garra Samba Member
Posted: Fri Sep 22, 2017 2:43 am Post subject: Tempature warning light flashes |
We started our trip in the van on Monday, about halfway through the first day the warning light on the temp gauge starts flashing. Gauge says it running below midpoint, even colder. Next morning on cold motor warning flashes again, has been flashing continuously since. Did notice when shut off to park and look at sights gauge reading goes down quickly. What's bad, temp sensor or does light have it's own circuitry? _________________ 1984 Vanagon Country Home Camper, 4 sp |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Fri Sep 22, 2017 3:42 am Post subject: Re: Tempature warning light flashes |
If it is working properly it flashes when the coolant level is low. If the coolant level is ok then the sensor might have failed or the wiring is coming loose or a bad earth. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4772 Location: Bemidji, MN
Posted: Fri Sep 22, 2017 4:03 am Post subject: Re: Tempature warning light flashes |
also, if the coolant level in the pressure tank, NOT the one behind the license plate, is okay, pull the sensor in the tank and clean the electrodes off. they measure conductivity/resistance and if gunked up with oil, stop leak, or corrosion, won't sense that coolant is touching them.
there's really nothing to fail in those sensors. even the plastic 'legs' of the sensor can crack but the stainless rod thru the middle of them will be fine if it is clean. the sensing is done with the lower exposed tips, cracks in the plastic above the tips doesn't matter.
-dan |
garra Samba Member
Posted: Fri Sep 22, 2017 4:10 am Post subject: Re: Tempature warning light flashes |
I filled the coolant tank the next morning, looked at it again yesterday and there is fluid to the correct level.
I was in the engine compartment before our trip messing with the altenator voltage regulator. Other issues have also come up since I was in there, must have knocked some items out of position.
Thanks for relieving my anxiety about the light
gg _________________ 1984 Vanagon Country Home Camper, 4 sp |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
DLJ Samba Member
Joined: August 05, 2008 Posts: 554 Location: North California
Posted: Fri Sep 22, 2017 11:43 am Post subject: Re: Tempature warning light flashes |
After you check out all the suggestion's listed above and still light flashes
you will find that the gauge itself is faulty. Not unusual ! If you can source another gauge, try it and you should be good to go. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6243 Location: Portland OR
Posted: Fri Sep 22, 2017 12:24 pm Post subject: Re: Tempature warning light flashes |
DLJ wrote: |
It's actually the sender that goes bad most frequently. Clean the wire connections and the metal probes in the tank. If that doesn't work, change the sensor before you go opening up the dash pod. If temp is ok and fluid level is good, it's ok to drive but keep an eye on things. Mine does it on occasion too. _________________ 89 Westy 2.1 Auto |
weekenderraf Samba Member
Joined: December 16, 2015 Posts: 27 Location: Olen Belgium
