CanStan Samba Member
Joined: October 16, 2005 Posts: 1038 Location: Calgary, AB
Posted: Thu Sep 07, 2017 6:08 pm Post subject: Re: The Stupid Question Thread |
It's just cardboard tubing. The same stuff used on the engine from the fan shroud to the heater boxes only a smaller diameter. Maybe this would work?
http://store.concept1.ca/Preheat-Hose-26MM-ID-211255359-WW/
I recall it's just slipped inside the metal vent piece, and over top of the round metal tube at the other end. No clamps or anything that I can recall |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51146 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Sep 07, 2017 6:14 pm Post subject: Re: The Stupid Question Thread |
CanStan wrote: |
26mm sounds too small, I recall digging through the universal preheat hose assortment at my FLAPS to find the correct size (90's GM IIRC), it exists, but it's not a VW part.
You are correct that there's no clamps, the valve jams into the nipple in the floor and the vent bolts down, the hose is just a slip fit between the two. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Sep 07, 2017 7:52 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
26mm sounds too small |
You're right! My mistake. I just went and measured some and they are actually 42mm ID. |
hiwaycallin Samba Member
Joined: May 07, 2008 Posts: 356 Location: Salmon Arm, BC
Posted: Mon Sep 11, 2017 1:13 pm Post subject: Re: The Stupid Question Thread |
How do I remove the distributor from my stock '78 bus? Is it as simple as loosening the clamp at the bottom all the way and pulling up? Or is there more to it? Thanks in advance! |
Posted: Mon Sep 11, 2017 3:25 pm Post subject: Re: The Stupid Question Thread |
hiwaycallin wrote: |
Leave the clamp on and remove the nut securing the clamp to the case, then pull up. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Mon Sep 11, 2017 3:47 pm Post subject: Re: The Stupid Question Thread |
Spray the hole under the clamp with some wd40, it will lube the oring and make it easier to slide out.
When the dist. is out. Don't rotate the engine CCW (counter clock wise) it can spit the dist. drive gear out and loose its timing.
Good luck
Tcash |
Posted: Mon Sep 11, 2017 3:58 pm Post subject: Re: The Stupid Question Thread |
Thanks guys! |
Convoy Samba Member
Joined: March 17, 2011 Posts: 312 Location: San Clemente
Posted: Tue Sep 12, 2017 7:36 am Post subject: Re: The Stupid Question Thread |
Is the 78 metal filler hose (the long version that goes from filler neck to gas tank) interchangeable on a 74 bus that originally has the shorter metal filler hose? |
Posted: Tue Sep 12, 2017 7:37 am Post subject: Re: The Stupid Question Thread |
Convoy wrote: |
Yes. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Convoy Samba Member
Posted: Tue Sep 12, 2017 12:38 pm Post subject: Re: The Stupid Question Thread |
Thanks. My intent is to buy a used longer filler tube from a later model so I may get a EFI return line welded into it (closer to the tank inlet). I know its a no go on welding on my gas tank but is is safe to weld on a used filler hose?? other route would get exhaust tubing, like in the link, and get a return fitting welded on that instead. |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Wed Sep 13, 2017 8:40 am Post subject: Re: The Stupid Question Thread |
Will a 32/36 dfav Weber progressive carburetor work with the distributor bearing the part number 021 905 205 P?
asking for a friend _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
Posted: Thu Sep 14, 2017 4:55 pm Post subject: Re: The Stupid Question Thread |
secretsubmariner wrote: |
asking for a friend |
The 021-905-205P and the 022-905-205S would be the preferred distributors. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sat Sep 16, 2017 2:09 pm Post subject: Re: The Stupid Question Thread |
Convoy wrote: |
If it's removed from the bus, should be no problem. Welding is good for steel to steel joints. I brazed my return tube on. Remove the tube zinc coating in the braze area with some hydrochloric acid. When brazing is complete, paint the outside with some zinc-based paint for rust prevention. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Sep 16, 2017 11:30 pm Post subject: Re: The Stupid Question Thread |
Friend of mine has a California fuel injected bus. I have never peeked inside the engine compartment, so I will take his word on what his set up is. He is complaining that he's burned up two different condensers and last three weeks and is convinced that these new parts are garbage. I agree with that thought to a large extent, but what I am concerned with is that he has burned up condensers.
Outside of leaving the ignition on, what would cause that? |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sun Sep 17, 2017 12:37 am Post subject: Re: The Stupid Question Thread |
Wasted youth wrote: |
I used to think that hooking up the coil backwards (switch positive and negative) could do that, but BusBoyTom had his backwards for the better part of a decade and routinely saw 19mpg before he corrected it
3 of the 5 new Bosch condensers were bad out of the box for me and customer cars in the last two years. When they got hot, my ignition cut out. After cooling, the car would run normally.
Differential diagnosis: Car ran for 10 minutes from cold start before bucking. Car would buck 1-2 minutes after hot start. After leaving the distributor in the freezer all night, installing, and immediately firing up, car ran for 25 minutes without bucking.
Robbie
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Sun Sep 17, 2017 2:27 am Post subject: Re: The Stupid Question Thread |
I don't run any new Bosch tune up parts any more, they are the worst junk out there. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sun Sep 17, 2017 2:30 am Post subject: Re: The Stupid Question Thread |
asiab3 wrote: |
Robbie
Geesz- Robbie- get some ice cream and some pot pies at least. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Tcash Samba Member
