cdolsen1 Samba Member
Joined: June 28, 2016 Posts: 66 Location: Crystal Lake, Il
Posted: Sun Sep 03, 2017 3:15 pm Post subject: dash lights |
I've been looking for info on dash lights. I want brighter lights. I only see two lights in the dash and they hardly work.
LED might be better?
Where do you get them?
Thanks |
Tcash Samba Member
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Sun Sep 03, 2017 4:47 pm Post subject: Re: dash lights |
Just did mine - results are wonderful:
Note pic is a trial fit on a junk instrument cluster, hence no speedo needle...
See more pics on page 9 of the link above.
Also see this link for details (available 9am-9pm pacific time). _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
Posted: Sun Sep 03, 2017 7:49 pm Post subject: Re: dash lights |
re: LED dash lights...
I ordered two from some place, had 'em installed and neither worked. Phooey.
Next, I ordered two from Superbright LEDS. One worked, but the other blew out immediately. Being a cheapskate, I sent it back under warranty.
Immediately, Superbright LEDs UPS'ed me a new one. They lost money on that deal!
Now I have them both working and I am happy.
Those of us of a certain age need the extra brightness. |
Tcash Samba Member
Posted: Sun Sep 03, 2017 8:17 pm Post subject: Re: dash lights |
static wrote: |
Extra brightness with magnified gauge lenses.
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Sep 04, 2017 8:04 am Post subject: Re: dash lights |
While we're on this topic, does anyone have a recommendation for quality LED bulbs that will fit the wedge-based sockets in a VDO tach (333051d)? Trying to avoid buying low quality stuff that is DOA... _________________ '71 panel, now with FI
mygreenbus Samba Member
Joined: February 14, 2007 Posts: 1154 Location: Palm Coast, FL
Posted: Mon Sep 04, 2017 5:02 pm Post subject: Re: dash lights |
I bought LEDs from SuperBrite. Blue, love them. _________________ '72 Bus |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Mon Sep 04, 2017 6:13 pm Post subject: Re: dash lights |
telford dorr wrote: |
Also see this link for details (available 9am-9pm pacific time). |
That looks almost too bright! Can you still adjust the brightness with the leds? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Mon Sep 04, 2017 6:52 pm Post subject: Re: dash lights |
Yes. An off-the-shelf LED dimmer works fine. I built my own, however.
The camera makes the pic look too bright. Actually, its fine. _________________ '71 panel, now with FI
DucksHockey Samba Member
Joined: April 30, 2016 Posts: 27 Location: Orange County CA
Posted: Tue Sep 05, 2017 1:41 pm Post subject: Re: dash lights |
I bought my LED lights from Auto-Hub.
I bought the following:
2 for the instruments (clear)
1 for the turn signals (green)
1 for the oil (red)
1 for the parking lights (green)
2 for the dome lights (clear)
Do not replace the generator/alternator light as the alternator needs an incandescent light in order to produce electricity.
They have been great! _________________ 1971 Bus
2161 Full-flow Engine
Dual HPMX 44's
Vintage Speed Exhaust and Shifter
1972 Karmann Ghia Convertible
2007 Full-flow Engine
Dual HPMX 40's
1973 Thing
1904 Full-flow Engine
Dual HPMX 40's |
Ry-dog Samba Member
Joined: May 31, 2003 Posts: 450 Location: Lunenburg, MA
Posted: Wed Sep 06, 2017 5:17 am Post subject: Re: dash lights |
telford dorr wrote:
Quote: |
While we're on this topic, does anyone have a recommendation for quality LED bulbs that will fit the wedge-based sockets in a VDO tach (333051d)? Trying to avoid buying low quality stuff that is DOA... |
I sent and inquiry to SuperBright LEDs a while back to track down the replacement bulb for a VDO bulb 600-815, Type E Wedge bulb that uses base VDO 600-840 and they told me to go with the 194 bulb. _________________ '70 Westy
'14 Jeep Grand Cherokee EcoDiesel |
Posted: Wed Sep 06, 2017 9:39 am Post subject: Re: dash lights |
Thanks for the info. _________________ '71 panel, now with FI
Posted: Tue Sep 12, 2017 10:32 pm Post subject: Re: dash lights |
Ry-dog wrote: |
I sent and inquiry to SuperBright LEDs a while back to track down the replacement bulb for a VDO bulb 600-815, Type E Wedge bulb that uses base VDO 600-840 and they told me to go with the 194 bulb. |
Tried that: 194-W6. Even though they're not a large bulb, they just wouldn't fit into the tach - too big in diameter, and too long. Looked through their catalog for other part numbers. Again, no luck. The 194-WHP will physically fit, but is spec'ed as 'non-dimmable' (in fact, most of their 194 type bulbs are spec'ed as non-dimmable). WTF! Called the SBL people and asked about that. Couldn't get a clear answer, but I suspect that this means that there is some circuit inside the lamp which isn't compatible with a PWM type dimmer.
Now VDO makes the 600-886 'E-type' LED, but it's EXPENSIVE (like $16 a bulb - seriously?). Unfortunately, may not have a choice.
So: before I bend over and pop for these bulbs, has anybody found a (reasonable) plug-in LED bulb that will fit this tach (VDO 333051d) that is also dimmable?
Not having fun at the moment. Can't get this done... _________________ '71 panel, now with FI
Ry-dog Samba Member
Posted: Wed Sep 13, 2017 4:40 am Post subject: Re: dash lights |
Sorry to hear it didn't work out.. I didn't get the 194 myself, so I did not know first hand. $16/bulb does sound quite expensive, especially for those of us that added 2 VDO bulb bases to replace the stock background lights for the instrument cluster. _________________ '70 Westy
chabanais Samba Member
Posted: Wed Sep 13, 2017 11:57 am Post subject: Re: dash lights |
I installed green LEDs and they work great. There are replacement bulbs available.
_________________ "I spud therefore I yam." |
Magion Samba Member
Joined: February 15, 2016 Posts: 236 Location: Vancouver, BC
Posted: Wed Sep 13, 2017 12:06 pm Post subject: Re: dash lights |
That clock! Did you install it or your bus came with it aka unicorn? _________________ 1975 Westfalia in Brilliant Orange
1995 Westfalia in Caribbean Green |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed Sep 13, 2017 12:12 pm Post subject: Re: dash lights |
As you consider colors, keep in mind that there are physiological reasons to choose red. Ships use red light in the wheelhouse because red does not destroy your night vision. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Wed Sep 13, 2017 12:46 pm Post subject: Re: dash lights |
Gas heater timer clock produced for 6 months back in 1972 and about as rare as a stock VW Bus heating system keeping you toasty warm in sub-zero temperatures.
Took me 15 years to find it and a lot of treasure to get it.
Martaskukla wrote: |
That clock! Did you install it or your bus came with it aka unicorn? |
Magion Samba Member
Posted: Wed Sep 13, 2017 1:20 pm Post subject: Re: dash lights |
I bet. my Westfalia came with factory BA6. It is my dream to find clock with timer but because it is 1975 the clusters are grey face. I only hope it does not take me 15 years _________________ 1975 Westfalia in Brilliant Orange
