stubthumb Samba Member
Joined: January 17, 2011 Posts: 13 Location: Oak harbor wa 98277
Posted: Sun Sep 10, 2017 5:41 pm Post subject: Rear Torson bushing change |
A VW Shop told me they can change the inner and outer rear torson bushings without removing the rear drums or the Diag arms. Is it possible? I don't see it. |
74 Thing Samba Member
Posted: Sun Sep 10, 2017 9:00 pm Post subject: Re: Rear Torson bushing change |
They are correct-just unbolt the spring plate and the torsion bushing cover. |
perello Samba Member
Joined: April 15, 2005 Posts: 830 Location: where social security comes for free
Posted: Tue Sep 12, 2017 3:16 am Post subject: Re: Rear Torson bushing change |
I am about to do the same now...
somebody knows a source for quality rubber bushings? _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Tue Sep 12, 2017 5:34 pm Post subject: Re: Rear Torson bushing change |
http://www.sacogermanauto.com/products.php?cat=28&pg=2
The Saco bushings are supposed to be good.
VW quit making the outer ones, but there are still inner VW ones around. I had a set of aftermarket black rubber outer ones and they were under size. |
Posted: Sun Sep 17, 2017 11:45 pm Post subject: Re: Rear Torson bushing change |
left rear already done, set at 27 degrees. I'ts not as difficult as I thought, but I needed to learn how to do it
1974 German Thing
1978 Bug 1200
Posted: Tue Sep 19, 2017 11:45 pm Post subject: Re: Rear Torson bushing change |
Much better stance now
1974 German Thing
1978 Bug 1200 |
Hyatt181 Samba Member
Posted: Sun Oct 15, 2017 5:07 am Post subject: Re: Rear Torson bushing change |
Where did you get the tool to do that?
I typically do it with a jack and chain.
I've bought the tool that will do it from aircooled.net butt the way it works you need to have the body off the pan to access the proper hole. |
Posted: Mon Oct 16, 2017 12:40 am Post subject: Re: Rear Torson bushing change |
Hyatt181 wrote: |
I build it myself _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Mon Oct 16, 2017 12:29 pm Post subject: Re: Rear Torson bushing change |
Some simple home-made tools for fun with torsion bars...
This tool allows easy and controlled release of the spring plate. It is composed of a length of 3/4" threaded rod, 2 nuts, 2 washers and 2 1/2" eye bolts.
Just pry the spring plate off of the step, then loosen the bottom nut.
Notice the spray paint "silhouette" of the diagonal arm. This allowed me to re-position the diagonal arm "close enough to play jazz" for my drive to the alignment shop.
This tool allows removal of a stuck spring plate from the rear torsion bar. It is composed of two short pieces of 2x2 bolted together. A suitable hole is drilled through the "split" so it can be clamped around the torsion bar.
The soft wood will grip the torsion bar without gaffing up the coating, and the spring plate is easily pried off.
Good luck, Mondshine |
fccperdiem Samba Member
Joined: August 16, 2005 Posts: 107 Location: Ellsworth, Maine
Posted: Mon Oct 23, 2017 6:55 am Post subject: Re: Rear Torson bushing change |
What a great idea, Mondshine! Thank you.
I've gotta make one of these. Your idea is far safer than jacks, ratchet straps, chains, etc... _________________ Eric
Beard Fire Metalworks
Ellsworth, ME
207-242-0016
www.beardfiremetalworks.com |
Posted: Mon Oct 23, 2017 8:18 am Post subject: Re: Rear Torson bushing change |
One thing I forgot to mention is that the nut at the top of the threaded rod is drilled through and pinned to the threaded rod so that the top nut can't accidentally come off.
Surprises are no fun when playing with those spring plates.
