tons of bondo, fiberglass and 3 different colors under that and a lot non-original patch jobs.
67ctbug
67ctbug is offline
PostPosted: Fri Sep 08, 2017 5:28 pm    Post subject: Re: VIN confusion Reply with quote
I wasn't saying it WAS stolen, I simply said that you may have one because the vins were changed out. If it's got a clean title and two owners than I wouldn't be worried about it being stolen.
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
SamboSamba22
SamboSamba22 is offline
PostPosted: Fri Sep 08, 2017 5:44 pm    Post subject: Re: VIN confusion Reply with quote
Need to know the numbers on the chassis, left rear area in the engine compartment.
A couple of things could have taken place here, one a 7-passenger bus was converted into a camper.
- Time consuming
- Costly
- With being in storage for almost 2 decades the times before storing would warrant a Westfalia bus for minimal amounts of time and money compared to doing a conversion one self.
A good ole VW guy had a handful of buses, took that current bus filled with bondo, which was totaled, and replaced the plates with a 7-passenger bus, allowing him to either drive it or sell it.
That’s all I’ve got, its been a while since I’ve caught Dateline with Lester Holt.
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
jlarmen
jlarmen is offline
PostPosted: Fri Sep 08, 2017 6:12 pm    Post subject: Re: VIN confusion Reply with quote
- Time consuming
- Costly
I'll look for the numbers when I get back in town. Still dealing with hurricane cr*p. The VW shop I bought it off said the seller was a VW mechanic, parts and re-seller since the 70's before closing shop, then stored it among others, so the latter may be plausible. Won't be many original parts left when I'm done, so a classic restoration is not what I'm after, just a driver.
busdaddy
busdaddy is offline
PostPosted: Fri Sep 08, 2017 6:26 pm    Post subject: Re: VIN confusion Reply with quote
I'm not saying it's stolen, just suspicious looking, I'm curious what the number beside the battery looks like from above and below. Some more pics of the cab and interior would help clear it up, pulling a spring plate cap off the rear torsion housing and seeing what color is under it would be even more decisive.
Слава Україні!
jlarmen
jlarmen is offline
PostPosted: Fri Sep 08, 2017 7:25 pm    Post subject: Re: VIN confusion Reply with quote
An interior shot. The base color under the bondo, primer, white coat matches the delta green specced.
Page: 1, 2, 3  Next
