Rear Torson bushing change
stubthumb
stubthumb is offline
PostPosted: Sun Sep 10, 2017 5:41 pm    Post subject: Rear Torson bushing change Reply with quote
A VW Shop told me they can change the inner and outer rear torson bushings without removing the rear drums or the Diag arms. Is it possible? I don't see it.
74 Thing
74 Thing is offline
PostPosted: Sun Sep 10, 2017 9:00 pm    Post subject: Re: Rear Torson bushing change Reply with quote
They are correct-just unbolt the spring plate and the torsion bushing cover.
perello
perello is offline
PostPosted: Tue Sep 12, 2017 3:16 am    Post subject: Re: Rear Torson bushing change Reply with quote
I am about to do the same now...
somebody knows a source for quality rubber bushings?
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
74 Thing
74 Thing is offline
PostPosted: Tue Sep 12, 2017 5:34 pm    Post subject: Re: Rear Torson bushing change Reply with quote
http://www.sacogermanauto.com/products.php?cat=28&pg=2
The Saco bushings are supposed to be good.
VW quit making the outer ones, but there are still inner VW ones around. I had a set of aftermarket black rubber outer ones and they were under size.
perello
perello is offline
PostPosted: Sun Sep 17, 2017 11:45 pm    Post subject: Re: Rear Torson bushing change Reply with quote
left rear already done, set at 27 degrees. I'ts not as difficult as I thought, but I needed to learn how to do it
1974 German Thing
1978 Bug 1200
perello
perello is offline
PostPosted: Tue Sep 19, 2017 11:45 pm    Post subject: Re: Rear Torson bushing change Reply with quote
Much better stance now Smile
1974 German Thing
1978 Bug 1200
Hyatt181
Hyatt181 is offline
PostPosted: Sun Oct 15, 2017 5:07 am    Post subject: Re: Rear Torson bushing change Reply with quote
Where did you get the tool to do that?
I typically do it with a jack and chain.
I've bought the tool that will do it from aircooled.net butt the way it works you need to have the body off the pan to access the proper hole.
perello
perello is offline
PostPosted: Mon Oct 16, 2017 12:40 am    Post subject: Re: Rear Torson bushing change Reply with quote
I build it myself
1974 German Thing
1978 Bug 1200
mondshine
mondshine is offline
PostPosted: Mon Oct 16, 2017 12:29 pm    Post subject: Re: Rear Torson bushing change Reply with quote
Some simple home-made tools for fun with torsion bars...
This tool allows easy and controlled release of the spring plate. It is composed of a length of 3/4" threaded rod, 2 nuts, 2 washers and 2 1/2" eye bolts.
Just pry the spring plate off of the step, then loosen the bottom nut.
Notice the spray paint "silhouette" of the diagonal arm. This allowed me to re-position the diagonal arm "close enough to play jazz" for my drive to the alignment shop.
This tool allows removal of a stuck spring plate from the rear torsion bar. It is composed of two short pieces of 2x2 bolted together. A suitable hole is drilled through the "split" so it can be clamped around the torsion bar.
The soft wood will grip the torsion bar without gaffing up the coating, and the spring plate is easily pried off.
Good luck, Mondshine
fccperdiem
fccperdiem is offline
PostPosted: Mon Oct 23, 2017 6:55 am    Post subject: Re: Rear Torson bushing change Reply with quote
What a great idea, Mondshine! Thank you.
I've gotta make one of these. Your idea is far safer than jacks, ratchet straps, chains, etc...
Eric
Beard Fire Metalworks
Ellsworth, ME
207-242-0016
www.beardfiremetalworks.com
mondshine
PostPosted: Mon Oct 23, 2017 8:18 am    Post subject: Re: Rear Torson bushing change Reply with quote
One thing I forgot to mention is that the nut at the top of the threaded rod is drilled through and pinned to the threaded rod so that the top nut can't accidentally come off.
Surprises are no fun when playing with those spring plates.
