Posted: Mon Sep 04, 2017 3:59 pm Post subject: Re: Distributor, Carbs, Timing... Oh My! |
I think what you are going to find is that your main jets have been clogged from running age gasohol. This stuff seemed to have been designed with clogging jets in mind. You may have some luck with running something like Seafoam mixed with the gas in your tank, but you may well have to pull the jets and use a wooden toothpick to break the crusty stuff loose. |
Seventy3Bus Samba Member
Joined: June 28, 2017 Posts: 40 Location: Washington, DC
Posted: Sun Sep 10, 2017 5:42 pm Post subject: Re: Distributor, Carbs, Timing... Oh My! |
I pulled both carbs off, and they are both pretty gunky. I am going to strip them down and rebuild them using the kit from CB Performance and will post an update once I have them cleaned up and back on.
I found a fairly useful series of videos for cleaning the Weber 34 ICT on youtube:
https://www.youtube.com/watch?v=di5AKIJpjeg
Link above for anyone else who wants to rebuild their own. |
Posted: Tue Sep 12, 2017 7:29 pm Post subject: Re: Distributor, Carbs, Timing... Oh My! |
After cleaning the carburetors I have a couple questions before re-installing.
1. What is the brass port just to the left of base of each carb? I sprayed carb cleaner through it and it connects to the throat of the carb. I'm guessing it is for the balance tube, which my bus didn't have installed. One had a black plug on it and one was open - the resulting vacuum leak probably had something to do with the engine not running. Does anyone have experience installing a new balance tube, or know where to find plugs for the ports?
2. I think the holes on the sides of the manifolds are for the brake vacuum booster. The connectors are made of old brittle plastic and the one on the left side was snapped off flush with the manifold. The PO just screwed a bolt into the plastic, which was pretty loose and I think another source of vacuum leak. I tried screwing the bolt in with some red loctite hoping that I could twist the whole thing out once it dried, but can't get the plastic piece out. Any thoughts? Should I just take the manifold off and carefully try to drill it out?
3. Aeromech has a couple good posts about using Gates vacuum line as a replacement. What are people using as the manifold fittings? I was thinking I would try to find some brass right angle connectors. Anyone have some experience with this?
Here's a before and after pic:
Thanks for your help! |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3844 Location: San Jose, CA
Posted: Tue Sep 12, 2017 7:49 pm Post subject: Re: Distributor, Carbs, Timing... Oh My! |
I see you have the finest Weber Tune-o-Matic Carburetor Calibrator in the background, there...nice work! |
melville Samba Member
Joined: August 09, 2006 Posts: 1245 Location: Just Outside the Redwood Curtain
Posted: Tue Sep 12, 2017 8:35 pm Post subject: Re: Distributor, Carbs, Timing... Oh My! |
The brass port is for vacuum advance.
The balance pipe will connect the manifolds, not the carburetors. It looks like you have something in the balance pipe hole on the left manifold to provide vacuum for the power brakes. You can duplicate that on the right manifold and use a 'T' to hook up the power brakes. You'd just need to buy a couple fittings and some vacuum hose. I would expect to see pipe threads once you get that bolt and sealant out of the right manifold.
If the broken fitting is plastic, you can burn it out after you remove the manifold and walk a safe distance away from the Bus. You should be able to get brass fittings at your local hardware store to go from the pipe thread to a barbed hose fitting. _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
slammed sickness Samba Member
Joined: June 05, 2009 Posts: 236 Location: clallam bay
Posted: Wed Jan 17, 2018 8:38 pm Post subject: Re: Distributor, Carbs, Timing... Oh My! |
you problem seems to be described as the problem I'm have in but my.motor is fuel injected... did you get it fixed? _________________ *Slammed Sickness*
*1960 Bug * |
Posted: Wed Jan 17, 2018 9:35 pm Post subject: Re: Distributor, Carbs, Timing... Oh My! |
I think the majority of my issues were due to vacuum leaks on the intake manifolds where the vacuum brake booster lines tie in, and the timing not being advanced enough. I don't know much about fuel injection, but I would try checking for vacuum leaks (some people check with a propane, you should be able to find a thread on it... be careful) and double checking the timing at full advance with a timing light. I don't know what type of distributer you are running or what the timing should be at full advance, but you should be able to find some guidance in Bentley or by doing a search on here. I hope this helps! |
