busdaddy Samba Member
Joined: February 12, 2004 Posts: 51146 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Sep 08, 2017 7:34 pm Post subject: Re: VIN confusion |
Well you would think that, but close inspection of that pic brings up more questions.....
Although the color is a deluxe or stationwagon one the lack of armrest mounts and mount for the Westfalia seat welded to the floor contradicts that. Too bad the seat belt is in the way or we could see if it has rear heater outlets, I also can't quite see enough of the bulkhead to spot a fresh air vent hole.
Quite the puzzle you have there, more pics please. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Fri Sep 08, 2017 7:47 pm Post subject: Re: VIN confusion |
jlarmen wrote: |
busdaddy wrote: |
I'm not saying it's stolen, just suspicious looking, I'm curious what the number beside the battery looks like from above and below. Some more pics of the cab and interior would help clear it up, pulling a spring plate cap off the rear torsion housing and seeing what color is under it would be even more decisive. |
An interior shot. The base color under the bondo, primer, white coat matches the delta green specced. |
Brackets are in place for middle seat, showing signs of a 7-passenger Transporter.
Whatcha link BusDaddy? Tcash? What green is that? _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Fri Sep 08, 2017 8:01 pm Post subject: Re: VIN confusion |
Some early Westfalias have the brackets so that's not definitive, seat belt hole plugs in place say camper from here, and no middle seat delete listed on the M plate, hmmm....
Does the bus have belly pans?, just the 2 on the outside between the frame and rockers?, or middle between the frame too? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jlarmen Samba Member
Posted: Fri Sep 08, 2017 8:08 pm Post subject: Re: VIN confusion |
Pic of the top. Don't have other interior shots with me.
Possible a sunroof model with a camper thrown on top? |
Posted: Fri Sep 08, 2017 8:14 pm Post subject: Re: VIN confusion |
busdaddy wrote: |
Does the bus have belly pans?, just the 2 on the outside between the frame and rockers?, or middle between the frame too? |
Don't think it has a middle one, I recall seeing some rust on the crossmember and noting there was easy access. |
Tcash Samba Member
Posted: Fri Sep 08, 2017 8:15 pm Post subject: Re: VIN confusion |
busdaddy wrote: |
I'm curious what the number beside the battery looks like from above and below. |
Tcash Samba Member
Posted: Fri Sep 08, 2017 8:32 pm Post subject: Re: VIN confusion |
No worries. We're here to help.
From above and below.
Posted: Fri Sep 08, 2017 8:40 pm Post subject: Re: VIN confusion |
Tcash wrote: |
LOL. I'm not worried, I'm from Texas. Either way, this 'thing' is getting put back together. No comment on the top? You have a pic of where exactly the engine bay # would be? |
Tcash Samba Member
Tcash Samba Member
Posted: Fri Sep 08, 2017 8:50 pm Post subject: Re: VIN confusion |
Tcash wrote: |
Not the engine number. The Chassis number stamped on the body to the right of the engine in front of the air cleaner.
Middle picture.
Posted: Fri Sep 08, 2017 9:29 pm Post subject: Re: VIN confusion |
Sure looks like a real Westfalia, but the green is odd, unless it's a Velvet green 68, any pics of the dash, front door handles and engine compartment?
The square on the roof is where the cot was mounted. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Sep 08, 2017 10:10 pm Post subject: Re: VIN confusion |
busdaddy wrote: |
The square on the roof is where the cot was mounted. |
Found two more pics.
The rear deck looks replaced and theres some fiberglass in that area as I recall. I don't have any door closeups but you can zoom the overall pic. *engine pic is a still from a vid of it running before someone points it out.* |
67ctbug Samba Member
Posted: Sat Sep 09, 2017 6:12 am Post subject: Re: VIN confusion |
All I can say is that this is very interesting... _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Sat Sep 09, 2017 9:34 am Post subject: Re: VIN confusion |
No drains or nuts in the sunroof opening, that's a Westfalia roof. Looking at the pics on page 1 again I see 68 only door handles and that sure looks like 68 only Velvet green.
Yet the VIN and M plates say 69 deluxe with no sunroof, I suspect it had some title issues magically solved with a pop riveter and a convenient "near match" sounding title. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Sep 09, 2017 10:02 am Post subject: Re: VIN confusion |
busdaddy wrote: |
Yet the VIN and M plates say 69 deluxe with no sunroof, I suspect it had some title issues magically solved with a pop riveter and a convenient "near match" sounding title. |
According to this, the Velvet Green was available in '69 as well: https://www.thesamba.com/vw/archives/info/colorstype2.php
[/quote]
Quote: |
Velvet green 64-70 38 L512 43319 |
Quote: |
August 1968 up to July 1970
From Ch. N. 219 000 001 to 210 2300 000
Paint L 50 K (47) Neptune blue
L 282 (42) lotus white
L 345 (41) light grey
L 512 (3 velvet green
L 567 (46) ivory
Upholstery 51 dark beige 69 51 dark beige 69 51 dark beige 69 51 dark beige 69 45 medium grey 68
Load compartment interior: L 275 light beige, Mod. 271, 274: L 567 ivory
Wheel disc, rim: L 581 cloud white; Hub cap: L 70 X grey silver; Bumpers: L 581 cloud white, Mod. 271, 274: L 567 ivory
Steering column tube, gearshift and hand brake lever: L 41 black; Seat frame: LD 43 grey black
Thanks for the help and info. She's an ugly beast at the moment so whatever Frankenstein it turns out to be, it's going to be what it is. There's a trove of shells in the area it came from, so the body swap is a possibility. |
Posted: Sat Sep 09, 2017 10:25 am Post subject: Re: VIN confusion |
Read that chart carefully, the upper 1/2 is commercial vehicles (panelvans, trucks and Kombi's), the lower 1/2 is standard and deluxe microbus.
Velvet green is listed after 68, but I haven't ever seen a North American delivered bus in VG after 68. Delta green is listed in the 69 microbus chart but is much darker than VG.
Either way it seems a 68 camper got the VIN from a 69 microbus, if you can get it licensed without a hassle then enjoy your camper for what it is, but consider the complications if you ever go to sell it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Sat Sep 09, 2017 12:27 pm Post subject: Re: VIN confusion |
One more thing.
busdaddy wrote: I'm curious what the number beside the battery looks like from above and below.
The chassis number stamped in the engine compartment.
Posted: Sat Sep 09, 2017 12:50 pm Post subject: Re: VIN confusion |
Tcash wrote: |
One more thing.
Asked my son to look, said he couldn't see a number, but it's all fiberglass in there. I'll follow up Monday with the yard and see what they know. It's from a border town and there are a few graveyards of rusted out bugs and frames. But thanks for reposting that Tcash, saved me from scrolling up, you're quite the help. |
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Mon Sep 11, 2017 9:50 am Post subject: Re: VIN confusion |
It looks like a '68 Westfalia Campmobile. Door handles ; pop top. I see one bracket in the floor for the bed....? |
