Joined: August 31, 2013 Posts: 12857 Location: North Carolina
Posted: Wed Sep 13, 2017 12:23 pm Post subject: Re: Body Repair Panels? FAQ |
Unfortunately, so is Wolfsburg West.
Does putting your sticker as far away as possible on the same part as the crappy manufacturer's sticker make it any less crappy? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
lil-jinx wrote: |
Here is an example of the one of the best panel on the market,Gerson panel,it is too short and the body lines are off,
No its not...you're not laying it in there right _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
obx71super Samba Member
Joined: December 16, 2012 Posts: 340 Location: Outer Banks NC
Posted: Wed Sep 13, 2017 12:28 pm Post subject: Re: Body Repair Panels? FAQ |
Well, that settles that! That's really a bummer to see the klassic fab panel leave something to be desired as well. Need to order a bunch of metal for my 73 riviera. Guess I'm just gonna go with bus depot and get the "best" quality of everything I need. That funky green panel not fitting right is disheartening, thought Gerson had his stuff well dialed in....poop!! _________________ 71 super auto stick basically original minus a couple resprays
73 Westy automatic with a 2 liter gex, soon to be a 1.8 liter Headflow masters
Newest Addition!! Solid straight 74 thing totally disassembled!! YEEEWWWW |
Posted: Wed Sep 13, 2017 12:31 pm Post subject: Re: Body Repair Panels? FAQ |
Ah thanks for clarifying skills! So in your opinion, since you know what you're doing, will it be worth the money to get what Gerson offers that I need for my 73, then get the best quality bus depot offers for the rest? Thanks for everyone's input! _________________ 71 super auto stick basically original minus a couple resprays
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Wed Sep 13, 2017 4:15 pm Post subject: Re: Body Repair Panels? FAQ |
lil-jinx wrote: |
Skills I hope your right,would you be kind enough to provide a link or info on how it should go on. |
no link...
typically you can't overlay a panel and have it "line up" very well. it's hard to tell from your pic, but the short rocker side of the cheater panel *may* be a little short in the seam...
if you can hold the edge of the panel (the top edge that you'd weld to the bus) to the side of the bus you can probably see if it lines up. the fold in the seam where you are suppose to spot weld it makes it hard to do an overlay.
I have done about 6 of those panels and never an issue...not to say you may have gotten a sloppy one _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Sep 13, 2017 6:33 pm Post subject: Re: Body Repair Panels? FAQ |
This may show it a little better,still come up a bit short,but it is a good solid panel and I will make it look ok,when I compare the piece to the Gerson outer rocker,the rocker is also a little longer.
I did try to adjust the seam profile on the panel,but there is not much give in it.
In the above picture it looks to be a bit short,but after I cleaned out 4 coats of paint and filler from the body lines,the panel was/is the proper length.
This picture shows the body line on the repair panel,the bend where I have marked it was to sharp [90 degrees]I have hammered it out some and will have to give it a few more taps to get it to more closely match the og panel.
Over all I am pleased with it. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
cd sullivan Samba Member
Joined: September 02, 2008 Posts: 19 Location: GTA Ontario, Canada
Posted: Thu May 03, 2018 11:26 am Post subject: Re: Body Repair Panels? FAQ |
Please help.
I need to know if the length of treasure chest louvers on a 1969.
Are the same length as the engine bay louvers??
I do not have access to a reference vehicle to measure them and mine came with out them...
I have searched
Thx!
C _________________ It's not finished until its Pinstriped! |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Wed May 23, 2018 10:19 am Post subject: Re: Body Repair Panels? FAQ |
I'm looking for a left side cargo floor edge for a 73 Baywindow. It looks to be about 12" wide. I have seen it at Schofield's and JK in the UK but not in the US. Bus Depot offers a cargo floor half as does WW. Both seem to have vague stampings in the area I'm looking for. Anyone know of a source for this part in the US? Thanks. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed May 23, 2018 12:37 pm Post subject: Re: Body Repair Panels? FAQ |
cd sullivan wrote: |
Please help.
I have searched
Thx!
C |
I could take some measurements from my 1975 single cab:
(more photos at http://vw.tauxe.net/arandano ),
but I am not sure if that is the same for 1969. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Fri May 25, 2018 9:47 am Post subject: Re: Body Repair Panels? FAQ |
That would be great!!!!, Thank you
I have purchased the engine louvers from Auto Craft Engineering, I just need a reference length, I can't see VW making different tooling for the louvers as it would be inefficient...my assumption is there are the same.
jtauxe wrote: |
but I am not sure if that is the same for 1969. |
jtauxe Samba Member
Posted: Fri May 25, 2018 11:55 am Post subject: Re: Body Repair Panels? FAQ |
Louvers for the engine compartment are 278 mm long, arranged in a 3 x 3 grid.
Louvers for the storage compartment are 298 mm long, arranged in a 2 x 1 grid.
The measurements are +/- a couple of mm, since the edges are rounded and all, but the bottom line is that the storage compartment louvers are 20 mm longer than the engine compartment ones. _________________ John
http://vw.tauxe.net
Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
Tcash Samba Member
Yarkle Samba Member
Posted: Fri May 25, 2018 5:49 pm Post subject: Re: Body Repair Panels? FAQ |
bummer.... this one busdepot is selling:
http://www.busdepot.com/j39782
"Very nice quality, much better than the versions previously available."
Is thicker than previous klokkerholm panels ive seen, but still thinner than the stock ones.
i didnt think about how the removable rear apron might/would/could affect the shape of the corners _________________ Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
https://www.thesamba.com/vw/forum/viewtopic.php?t=771024&highlight= |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri May 25, 2018 6:16 pm Post subject: Re: Body Repair Panels? FAQ |
It depends on your metal skills, the early corner is different on the back edge and where it meets the rear seam, there's lots of meat to trim and reshape it but it's not going to fit or look right if you just slap it on as is.
There's also that bump for the bumper pan the later ones lack. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon May 28, 2018 8:19 am Post subject: Re: Body Repair Panels? FAQ |
jtauxe wrote: |
The measurements are +/- a couple of mm, since the edges are rounded and all, but the bottom line is that the storage compartment louvers are 20 mm longer than the engine compartment ones. |
WOW THANKS!!!!!!
20mm is a massive difference,
this was the last pieces of info. i needed to start on the door.
Thank you again. _________________ It's not finished until its Pinstriped! |
Tcash Samba Member
Posted: Wed Jul 25, 2018 6:32 pm Post subject: Re: Body Repair Panels? FAQ |
I am considering replacing a cab doorskin for a 73 bus. As far as I can tell the only available doorskins are made by Klokkerholm, both for the U.S. and Europe/UK. Does anyone else make doorskins of the same thickness as orignal? I am fighting a stubborn dent repair, but the rest of the door is original and in good condition. I have heard the Klokkerholm skins are a good fit. Fitting a new skin looks fairly straightforward. It looks to be mostly a measure twice, cut once kind of thing. Any pitfalls/downsides to replacing one vs finding a good used door?
Thanks for the help. |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
