Bassyaks Samba Member
Joined: October 06, 2010 Posts: 1137 Location: S.E. Connetitcut
Posted: Tue Sep 26, 2017 11:49 am Post subject: Syncro Driveline Question |
I'm planing on a long trip with some 6000 ft elev., I won't be using or needing the 4WD, My question is I have a de-coupler and a locking rear. If I was to snap an rear axle or CV , could I remove that axle and lock the diff and still proceed and in the same idea if both rear axles are removed will the front diff still move the van.
I always have a spare front and rear axle in the van . but I was thinking about removing the driveshaft for better performance. Of course with the front the driveshaft will have to be inplace.
thanks |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Tue Sep 26, 2017 12:22 pm Post subject: Re: Syncro Driveline Question |
I was in a situation this summer where one of my options was to remove the broken axle and drive home locked with the decoupler on. I was told by someone who's advice I trust that it was perfectly OK to do so. I did not however choose that option so I can't comment from real world experience... _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
jberger Samba Member
Posted: Tue Sep 26, 2017 2:24 pm Post subject: Re: Syncro Driveline Question |
Yes, you can absolutely run with the axle removed and the locker engaged. For as long as you want, with or without the driveshaft. Typically the front axles will not grenade unless they are filled with sand or under torque.. so I would not worry about it. |
Posted: Tue Sep 26, 2017 4:43 pm Post subject: Re: Syncro Driveline Question |
Thx. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Tue Sep 26, 2017 5:31 pm Post subject: Re: Syncro Driveline Question |
jberger wrote: |
axle removed and the locker engaged. For as long as you want, with or without the driveshaft. |
I agree. This is because you have a rear locker. If no locker, I would "go easy" on the VC and not go too far or fast (on FWD only).
But with the rear axle locked (driving one rear wheel direct drive) I wouldn't worry. It IS beating harder on that one rear drive axle, but to "get home" that's a good use of your equipment ! _________________
....KTMs, GasGas, SPOT mtb |
87vanwes Samba Member
Posted: Tue Sep 26, 2017 5:48 pm Post subject: Re: Syncro Driveline Question |
If you are thinking of traveling with your driveshaft out, locking your decoupler is a must. There were no per visions by vw to run a driveshaft decoupler with out a drive shaft lubrication wise. My first three road trips were without a drive shaft. I ran with it coupled and the sender unplugged so I didn't have to look at the light. I guess that's an aviation thing. _________________ Kevin
1987 westy syncro tdi conversion and restoration.
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
mrshrimp Samba Member
Posted: Tue Sep 26, 2017 7:13 pm Post subject: Re: Syncro Driveline Question |
I drove 120 miles with rear axle removed and rear locker on, decoupled engaged. Was fine and had no issues. But you should just bring a spare rear as they are easy to swap. |
BavarianWrench Samba Member
Joined: January 18, 2004 Posts: 1045 Location: Oceans Edge
Posted: Tue Sep 26, 2017 7:34 pm Post subject: Re: Syncro Driveline Question |
I just took my dad on a four day 1000 mile run through Colorado. We were running from storms and chasing the turning Aspens. We climbed over seven Passes between eight and twelve thousand feet. We used the Syncro off road a bit, showed him the joy of camping wherever. It was primarily highway and dirt roads. I took tools, but no extra parts. It was in the twenties in the evenings, so we carried extra sleeping gear. We were a little heavier then when its just me and the dog. The van made a few new sounds due to the extra three hundred pounds.
You can run with your diff locked and an axle out. If your axles are good and you're not weighing a ton over the vans usual weight, you will not break an axle. Just enjoy your trip. I would leave the drive shaft. You may see something off road worth looking at. All the best. Give us a full report, with some fine photos. |
Sodo Samba Member
Posted: Tue Sep 26, 2017 8:32 pm Post subject: Re: Syncro Driveline Question |
It takes some effort to bust an axle....
.... but less if you cracked it somewhere else. _________________
