Charlie57 Samba Member
Joined: July 29, 2012 Posts: 140 Location: Lebanon, TN
Posted: Mon Sep 11, 2017 9:26 pm Post subject: A few general questions about Type 4 Engines |
First, are all type 4 engine parts the same, regardless of what vehicle they were used in? I need some tin pieces, as long as they are type 4 am I ok? Does anyone have a good source for these, I need both lower tin for sides 1-2 and 3-4 and also the top cylinder 1-2 cylinder side.
Next, I was watching the "Awesome Powdercoat Type iV engine tin install videos and his heat ex changers are different from mine, If I buy type 4 lower tin will it work with these?
I had my engine rebuilt by Brothers and believe it to be a 2.0, I have already been told the fan shroud is not from a 78, but seems to work fine. What else can you tell by the photo?
richparker Samba Member
Joined: November 24, 2011 Posts: 6985 Location: Durango, CO
timvw7476 Samba Member
Posted: Mon Sep 11, 2017 10:35 pm Post subject: Re: A few general questions about Type 4 Engines |
that puppy is smart enough to know that as long as that engine sits there
there will be no bus rides with his/her snout out of the passenger window. lol.
There were at least two different heat exchanger set ups, linked two
the two different exhaust port designs, oval & square(later models).
The cylinder 1/2 tin should be universal for bus applications, but there is
914/411 tin that would also be different, you want bus tin, for fuel injection
use. The bottom tins? The early right side had a vent hole for the fuel pump,
so you do want later fuel injection engine bottom tins as well, to fit your
specific heat exchangers, at least one tin fastener per side attaches to them. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Mon Sep 11, 2017 11:33 pm Post subject: Re: A few general questions about Type 4 Engines |
richparker wrote: |
Dats one creepy dawg |
Ouch! No puppy love in the Bay forum?? |
Posted: Tue Sep 12, 2017 7:03 am Post subject: Re: A few general questions about Type 4 Engines |
I have to admit, Hurricane my Pomeranian is like no other dog we have ever had, oddest looking pet we have ever had. However he is the best shop dog I have ever had! Never jumps when the compressor kicks on, does not chase other dogs. Pretty good dog, but the last thing I wanted was a little lap dog! My wife picked him out.
Back to VW's
Is there a way I can identify my motor, The boy said it was a 2.0 when I bought it and said the engine compartment was original. What I have learned is the fan shroud is a different year, the engine came fuel injected but there were no signs of FI on this engine. More then likely its a completely different block.
I had Brother in Ontario, CA build the engine, on the receipt they have:
T4 Long Block
1910 CC
Heads 39 x 34
Solid Lifters
C-35 Cam
009 Electronic Distributor
and I purchased a set of 44 webbers
timvw7476 wrote: |
My exhaust is oval. So it's the early design?
Watching Awesome Powdercoating video's there are two tins on the bottom, I do not have either. Did the FI come with them? I am assuming I need them. My engine does not have the thermostat assembly but I am getting AP's thermostat
I will run a electric fuel pump more then likely so my main concern will be the correct lower tin to match the exchangers.
[/b] |
SGKent Samba Member
Posted: Tue Sep 12, 2017 7:15 am Post subject: Re: A few general questions about Type 4 Engines |
the cam is too much for a bus. More a sand rail cam - something with high end power. That isn't to say that it won't have power. In general bus engines last longest when they are kept below 4500 RPM and that cam is a 6,000 RPM cam. Nothing you can do but enjoy it.
What year is the bus
What is the code on the engine case
You want to get away from the 009 distributor and get something that also has a single vacuum can. You can use the 009 in the meantime.
If those are the heater boxes you are using you will need late 1976 to 1978 tin. The breather will work with carbs but not FI _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Tue Sep 12, 2017 7:20 am Post subject: Re: A few general questions about Type 4 Engines |
Charlie57 wrote: |
First, are all type 4 engine parts the same, regardless of what vehicle they were used in? I need some tin pieces, as long as they are type 4 am I ok? |
The short answer is no. The Type 4 engine was used in the VW 411 and 412, the Porsche 914, the VW Bus from 1972 to 1979, and the VW Vanagon from 1980-1982.
There's a lot of different tin depending on the application and even the year of the application. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Martinph Samba Member
Posted: Tue Sep 12, 2017 10:10 am Post subject: Re: A few general questions about Type 4 Engines |
I put a type 4 engine in my 68 Bay. I custom made my own tin. It works well, but if you are after a stock look. then its not the answer. I was able to use the very front tin and very rear tin from a later model. _________________ Daisy Bay is my 68 Bay Westy with type IV Engine |
Tcash Samba Member
Posted: Tue Sep 12, 2017 10:12 am Post subject: Re: A few general questions about Type 4 Engines |
Put the year of your bus in the Title.
Look under Vehicle ID and Parts ID
Tech Tips
[url=http://www.thesamba.com/vw/forum/viewtopic.php?
The Heater Box's you have are for a 1975-78. See if the other Exh. pieces match up. Pay special attention to A-B Exhaust manifolds. Do they take a Oval or Square gasket?
http://www.oldvolkshome.com/2exh7279.htm#251B
p=7271723#7271723]Type IV 4 Exhaust Install[/url]
I need both lower tins
75-78 Type 4 Engine Tin
I have already been told the fan shroud is not from a 1978
The fan shroud could be off any type 4. Yours looks like a 73-74, note the two smog pump mounts on top. You cannot go by that. You need the Engine Case numbers.
Go down to engine case numbers
VIN, Chassis, Engine number locations
Good luck
Tcash |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Sep 12, 2017 10:21 am Post subject: Re: A few general questions about Type 4 Engines |
That DS exhaust /heater box looks like my 78 California piece.
_________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Tue Sep 12, 2017 3:09 pm Post subject: Re: A few general questions about Type 4 Engines |
williamM wrote: |
That DS exhaust /heater box looks like my 78 California piece.[img][/img] |
That's a '79 Cali exhaust in your picture. And that's a 75-78 exhaust the OP has. _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Posted: Tue Sep 12, 2017 9:00 pm Post subject: Re: A few general questions about Type 4 Engines |
Thanks everyone for the help. My engine code is CB041862 which means it's a 1972-73 1.7L.
I have a post I started called "Restoring my 78 from the ground up" I'll start posting everything there, so please FOLLOW it (lol) I'm going to have plenty of questions.
Charlie |
